Question about Simplex Kaba Ilco Unican 1000 keyless lock
My grand kids are coming for a visit. They are too young to open the Simplex combo lock. Is there a way to temporarily disable the combination and make the door open like it does not have the combo lock on it? I would then like to put the combination back after they leave.
SOURCE: Bought house from bank and trying to retrive lock combination
I'm trying to remove a unican lock from my door but I can't see how to get the handle off. any suggestions?
Posted on Aug 22, 2009
SOURCE: how to change the combination of a Simplex pushbutton lock
Your screwed.
Posted on Mar 18, 2010
  • 963 Answers
SOURCE: We have a Simplex LL101126D41
I found this instruction elsewhere on this site ( thanks to pctuneup191):
PROCEDURES TO CHANGE THE COMBINATION OF
SIMPLEX 1000 SERIES CIPHER LOCKS
1.) ENSURE THE DOOR IS OPEN.
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE
DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
3.) TAKE THE CHANGE PLUG ASSEMBLY COMPLETELY OUT OF THE DOOR.
4.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE ALL THE WAY UNTIL IT STOPS, THEN RELEASE THE KNOB.
5.) PRESS IN THE EXISTING COMBINATION FIRMLY.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE
O'CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O'CLOCK POSITION. NOTE
THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O'CLOCK POSITION UNTIL IT STOPS.
REMOVE THE SPANNER WRENCH.
9.) TURN THE OUTSIDE DOOR KNOB CLOCKWISE (ALL THE WAY, UNTIL IT STOPS), THEN RELEASE.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a
maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND
CHECK IF THE LATCH IS RETRACTED.
12.) RELEASE THE DOOR KNOB.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH
SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59
CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
A Df-59 key can be purchased at this site:
http://absupply.net/kaba-access-control-lock-1000-series-key-df59.aspx
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from
this site:
http://www.ckilock.com/Mpage18.asp
Here is the "literature grid" from the KABA website, which has manuals and parts lists for the
Simplex mechanical pushbutton locks:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.
aspx?id=13
Good Luck!
Posted on Mar 06, 2011
Testimonial: "The information was exactly what we needed."
  • 963 Answers
SOURCE: I have a 5 button
I can't help you directly, but I will steer you to further information.
You will find a link to download the manual for your model on this page:
http://www.kaba-ilco.com/access_control/literature/literature_grid_mechanical_pushbutton_locks.aspx?id=13
These are PDF files, requiring Adobe Reader to open. There is a link on the same page to download Adobe reader.
Customer service can be contacted from this link:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on May 13, 2011
Testimonial: "Thaks, I was able to download pdf and problem was solved.."
  • 963 Answers
SOURCE: how do i change the
I'm not sure of your exact model, but I think you will find the information that you need listed on this grid chart:
You can cut & paste the link or type it into you browser's search bar.
Hover your mouse over the right-most column (Tips) for your model and you will pop up links for Changing the Code or Resetting the Code.
These are PDF files, requiring that you have Adobe Reader or equivalent installed on your computer in order to view them. If you're not able to view them install Adobe Reader from this link:
http://get.adobe.com/reader/
Posted on Jul 14, 2011
Forgotten cipher lock combo
First, you need to have access to both sides of the lock (door must be open).
If you are technically able, you can disassemble the lock, remove the combination unit and take the cover off of it. From there you can determine the combination and then re-assemble. The instructions for this can be found online.
If you are not technically able, you should not attempt this and bring the lock to a locksmith or get a new one.
Feb 17, 2014 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex 1000 lever handle when correct combo put in lock combo lock operates fine except unless you let the lever snap back lock dose not reset in locked position, in other words if you slowly let the...
I don't have a direct answer, but here is the contact info you need for customer service:
1-800-849-8324 (option 1)
Technical Support (Simplex, E-Plex, PowerLever, 4000 Series, Solitaire 850L, Solitaire 850/950)
1-800-849-8324 (option 3, and then option 6)
Tech Support is probably your best bet!
Aug 25, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
I tried reseting my combo on the simplex LP 1000/8100 series and messed up. I entered a new combo and the latch did not work. Not only did the new combo fail, I could not open it with the old combo. What...
Contact Kaba Ilco for technical assistance:
Jul 03, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
If the wrong combo is entered into my simplex Unican 1000 series Keyed lock the locking mech. will not reset unless I open the lock and manually move the levers. How Do I correct this so the lock functions...
PROCEDURES TO CHANGE THE COMBINATION OF SIMPLEX 1000 SERIES CIPHER LOCKS
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
The spanner wrench (SMPBC201278 Simplex:SpannerWrench $9.00) referred to can be purchased from this site:
Apr 22, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
We have a Simplex LL101126D41 Combination lock and tried to change the code following the instructions for an earlier model (on that does not have the handle). Now the lock will not recognize the new nor...
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
this site:
aspx?id=13
Good Luck!
Feb 11, 2011 | Simplex Kaba Ilco Unican L1000 keyless...
I changed my combination and dont know what i set it to
If you forgot the combo you will need to reprogram it. If you can not get in to open the door to reprogram you can email llco at info@lilocksmith.com for an override code.
Good Luck
Dec 28, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
How do i do a "lost combination" combo change on a 5-button cipher?
O'CLOCK POSITION.
maximum of five.
REMOVE THE KEY.
Oct 28, 2010 | Simplex Kaba Ilco Unican 1000 keyless...
Need instructions on changing combo
2.) INSERT THE DF-59 CONTROL KEY INTO THE COMBINATION CHANGE PLUG ASSEMBLY (ON THE BACK OF THE DOOR) AND UNSCREW THE CYLINDER BY TURNING THE KEY COUNTERCLOCKWISE.
6.) INSERT THE SPANNER WRENCH IN THE COMBINATION CHANGE SLEEVE. IT SHOULD INSERT AT THE NINE O’CLOCK POSITION.
7.) TURN THE SPANNER WRENCH GENTLY CLOCKWISE UNTIL IT STOPS AT THE 12 O’CLOCK POSITION. NOTE THE NOTCHES IN THE COMBINATION CHANGE SLEEVE MOVES AS THE SLEEVE IS MOVED.
8.) TURN THE SPANNER WRENCH COUNTERCLOCKWISE BACK TO THE NINE O’CLOCK POSITION UNTIL IT STOPS. REMOVE THE SPANNER WRENCH.
10.) INSERT THE NEW COMBINATION BY PRESSING IN THE BUTTONS. USE AT LEAST three numbers and a maximum of five.
11.) TURN THE DOOR KNOB CLOCKWISE ONCE, ALL THE WAY, UNTIL IT STOPS. HOLD IN THIS POSITION AND CHECK IF THE LATCH IS RETRACTED.
13.) TURN THE DOOR KNOB CLOCKWISE ONE MORE TIME TO THE STOP POSITION. AT THIS POINT, THE LATCH SHOULD NOT RETRACT UNLESS YOU USE THE NEW COMBINATION.
14.) REINSERT THE CYLINDER INTO THE BACK OF THE DOOR BY SCREWING IT IN CLOCKWISE WITH THE DF-59 CONTROL KEY (DO NOT OVERTIGHTEN!)
REMOVE THE KEY.
Aug 04, 2009 | Simplex Kaba Ilco Unican 1000 keyless...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
69 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
Pamela Leach
Pamela Leach
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
