Question about KitchenAid Blenders
Remove coupling drive on kitchenaid blender ksb5mc4
I need to replace the coupling drive on my kitchenaid blender (model# ksb5mc4), but I haven't been able to figure out how to remove the old one. I've taken off the bottom of the base but was unable to remove the coupling. Any ideas?
SOURCE: Kitchen Aid Blender Rubber Coupling replacement
Someone else suggested a link that explains exactly how to unthread the old coupling... and it works. It took me about 90 seconds to fix my blender. But in case that link is dead, here's a summary:
(1) Note that the coupling (the round part with teeth) is threaded to the blender motor in reverse to a standard threading. So it screws off just like a bottle top, but in a clockwise direction.
(2) place the blender base on a tabletop, facing you. You should probably unplug it.
(3) take a punch or a flathead screwdriver, and place it against one of the coupling teeth that is furtherest away from you.
(4) strike the back of the screwdriver with a small hammer or maillot. The result will spin coupling clockwise. It may take several tries, but the coupling will eventually spin clockwise faster than the motor, and it will begin to unthread.
(5) unscrew the old coupling, and screw the new coupling into place (counterclockwise). Note that the new coupling will tighten itself every time you use your blender, so no need to worry about tightening it too much.
(6) Make a smoothie to celebrate your success!
Posted on Nov 10, 2007
SOURCE: Blender base gear knobs broke off
http://www.fixya.com/support/t509590-kitchenaid_ks85_coupling_drive
Reports the same problem and a couple of solutions.
Posted on Sep 26, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Locking the jar on the base Oster Fusion 600W Blender
Here is the user manual for the Oster Fusion:
http://www.osterfusion.com/Manuals/MANUALS/BRLY07-Z00-000_43_29190737.PDF
It looks like you line up the threads, place the base on, and twist to tighten.
-Tha Mp3 Doctor
Posted on Mar 21, 2009
SOURCE: The blender coupling on my
10-01-2009 Sara - see solution for rlaymon 1-9-08 "Top part of base broke off" by TanyaCS on 1-20-08 - good ideas. I just fixed mine - 2 hour job + half hour to put a new cord in. Like TanyaCS my broken coupling was rusted to shaft - used WD-40 twice and let sit - meanwhile took out motor and removed fan - kept screws and washers in order on workbench (kitchen counter) - the fan hole is "D" shaped - fan end of shaft also "D" shaped - I filed a "flat" on the other side of the factory "flat" (side of 'D' that is straight) - Used big pliers on broken coupling and adjustable wrench on on the "flats" on fan end of the shaft. Broken end came right off. New cord is 18 gauge extension cord capable of at least 6 amps. Cut off the un-needed end. Or order a replacement cord $4 when you order the rubber drive coupling $4, pin with slinger washer $3. Bet you also need new rubber feet - didn't buy for mine - wish I had. Bert
Posted on Oct 01, 2009
  • 95 Answers
SOURCE: I have a KitchenAid KSB5MC4.
oops ! may have just pop the thermal fuse inside , but you might have to take apart and see what you did, if you got this cheap enough , might just buy another good luck >
Posted on Dec 20, 2010
How do I remove the motor on kitchenaid Diamond blender, removing the coupler?
Put the base back on, determine which way the motor normally turns from the top when running. Drill a hole in the edge flange of the driving coupling. Stick a punch or screwdriver in the hole and whack the punch with a decent hammer to shock the coupling in the direction it normally will be turning. Sometimes it's a few whacks, sometimes a whole lot more but eventually they always come undone. Replace the coupling.
May 27, 2016 | KitchenAid Blenders
How do you replace the coupling on the  KitchenAid 4KSB5 5-Speed Blender
Buy the new coupling from Kitchen Aid, the instructions are in the bag with the coupling.
Aug 05, 2012 | KitchenAid Ultra Power 4KSB5 5Speed...
Pitcher stuck on base
You will likely need to replace the beaker anyway, the drive which is now melted to the motor coupling is only supplied as part of the beaker/blade assembly. You will also need a motor coupling.
Aug 01, 2012 | KitchenAid Blenders
How to remove the cutters on model ksb560mco pctag@verizon.net
The cutters are part of the collar itself and not available as a separate part. If there is anything wrong with them you need to replace the whole collar. The collars are available on Amazon UK, K A Parts as well as other places.
Dec 31, 2010 | KitchenAid KSB560 5 Speed Blender
I have a KitchenAid KSB5MC4. I believe the motor shorted, since smoke was coming from the bottom. Can you help me figure out how to replace the motor?
Dec 19, 2010 | KitchenAid KSB5 Ultra Power Work Top...
Blender motor drive coupling fitted to motor which drives rotor blades broken and I want replacement.
If it is a KitchenAid blender, the part you will need is a 9704230 coupler.
Jan 29, 2010 | Blenders
Teeth sheared off the coupler drive on KitchenAid Blender
You should be able to remove this assembly from the other parts - then you will have enough room to work on it.
Remember to clean the seal area if disturbed or it may leak.
Aug 20, 2009 | KitchenAid KSB560 5 Speed Blender
I need to replace my rubber spinner with a new one. Where can I get the part and how do I take the old one off and put the new one on?
Hi, you have broken the coupler (sometimes called a coupling). It is relatively cheap and easy to replace. In the UK, K A Parts Limited sell them here and provide removal instructions here.
Aug 11, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
The coupling of my kitchen Aid blender is broke could tell me how to change it
Visit MENDINGSHED.COM.
On the left, click KITCHENAID. On the next page, click KITCHENAID BLENDER PARTS. On the next page, you will see a listing for a drive coupling. You want to choose on the left, which is retailing for $5.95.
You may order the part if you need it. If not, click onto the parts order page and scroll down. There will be a two-step instructional guide on how to properly replace the coupler.
Sep 14, 2008 | KitchenAid KSB5 Professional Stainless...
Aug 13, 2007 | KitchenAid KSB5 Professional Stainless...
Blenders Logo
1,140 people viewed this question
Top KitchenAid Blenders Experts
eyecam
Lawrence Oravetz
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
