Question about Onkyo DV-CP704 DVD Player
I have an HDMI Out Error message displayed on DVD
I have an onkyo 6-disc DVD player with an "HDMI Out", HDMI Error" message flashing on display. went back over all the settings, resolution and replaced cable. Do not recall if I have a DV-CP704 or 706 model.
Nothing wrong with ports on AV reciever. Plugged in another DVD player to check. What could be the problem?
ChadL777
  • 69 Answers
SOURCE: Shuts off after a loud sound
Hmmm...not sure but sounds like the vibration from the loud sound is causing the disk to jump. Not sure why that would power it off, but I think your thought to junk it sounds reasonable.
Posted on Dec 24, 2007
SOURCE: Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Posted on Feb 14, 2009
petraman7
  • 1175 Answers
SOURCE: my onkyo dv-cp704 powers on but frrezes after
HI...
A problem like that will need tech service.
Check the onkyo consumer site for service people
Posted on Mar 03, 2009
rulds2008
  • 3866 Answers
SOURCE: Onkyo DV-SP405 DVD player says no disc
This woud be due to two things
1. laser
2. servo motor not spinning to the correct speeds i,e Bad motor
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Jun 11, 2009
SOURCE: Onkyo DV-CP704 will not turn on.
Has Onkyo provided a recall for this. Owned lots of Onkyo products. Always great, but experiencing the same problem about a year after ownership. Very frustrating.
Posted on May 15, 2010
Emerson LCD TV Model LD190EM1 Sony Blu-Ray Disc Player, Model BDP-S3100, The TV screen gives an error reading "Format not supported" when I connected it using either HDMI connection.
This HDTV is rated display signals up to and including 720P resolution according to the spec linked below. If you are outputting a 1080i or 1080P signal from your BD Player, this could be the cause for the error message. Many HDTVs will accept signals higher than they can display - and simply down-rez to the highest resolution that they can display.
Connect the BD Player to a device that can display the signal. Enter the player's setting and change the output to 720P. Shut it off / disconnect cables as needed and reconnect it to the Emerson HDTV and see if it will display properly.
If it does, you're all done! if it doesn't - there's something else going on that isn't readily apparent to me. Good luck!
Emerson LD190EM1 Specs CNET
Mar 03, 2015 | Emerson LD190EM1 19 in. LCD TV/DVD Combo
The display will not light up
When CD exchanger is turned on, it states searching for disc,
then defaults to an error message. Door also not opening all they way since this problem started.
Jul 28, 2013 | Onkyo DX-C390 6-Disc CD Changer
Error message (protect) cd plays then goes silent then plays again. have cleaned laser several times with cd cleaner disk.
Dirty lasers don't cause "protection" problems. Are you sure thay message is displayed on the CD player? That word is nowhere in its manual.
May 22, 2011 | Onkyo DX-C390 6-Disc CD Changer
Displaying an error message "mecha
http://www.fixya.com/support/t4093524-onkyo_dvd_changer_display_reads_mecha
http://www.fixya.com/support/t1119443-onkyo_dv0_cp702_error_mecha_err
These may help you.
May 07, 2011 | Onkyo DV-CP702 DVD Player
The HDMI is not outputting to my display. I have 3 inputs and none of them work. However they did work for about 2 weeks with no problem. I can take the input directly to the display and they work...
Measure all hdmi inputs and output HPD Voltage by a needle probe.
Steps:
(1)unplug the amp.
(2)open the cover.
(3)connect a blu ray player to hdmi input & a mon to output, otherwise no 5V.
(4)negative probe connected to the large heat sink with large power transistors mounted by a crocodile clip.
(5)postive probe to right hand side last pin called hot plug detect, HPD.
(6)If it has 5V, hdmi board is OK. Check HDMI cables(7)If no 5V, check power to this board. Go to you tube:How to fix an Onkyo receiver - TX-SR606 . All large capacitors next to SMPS IC are replaced.
(8) If not OK, replace Q 8595-Q8597.
(9)If not OK, replace Q8501,sil9135.(Onkyo won't help you to replace this HDMI decoding Chip. A HDMI board replacement instead, the company policy.)
Oct 02, 2017 | Onkyo TX-SR605 Receiver
Have hdcp error flashing on front display
HDCP is copyright protection for HDMI ensuring that you can't copy the protected material.
Did you connect some new DVD player or new TV to the receiver? However the error should clear once you disconnect everything from HDMI. If not, try to restore the receiver to factory defaults.
Apr 11, 2009 | Yamaha RX-V461 AV Receiver
HDMI connection with Panasonic DMP-BD35K Blu-Ray Disc Player
Try hooking the Panasonic up straight to the tv without going through the receiver. If it displays a picture its obviously not the blu-ray player. May also be a problem with the HDMI cable itself. Hope this helps.
Jan 04, 2009 | Onkyo TX-SR506 Receiver
HDMI SOUND
True HD can only work with HDMI interface and is only available on some newer HD DVDs. Check the DVD to see if the True HD encoding is available.
Feb 11, 2008 | Onkyo TX-SR605 Receiver
Onkyo DV-CP704 DVD Player Logo
67 people viewed this question
Top Onkyo Televison & Video Experts
Clive
Clive
Are you an Onkyo Televison and Video Expert? Answer questions, earn points and help others
