Question about Fuji FinePix F470 Digital Camera
Fuji f40 wont turn on - Fuji FinePix F470 Digital Camera
Dryer wont run gave me f40 code, can you help me?
I found two possibilities for an F40 code.
1) Error Code F40 is that the thermal fuse has blown.
2) The F40 error code is a communication problem between the machine control board and motor control board. A bad connection might or might not cause this.
Dec 23, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Needs software for Toshiba Gigabeat F40
Maybe you can find it on Toshiba site, the following link is download link include all aplicable to Gigabeat models:
Click here for Gigabeat F40 software
hope it help
regards
Apr 18, 2010 | Toshiba Gigabeat F40 40 GB MP3 Player
My fuji finepix f40 says card error when I turn it on, how do i fix this without losing all the photos on the card?
Try the card in another camera or card reader. If that doesn't help, there is software you can get to recover the pictures from the card. If you do a google search, you should come up with software that will help you with this as there are many programs available.
Jan 26, 2010 | Fuji FinePix J10 Digital Camera
Photos saving to camera internal memory not to memory card.
go into memory on menu and choose change memory settings from internal to card
Mar 16, 2009 | Fuji FinePix F40fd Digital Camera
Fuji finepix f50 camera was dropped with lense out, and now wont return. it also says focus error on screen. I have the same problem and Fuji want £88.00 to repair it - you can buy a new camera for...
Unfortunately dropping this model, and the f40, 45, 47 fd models, is suicidal for the camera. The lens has an inner slide ring which other models do not have and this ring has three lugs to keep the lens from spinning when powered up and used. Unfortunately these lugs are also clips which hold the focus lens inplace. These are tiny. hard to repair
Feb 13, 2009 | Fuji Finepix F50FD Digital Camera
I need to reset the entire program on the f40. System settings and all
The EASY but Time consuming way (If you Only hagve USB 1), is to just RESET the unit.
The manual will run you through it, and reload.
I have both Gigabeat Room, and Win/Player 11, and have reset and reloaded a few times.
Just take some time (Specially with Gig Room)
Good Luck
Jun 13, 2008 | Toshiba Gigabeat F40 40 GB MP3 Player
Toshiba gigabeat F40
Because bootloader found ,must copy again GBSYTEM
Jan 29, 2008 | Toshiba Gigabeat F40 40 GB MP3 Player
Overly white pictures
This may be due to jammed iris at fully open. You are over exposing the photographs. if the iris is stucked due to friction a little tappin your camera from side may help you.
Sep 08, 2006 | Samsung Digimax i6 PMP Digital Camera
Fuji FinePix F470 Digital Camera Logo
47 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
