Question about Linksys Wireless-G WRT54G Router
I do not know my password to unlock my wireless
I do not know my password to unlock my LINKSYS-G wireless router so I can use my new Iphone in my house. Can you help?
  • nancie1186 Jul 11, 2010
    have you changed the password when you set this up? If not you can access by using the default password. When you connect, leave user name blank and for password type admin; this is default settings and will only work if you have NOT changed these settings under admin
sandrew
  • 2961 Answers
SOURCE: Password protection for my linksys wireless router
you need to get into the routers settings and look in the menu for security and select atleast WEP security and either you type a password in to reveal a 8 digit code or type in your own mixture of numbers and letters, which will then have to be entered into each pc when they try to connect. You can also look in the SSID and remove the name or dissable SSID so as your network will not appear on anybody elses wireless searches.
Posted on Oct 09, 2007
ymeletis
  • 55 Answers
SOURCE: my motorola surfboard modem will not connect to my
Try resseting your router and then taking off the security...And try to join...If you can't , probably this stuff is junk.
Posted on Jun 23, 2009
mjhedger
  • 25 Answers
SOURCE: I don't know the password of my Linksys router.
Hold teh reset button in the back for 30 seconds and it'll reset the router to factory defaults. From there, open a browser and type the address 192.168.1.1. Username is blank and password is "admin". If that doesn't work, many of the newer linksys routers have "admin" as both the username and the password.
Posted on Aug 26, 2009
  • 59 Answers
SOURCE: i have a linksys wrt310N router with wap2
u can add the network manually ...
In Intel pro set u can go to profile and do the things there ...
Posted on Sep 25, 2009
  • 252 Answers
SOURCE: How to configure Huwaei MT880 with linksys WRT120N router?
Try these steps:
  1. Shut down the DSL/Cable modem
  1. Power up the router (no cables just yet).
  1. Power up the modem and wait for the appropriate lights (power, ethernet, and activity – something along these lines)
  1. Connect the modem and router with an ethernet cable (if there is a WAN port on the router make sure to put the cable in this port).
  1. Connect Port 1 on the router to the network card on the computer using an ethernet cable and check to see there is a light at the correct port.
  1. Open a web browser, such as Internet Explorer or Firefox. Input your routers id (usually an IP address or an URL) in the browsers address bar and press Enter. The address bar is where you would normally see, for example, http://www.google.ca If you don't know the IP address (such as 192.168.1.1) or the URL, try going to the manufacturers web site and downloading a manual.
  1. Now, a window will open asking for a user name and password (these are given to you in the instructions of the router). For example, Dlink sets up some of their routers as, username: admin and leave the password field blank then press OK.
  1. Now you are in the configuration page of your router (wireless most probably). Here you can set the encryption, new passwords etc… If your not comfortable doing these on your own most routers have a wizard that you can follow.
  1. If everything goes alright and the settings are successful you can now try the wireless connection. Go to a machine with a wireless card, right
  1. At the computer with the wireless connection, make sure the connection is on You might be trying to connect to the network by using either the application that came with the router or windows wireless configuration. Right click the icon in the system tray and “view available networks”. If it comes up in a window saying “Windows is not setup for wireless networks” then you must right click on the correct icon in the tray.
  2. Now, in the list of available networks, click on the name of your network Click on "connect" and it should ask for your security id (the encryption code). Put in the code (usually twice) and click connect or OK. It should now be "acquiring anip address" and in a few minutes it should be connected.
Posted on Nov 07, 2009
How do I get my iPhone to recognize my new Linksys router.
passwords are case sensitive, so the problem is possibly just that you have capitals in the password and these are not specifies when entering the password into the iPhone
Jan 28, 2016 | Apple iPhone 5
How do I find a forgotten password that will allow me to connect my new iPhone 5C to my WiFi
Hi, just log into your router (or run the router setup disk) from a PC connected to one of the router ports on the back. You can find the password on the Wireless Tab and within that page the Wireless Security subtab. If you don't know how to log into your router and/or have lost the setup disk, you may have to reset it and use the default (none) security.
Jun 11, 2014 | Cisco Linksys E1000 WirelessN Broadband...
I am trying to connect my iPhone 5 S to my wireless network and have forgotten my password. HELP. To connect to wi-fi I need a password and can not remember the password as this router was set up years ago
Firstly log into your router from your computer. If you don't know the username and password, try the default one which is Username: admin Password: Admin. Check under Wireless setting and you will see the current password listed there. You can change it to a new one if required. Just remember to save after you've done any changes.
Jun 11, 2014 | Cisco Linksys E2000 Advanced WirelessN...
Connecting an IP5 to a wrt54gp2
Change the wireless key encryption level to wpa atleast. get a any new wireless key.then try to connect. remember by making any changes on the router on the wireless part of the router it will disconnect all the devices or computers connected wireless. you have to connect them with new wireless key or the password.
Oct 21, 2012 | Linksys WRT54GP2-NA Wireless Router...
Trying to connect iphone to wrt160n router but cant
Dear friend fist turn on your iPhone wifi and when your router is find in your iPhone select the router name and enter your password same password use when you conncet Internet with your laptop ....,ok
Mar 01, 2011 | Linksys WRT160N Wireless Router
I cannot connect my Apple iPhone with my Linksys router. Please help.
hi
have WPA2 security enabled. When I type my password the iphone says "unable to connect." I just disabled the security on my router and was able to connect. How can I connect my iphone with the security enabled???
Nov 11, 2010 | Linksys WRT160N Wireless Router
I have a WRT54G -V5 which works great with all my home PC's. Have purchased itouch and it does see my Linksys device and I do know the password but when I put that in itouch it does not connect. The...
You are looking for a Wireless Security key, this is not the Linksys password for the admin portion, look on the bottom it maybe there if not changed. Else goto the router home page and check it there something like 192.168.0.1. or 192.168.1.1 etc etc
Sep 05, 2010 | Linksys WRT54G Wireless-G Broadband Router...
Forgot my password
please follow the following steps:
1) Click Start > run > cmd > ipconfig (enter) and note down the Deafult gateway should be some numbers like 192.168.1.1 etc 2) Open internet explorer and type those numbers in the address bar and press enter 3) now you will get the router page, login with following details username: admin password: admin or password 4) and in wireless settings you can find the password (WEP) to connect the IPhone
Jan 27, 2009 | Linksys Wireless-G Broadband Router
I've forgotten my password
DOH! Sorry to hear that! Unless you can remember it, you'll need to reset your router to the factory defaults, which will unlock your password. Your router should have a tiny button on it you'd typically use a ball point pen to depress, which resets it to factory defaults.
Some routers, like linksys, don't have an actual user name so be sure you're leaving that blank. If it is a linksys, the default username is blank, and the password is admin. You'll want to change that quickly and I recommend writing your password in sharpie under your router if you're the forgetful type.
Dec 18, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
191 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
