Question about Jura Capresso Impressa E8 Espresso/Coffee Maker
How do I remove the cover on the Jura Capresso F8? I am trying to clean out the grinder and any other areas that may need cleaning.
    Genius:
  • 1,478 Answers
Remove the carafe and filter basket. Also remove the water reservoir lid.
Also check the user manual to see more information as regards this.
Take care.
Posted on Jul 11, 2010
  • bill234 Jul 11, 2010
    This is a Jura Capresso F8. There is no filter basket. I don't FixYa if the answer was in the manual.
    There are 4 Torx screws on the the top of the unit. I have removed these and snapped the cover away from the front of the unit. It appears as if there are four rivets holding in the rest of the cover in the rear of the unit.
    What is the proper way to disassemble this unit for a thorough cleaning?
Grinder stopped working today. Tried to clean with no result. Anything I can do to trouble shoot? The timer goes, but no grind...
check to see if the grinder is jammed. Most likely, there was something that's gotten caught in it, and jammed the mechanism.
Feb 27, 2016 | Jura Capresso Capresso Infinity Conical...
How to open for cleaning jura ena5 coffee machine
The question is, how to open the machine? I found elsewhere one should unscrew the back logo, but it is slippery. Seems like a special tool would be needed, but I did not find it.
May 06, 2012 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
How to clean jura C5 grinder
How to access grinder itself? Where is it? My Jura C5 doesn't grind coffee beans at all. Firstly grinder has started with starnge noise and then stopped with alarm "no beans", now it doesn't start at all..
Mar 06, 2012 | Jura Capresso Impressa Coffee Makers &...
Jura Capresso E8 keeps getting error code 8 over and over. I will clean, remove grounds etc, it will make a few espressos, then back to the error code. I can hear it struggling.
One of the problems that I see with these units is the Grinder setting. Sometimes the grinder is set too fine for Dark and Oily beans. This setting will ( can) clog up the brew screen after less than 10 cups are brewed. Also, running the cleaning tablets through to create a clean starting point may help you. Try turning the grinder to a slightly coarser setting and try that.
Sep 21, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura E9 grinder spins but does not grind
I had a similar problem, and solved it by turning the grinder by hand against resistance. Apparently the grinder wasn't really turning during the cycle and needed to be cleared. If your beans are "hopping" this may be a different problem.
Aug 14, 2009 | Jura Capresso Impressa E9 Espresso Machine...
Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
Jura capresso E8
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Apr 10, 2008 | Jura Capresso C1000 Espresso & Coffee...
Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
200 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
