Question about Dell Dimension 8200 PC Desktop
My computer has slowed down and when I attempt to use programs it takes multiple tries to click on a function; I have norton installed but what could be the problem?
3 Suggested Answers
  • 788 Answers
SOURCE: After installing Norton Antivirius laptop has run slow
Go to add or remove programs and remove norton anti-virus. Reboot your unit and download AVG free.
P.S. you will need to remove the instant udates and anything that say's symantic's
Posted on Nov 10, 2009
Betageek52
  • 396 Answers
SOURCE: Slow computer start up
I remove Norton from more PCs then I install it on. It is an very intrusive suite of protection, and is not compatible with Windows XP age PCs, due to the size this software has grown to, over the last few years. Call Norton and get a refund, if you find my answer useful. I use a set of programs that I update manually. I am not an agent or advertiser for the products on this list. It changes depending on compatibility with the system in front of me.
1) Spyware Blaster(Free) Open it, update it, enable all disabled protection, and then close it, you're done. This one does NOT run in the background, after you close it. Every couple of days.
2) Malwarebytes Antimalware(Free) Open this, run a scan. It will update prior to the scan. When it is done, you can have it quarantine and remove all problems it finds, and then close it. At LEAST once a week.
3) CCleaner(Free) This is used to remove the crud from your system. I DO NOT RECOMMEND using the Registry Cleaner it has. This uses a destructive method of fixing registry problems, by deleting things, and WILL trash your system. Under TOOLS, it has an Uninstaller, and a Startup listing, which is better than 'msconfig' that comes with windows.
4) Panda Cloud Antivirus (Free) Panda Cloud Antivirus will check your system for viruses on it's own and will update and check any viruses with the Pandas servers in the cloud, automatically.
Also, a better disk defragmenter:
5) Auslogics Disk Defrag.
The first three need to be updated manually, in the free version, so be aware of the check boxes, and settings that try to get you to enable or start the 'FREE' Trial on these. Any of these programs that you are unsure of, can be removed, it's your call. But #'s 1,2 and 4, would be the minimum you need for protecting your system, along with keeping an eye on what you click, where you go, and paying very close attention to the way your system responds to your mouse clicks online, and be aware of what causes popups on your PC. Google is your friend.
I do them one at a time, or all at once, but I DO do them religiously, as I am taking the responsibility of keeping my system clean and efficient, to save money.
I hope this helps.
Posted on Aug 16, 2014
Can system mechanic coexist with norton security suite
Hi Jim,
Norton Security Suite Takes Lots of Space and Slow Down The System if you are using old version of norton security suite and please disable the background acitivities of norton its slow down the system takes the CPU Consumptions Power & yes System Mechanic Coexist with the norton security suite only if you disable the background processes.
Thanks & Regards
Bheshaj
Apr 19, 2013 | Iolo Technologies System Mechanic: Windows
I want windows to take over restore points instead of this norton goback 4.0
Norton will slow your computer up.
You should always remove and uninstall programs from your PC that you are not using. It could be beneficial to your computer's productivity and functioning to free up space. You run the risk of running out of space on your computer if you add too many programs without uninstalling some. It is a relatively easy process, but you should be sure you are not removing a program that is necessary to the operation of your computer.
Click "Start" and select "Programs." Click "Control Panel" and "Programs" and "Programs and Features." Browse the list of programs on your computer and select one that you want to remove. Click "Uninstall." You may be prompted for permission from the administrator to remove the program. Enter the administrator password or confirmation if necessary. Check the properties of the program if it is not listed in "Programs." You can do this by right-clicking on the program desktop icon and selecting "Properties." Check to see if the program is compatible with the version of Windows that you are using. Click "Start" and "Run," to manually remove the programs if the uninstall option does not completely uninstall the program. Type "Regedt32" in the box and click "OK." Locate the "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall" registry key and click "Export" under the "File" tab. Click "Desktop" on the "Export Registry File" dialog box. Type "Uninstall" in the "File Name" box and select "Save." The left panel of the Registry Editor will display the programs that are currently installed. Right-click the key in the left panel of the Registry Editor window. Click "Delete." Click "Yes" when you are asked to confirm deletion of the program. Click the "File" menu and select "Exit." This will exit the Registry Editor. Click "Start" and "Control Panel" and click "Add or Remove Programs." Confirm that the program is no longer listed here.
Hope this helps and you are finally rid of norton.
If you need more help with this post a reply.
Jan 05, 2013 | Symantec Norton GoBack 4.0 for PC
What the disadvantages of norton antivirus and what are the performance norton antivirus
Norton may slow down the performance of your computer,and it is a paid software what i think is instead of going with this you can download any of these free software (avg,avast or avaira) they all are free for one year and do the same thing what norton does without slowing down your computer.
Mar 03, 2010 | Dell Computers & Internet
We have recently upgraded our Norton 360 - it
I wouldn't recommend installing McAfee as this can also slow down machines. Norton is notorious for this. Download AVG free Anti-Virus or Avast Anti-Virus & a firewall such as Zonealarm. Anti-spyware software is also a good idea. Spybot Search & Destroy & Adaware are good. If the computer is in a corporate environment you must purchase the software as the free licence only covers home use. Uninstall Norton when you have downloaded the programs & before you attempt to install the new programs.
Oct 21, 2009 | 2wire Computers & Internet
Do I need a Norton-type security for my laptop, or is AVG sufficient ?
AVG is more than sufficient for a home computer.
Norton takes quite a lot of system resources and slows computers down dramatically. AVG on the other hand uses 2/3rds less resources than Norton and is just as good.
Reagrds.
Sep 14, 2009 | Acer Aspire 3000 Notebook
It says there is another norten product on my computer.
  • remove norton 360 product from computer
  • remove all other norton product from computer (two programs to be removed)
  • set a restore point
  • get the computer functioning offline
  • attempt norton 360 install
Sep 14, 2009 | Symantec Norton 360 Version 3.0 Full...
Norton Internet Security 2009 Causes Blue Screen of Death.
Hi there
Thats Norton for you! this is a very heavy and memory hungry program, it takes control of your computer and if you have not got enough system or virtual memory it will cause the pc all kinds of problems. To fix this either upgrade the system memory or don't use Norton, use AVG free instead, its a lighter program and lets you have some speed back over the internet.
good luck and thanks for using Fixya!!
Feb 11, 2009 | Symantec Norton Internet Security 2009
Removing norton ghost before reinstalling
If you tried removing Ghost yourself by deleting foulder or files then it will not appear in the add/remove list. Try reinstalling it and then using removal tool. Make sure you have correct one for version and your OS. My advice is stay away from Norton products, they severely slow down performance and hinder daily activities. There are free tools online that work much better.
Dec 30, 2008 | Symantec Norton Ghost 14.0: Windows
Trying to reinstall norton ghost v14
you need to remove Norton with Nortons own removal tools. Add/remove program not the same thing as it leaves stuff in the registry. Go to norton.com and get removal tool..Run it, then try the re-install.
Dec 27, 2008 | Symantec Norton Ghost 14.0: Windows
Dell Dimension 8200 PC Desktop Logo
29 people viewed this question
Alun Cox
