Question about Acer Aspire 3680 Laptop
My theme went form the standard xp look to the really old windows classic look and now my internet won't work and I can't change the theme back to what it should be
How can i change the colors of my desktop back to normal. i have a old school desk top the box ones
You should be able to go into display properties and select Windows Classic as the theme.
Right click on Desktop
Select Properties
On Theme tab select Windows Classic and then click apply.
If you have customized the Windows Classic theme and saved as Windows Classic, then you will need to edit the registry to remove those customizations. If this is the case, reply to this solution and I will research and let you know where to make the changes. Beware that incorrectly modifying the registry can cause the system to not boot or have other problems.
Best of luck, Jim
May 07, 2011 | E-Machines eMachines Desktop PC
The IE8 menu bar and certain toolbars are blacked out. Why?
This is caused by having your display properties (Themes, Appearance) set to 'Windows Classic'. Resetting them to Windows XP fixes it - You can then change it back to Classic again if you wish and it will display properly
Jul 15, 2009 | Microsoft Internet Explorer 8
Windows XP English
copy the thyemes in the
windows >> resources folder
and also install the latest version of uxtheme patcher
now right click on the desktop go to properties and select the new theme which will be there in the list of themes
Jul 08, 2009 | Microsoft Windows XP Professional SP3 Full...
Lost Vista colors and themeS in personalzations
Remove and reinstall the video drivers on the machine. That should resolve your issue.
May 25, 2009 | HP Pavilion s7700n (5584788) PC Desktop
Trouble with theme
click in this order
right click my computer
properties
advanced system sttings
continue
settings [under performance]
enable desktop composition.
ok
ok
then when ur done its possible that the glass might not be back, so go back thru all the same steps, but instead of enable desktop composition. Click
enable transparent glass.
All should be back to normal, thanks again.
Apr 10, 2009 | Microsoft Windows? Vista Home Basic...
Theme Failing to work.
Go to Restore..
Menu details:
start==>all programs=>accassores=>system tools=> system restore...
give ur installation date...thanks.........
Mar 25, 2009 | Computers & Internet
About themes and classical view
Go to control panel. Windows color scheme and appearance, you should be able to change it back there. Hope I helped :)
Mar 19, 2009 | Microsoft Windows Vista Home Premium with...
Windows XP Default theme deleted
This happened to me once on my other computer, I don't know what caused it, maybe service pack 2 that I installed but I don't know. Anyway i just rebooted and then the themes were back and I could change it again.
I hope this helps
Jan 14, 2009 | Microsoft Windows XP Media Center Edition...
Acer Aspire 3680 Laptop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
