Question about Canon PowerShot A430 Digital Camera
Can't install camera
I have a Canon Powershot A430 camera. I attached the camera to the computer, but I can't get the computer to recognize it. Canon isn't even listed as a manufacturer on the camera installation wizard.
Every time I attached the camera in the past, the magical computer gnomes immediately got to work and talked me through all the idiot-proof steps. :) It is possible that Windows XP was installed on this computer since the last time I used the camera.
Thank you!
  • kakima Jul 11, 2010
    Have you considered NOT connecting the camera to the computer?
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive.
    Brigadier General:
  • 11,967 Answers
End your troubles by getting a card reader...you can thank me later.
Posted on Jul 11, 2010
Just installed a new memory card in my powershot A430 and the camera says memory card error, card is locked. how do I unlock?
What type and size memory card? The A430 works with SD cards. It won't work with SDHC cards.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 28, 2012 | Canon PowerShot A430 Digital Camera
I am having problems downloading or transferring pictures from my Powershot A430 to my computer.
Having gone over two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
Feb 03, 2011 | Canon PowerShot A430 Digital Camera
I`ve bought a 4GB memory SDHC memory card to my Canon powershot A 430 camera, and when i put it in my camera - it says memory card error. I tried to unlock it by the small button, but didin`t help. What...
The Canon A430 uses MMC and SD cards. While SDHC cards will fit into the slot they are electronically incompatible and will not work. You need to use SD cards, 2GB and smaller.
Dec 24, 2010 | Canon PowerShot A430 Digital Camera
Horizontal lines in both my LCD screen and when I download to the computer of my Canon Powershot A430---help I've tried everything?
There is a CCD sensor mechanism problem. Go to a specialist to fix it. Is a very complicated procedure and you cant fix it at home.This is caused by the sand and dust particles and many Canon A 430 cameras have this problem.
May 16, 2010 | Canon PowerShot A430 Digital Camera
Trying to download my pictures from Canon Powershot A430 onto my new laptop Windows 7. Downloaded the disk and now trying without success to download my pictures onto the computer. Help??
Supported windows Operating system Windows 98 Second edition(SE)
Windows Me
Windows 2000 Service pack 4
Windows XP SP 1 and SP 2 Canon PowerShot A430 has no update about the new driver software for windows 7 Try doing this direct transfer in your computer 1. Connect the camera to your computer using the supplied USB cable of your camera. 2. Set the mode dial to (playback) and turn on the power.
The camera and computer will be able to communicate. 3. If there is no pop up window that has Canon CameraWindow, Click the [Start] menu and select [all Programs] or [Programs]. followed by [Canon Utilities], [Camera Window], [PowerShot-IXY-IXUS-DV 6] and [CameraWindow] 4. Download the images.
* Download the images using the camera or the computer.
* By default, the downloaded images are saved into the [My Pictures] folder. ** If the above process does not work you can just use the memory card of your camera and connect that on your laptop. (some laptop has built in card reader) The memory card works like a flash drive and you can just transfer files like transferring from one folder to another. ** Issue on the operating system compatibility.
Apr 14, 2010 | Canon PowerShot A430 Digital Camera
Overexposure
The A430 is prone to fatigue failure of a flex cable internal to the camera that causes these symptoms. Please see this other Fixya article.
Apr 08, 2010 | Canon PowerShot A430 Digital Camera
I need driver canon powershoot a430 for windows7
windows 7 is a new os hence all the drivers are not available yet. so install the vista driver in the older version compatibility mode which can be done by opening control panel of your computer then go for the options of progams and features and then install the older version program. then it will work
Jan 18, 2010 | Canon PowerShot A430 Digital Camera
Canon A430 - horizontal lines
Tend to agree with you that it's a common design problem for the A430, but it's a very different issue than CCD failure mentioned in you referenced article.
Please see this Fixya post instead of the one that you mention above. Unfortunately, Canon has yet to officially recognize this A430 specific problem. But if you reference this Fixya post, (include a link), when contacting Canon (if in US, email is CareCenter@cits.canon.com. You'll have to research www.canon.com to find an equivalent UK email contact), who knows you might get lucky
Nov 12, 2009 | Canon PowerShot A430 Digital Camera
Can't find a Twain driver for xp for canon powershot a430 camera
Forget all that...use a card reader to download your pics.
Nov 10, 2009 | Canon PowerShot A430 Digital Camera
Canon Powershot A430 - can i charge batteries through AC
The A430 is a camera, not a battery charger. If you want to use rechargeable batteries then you must use a separate charger. Battery chargers should be available at just about any department, electronics, or office-supply store.
Apr 30, 2009 | Canon PowerShot A430 Digital Camera
Canon PowerShot A430 Digital Camera Logo
88 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
