Question about Brother PE-150V Computerized Sewing Machine
Pe 150 will not pick up the bobbin thread - Brother PE-150V Computerized Sewing Machine
4 Suggested Answers
SOURCE: My Brother PE 150 will
My pe-150 embrodery machine is not grabing the tread right since I changed the needle out it keeps promping me to check my threading
Posted on Nov 16, 2008
  • 1788 Answers
SOURCE: Hi, my name is Carolyn, I have the PE 150. When
Read the troubleshooting guide in your manual or go to brother-usa.com under customer support, it may have your problem listed under frequently asked questions. And if all else fails call them at 1-877-276-8437
Posted on Sep 11, 2010
caroldon
  • 17129 Answers
SOURCE: Model PE-180 not picking up bobbin thread
Possible that the shuttle settings are not correct. remove the bobbin and thread it once again. reset it back on the catch and see if the thread is caught up. follow the directions once again and make sure the thread is freely moving within the bobbin.
Posted on Dec 07, 2011
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
PE-3000S Pacesetter won't pick up bottom thread
also rethread the machine
clean under the needle plate & in the bobbin area for loose threads or lint
if these suggestions don't help the it's possible that the machine has jumped time & needs to be serviced
May 15, 2012 | Brother Sewing Machines
Dec 07, 2011 | Brother Sewing Machines
Brother pe 150 needle wont pick up thread from bobbin changed needle
Check that the needle is in the right way, flat shank to the back. If it is around backwards, the shuttle hook won't be catching the thread at the back of the needle to form the stitch.
Jun 22, 2011 | White Sewing White 3032
The bobbin thread is not catching. I have rethreaded the entire machine multiple times, tried different bobbins, etc. However, the needle and thread are not catching the bobbin thread. The bobbin thread is...
try a new needle
make sure the bobbin is not warped
make sure the bobbin case area is free of lint or loose thread
make sure you hold the upper thread tail while it's going down to pick up the bobbin thread
make sure there is a 2 to 4 in tail for the upper thread to grab
Aug 01, 2010 | Brother Disney PE-180D Computerized Sewing...
Brother pe150 won't pick up bobbin thread
Hi. This may sound silly, but the most likely reason the upper thread doesn't pick up the bobbin thread is that the needle is in backwards. (Sounds silly, but it's true!)
Needle shanks have a flat side and that flat side has to go in a particular way for your machine. With most modern machines, the flat side goes to the rear, facing away from you. Check your manual to be sure.
The second most likely reason is that your needle may be bent. Check that your needle is straight (or just use a new one).
Hope this helps!
Happy Sewing,
Robbie
Mar 14, 2010 | Brother PE-150V Computerized Sewing...
My Brother PE 150 will not pick up bobbin thread. I changed needles cleaned it etc. nothing helps.
Sep 07, 2008 | Brother PE-150V Computerized Sewing...
Brother PE-150V Computerized Sewing Machine Logo
102 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
