Question about HP vs15 15"LCD Flat Panel Monitor
Poawer will not stay on when I press the power key.
When and if it comes on it goes off emediately. I can not power down my computer.
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed HP monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
Posted on Jul 11, 2010
Monitor goes blank and power light remains on and when i turn it back on, it stays on for about 3 seconds and goes blank again. thank you!
  • Turn on CPU.
  • CPU will be start booting. Red/yellow light will be blinking. If yes then check your monitor light will be fixing and Show *********** Board.
  • If shows and your OS will be Booting and fail to start.
  • If yes you can repair it.
  • Insert OS disk into the DVD driver.
  • Turn off PC.
  • Turn on
  • "Press any key........" when comes this message you press any key.
  • After that you can see two option
?? Fresh copy Installation OR
?? Repair Option
  • For Repair Press "R"
  • It will be start repairing
Thanks.
May 15, 2011 | HP Compaq WF1907 Monitor
BACKLITE WON'T STAY ON
You can only change the back light level in the BIOS. Boot the computer and press F2 immediately. Once you are in the BIOS, set the back light level you want, then save and exit. When the computer comes back up, that will be your back light level.
Jun 19, 2010 | Panasonic Toughbook 29 Touch with Backlit...
Goes to self test and says there!
You may have a bad system board, but try this first.
Press
Unplug power cord in the rear of the machine
While holding down the ENERGY SAVER key, plug in power cord
Scroll down to SHIPMENT SET
Press SET
Press 2
Wait for the machine to initialize.
Nov 24, 2009 | Kyocera Office Equipment & Supplies
Power failure on Dell XPS M1530
sounds like a bad charger, try taking out the battery and plug in the charger to the laptop and see if it will boot if it does it might be a bad battery
Sep 25, 2009 | Dell Latitude D600 Notebook
Computer will turn on but wont stay on
Most likely your power supply is faulty. You can test it with a voltmeter to determine if this is the cause or if it's the motherboard.
Sep 15, 2009 | E-Machines eMachines Desktop PC
Screen goes black on my hp pavilion dv4000 notebook
Try connecting an external monitor to the laptop, power up the monitor first then boot up the laptop. The video data will switch to the monitor automatically, check if the monitor dislays a normal image and see if the image stays on the monitor.
Also press and hold the Fn key and press the F4 key, these keys toggle the video output between the LCD screen and the video port.
Test to see if this functions correctly.
Get back to me with the results of the tests.
Jun 03, 2009 | HP Pavilion dv4000 Notebook
Laptop screen goes dark.
Is your computer setup to go to sleep when you close the lid?
Click on start -->control panel-->power options and then check the option that says choose what closing the lid does. You have to change this setting to 'do nothing' if you want the computer to stay on when you close the lid.
May 19, 2009 | HP Compaq Presario C700T
Monitor won't stay on
Restart the computer and tap on f8 button so u can start computer in safe mode, if u are able to restore computer to earlier tiem. IF u are unable to start using safe mode. Ur computer need to reformat. Please insert recovery disc restart computer and tab on down arrow button and follow onscreen instruction...
Jan 19, 2009 | Liquid Video E15LCD1 15"
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
HP vs15 15"LCD Flat Panel Monitor Logo
55 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
