Question about LG Prada KE850 Cellular Phone
KE850CP40-7-V10i-JAN-19-2008 solve Deat Problem. But how to use it?
I downloaded KE850CP40-7-V10i-JAN-19-2008 from http://rapidshare.com/files/98211539/KE850CP40-7-V10i-JAN-19-2008.rar.html I heard it can solve the Date Problem by flash or install it. But I don't know how to flash this Phone LG Prada. Anyone have success? Anyone can help me? Thx a bunch~~
  • Bob Cheney Apr 23, 2008
    I have the same problem for updating the software. Another reason for the update is my hope of resolving the following Snyc problem:
    With the Sync connection, I'm able to view the SIM contacts on the right panel of LG Sync and upload them to PC. However, strangely I cannot see my contacts in Phone Memory when this pull-down is selected. In fact, an error message "unknown error" appears after the "connect" botton (on the LG Sync page) is clicked and connection is established. I'm using Windows Vista. Any help?
  • Anonymous May 14, 2008
    I cant sync my phone to my pc... whenever I try to connect it it says "unknown error" and the USB CABLE otion appears gray... any ideas why?
  • 3 Answers
To enable the connection between the pc software and your phone, you need to first go to settings on the KE850, Connectivity (scroll down to see this option), USB Connection - and change this setting to Data Service. For simple upload of files, eg. mp3 or jpg, set this option to mass storage.
Posted on May 23, 2008
APC UPS is totely deat. No respone on back battery or main Please tell me detail thank
You have to take apart the UPS. Inside you will find a battery. On the battery you will find the make and model of the battery. Buy a new battery install it. Plug in UPS and turn it on.
Sep 19, 2011 | APC (BE500U-WEB) (BE500UWEB) UPS System
I have a PZ6114 vivotek cam and has a flash corrupt problem, the cam turns on, get ip but never keeps the config data, also report a big config.ini file ftp> dir 200 PORT command successful 150...
What I could recon from your question is that your webcam driver is not installed in your PC.
Please be informed that any Driver software depends upon the hardware make and Operating System. So, you need to know all these information's to do get going.
Please find the Driver software's of your webcam inside the installation disk provided with the System at the time of purchase. In case if you do not posses the same then you need to download the driver software from the web. As you have not mentioned your \ Operating System you are using, I am unable to give you the direct download link. However you can download the same by visiting the website of the company that manufactured the Webcam.
http://www.vivotek.com/support/faq.php
Even here you need to be careful to download the correct software for your PC. You need to be exact with the Webcam Model number and the OS that you are using.
After you have downloaded the driver, to install just plug in the webcam on to your PC and then Double click on the driver setup.exe file and go on clicking 'Next' until you get the 'Finish' option and restart the PC.
Jul 09, 2011 | Vivotek FD6112V Webcam
How can i change my LG Phone default saving memory, my phone memory is full, i want change to full details in phone to memory card plese solve this problem my phone model GT 505 touch screen
The phone must have hung up because there are errors in the software. So to reset remove the battery and the memory card from the phone. Using your PC , scan the memory card for any corrupt files or media files with virus- it is possible when they are downloaded from unsafe sites. If so remove or format the card. Now replace the card and battery and switch on the phone. If the phone hangs up then it is confirmed that the software is corrupt and will need a reinstallation.
Feb 23, 2011 | LG GT505 Cell Phone
Please describe your how to fix Rocketdock had trouble loading your icon last time it was run problem:
"RocketDock had a problem loading your icons. Would you like RocketDock to load the default icons?" Issue is finally solved. Go to my site at : http://de.amberwork.com and download w7rdock from the Apps-section. That will do the trick. Greetings, Jan
Oct 23, 2010 | Computers & Internet
I have misplaced Philips DVDR5570H/05 - 250GB Hard Disk/DVD manual. Can you let me have a copy please?. Regards. Jan Carling
You can download and print the instruction manual in PDF format by clicking this link.
Please note: Adobe PDF Reader is required to view this manual. Download the latest version of Adobe Reader.
Hope this solves your problem. Thanks for using FixYa.
Sep 08, 2010 | Televison & Video
EasyCap Capture usb2.0 Viceo Adapter with Audio Model DC60
Do NOT use autoinstall.
Just plug your adapter in one of the USB-ports and wait for the OS to want to install it, then select your drivers manually.
Worked for me after finding the solution on another forum.
Sep 19, 2008 | Ulead Videostudio 8 for PC
N 70 set deat
there may be some parts there that been misplaced
Sep 03, 2008 | Nokia N70 Cellular Phone
Installing the downloads in xp home edition
The only thing that comes to mind is you have some antiviirus/firewall software that will not allow it to load.
Depending on what type is is it can be blocking it without telling you or allowing you to pass the program.
This is a common issue with this type of software.
you can disable it but how depends on what it is.
if you can disable it then run the update manually.
start/windows update
Jan 29, 2008 | Microsoft Windows XP Home Edition
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Solve GSM CMS Errors......
I'm using also smslib and nokia 6020 phone for sending and receiving SMS, but i've some trouble with reading messages, would you please tell me the configuration for the modem, i used this one :
ModemGateway gateway = new ModemGateway("modem.com4", "COM4", 4800, "Nokia", "Nokia 6020", srv.getLogger());
Oct 01, 2007 | Microsoft Office Outlook 2003 for PC
LG Prada KE850 Cellular Phone Logo
269 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
