Question about Alpine GPS
I have the only screen model no .AJ2070D 12v d.c.negative gnd (navigation screen for jaguar xk8 2003)i would like to know its wiring diagram and which gps reciver compatable with it and how to connect it to dvd, rear camera
  • Holger Galuschka
    Holger Galuschka Mar 16, 2014
    did you get it meanwhile? I'd like to replace this too...
  • Alpine Master
  • 6,993 Answers
please I don't really understand the question, can you rephrase it?
Bye for now.
Posted on Jul 21, 2010
Power supply to mother board connection manual for 600watt diablotek model number (psle600)
if it's a PC psu
The connectors voltage are indicated by colors
yellow is 12V
red is 5V
orange is 3.3V
black is 0V(GND)
green is PSon
purple is 5Vsb
blue is -12V
white is -5V(optional)
gray is PWRGOOD/PWROK
Nov 30, 2012 | Diablotek Computers & Internet
We have a DEH-6 pioneer radio that we are trying to install in the 1994 dodge caravan.We cannot find where to hook the white wire from the radio. when you turn the ignition on the radio lights up but the...
Most aftermarket cd players have the following wiring diagrams
(+)Red..............12v ignition
(+)Yellow...........12v battery (Memory) Constant Hot
(-)Black............12v Ground
(+)Blue.............12v Power antenna
(+)Blue/white.......12v Remote turn on
Orange...........Dashlight/dimmer
Orange/white.....Dashlight/dimmer
Orange/black.....Dashlight/dimmer
(+)White............Front left positive
(-)White/black......Front left negative
(+)Grey.............Front right positive
(-)Grey/black.......Front right negative
(+)Green............Rear left positive
(-)Green/black......Rear left negative
(+)Purple...........Rear right positive
(-)Purple/black.....Rear right negative
Hope this helps.
May 29, 2011 | Pioneer DEH-P690UB CD Player
Need wiring diagram for pioneer deh p2900mp wiring diagram
Hope this helps.
Feb 23, 2011 | Car Audio & Video
I need to know what does the colors on the harness to the sony radio mean?
Hope this is what you were looking for.
Nov 07, 2010 | Car Audio & Video
Wireing diagram
I hope this is what you were looking for.
Nov 07, 2010 | Clarion Sirius DXZ-535 CD Player
Sony xplod drive-s cdx-gt31w wiring diagram
Nov 07, 2010 | Sony Car Audio & Video
I need a diagram showing me how to wire a 3.5mm mini jack (input)? Its for aPC Audio Cable.... seems there are no experts who can help as its not in the "products".... plz forward this to someone who might...
A any jack/plug it is always wired the same, there are only 2 wires, + Plus, and - Negative, ETH, GND. The Minus, GND, ETH, always, logically, goes to the or Negative or "Case" ETH, Gnd, all mean the same. Now the + Positive is always Plus,. If the connection is for a Coaxial Cable then, the inner core is Plus +, and the Shield is always - Negative, Gnd, Earth. All Jacks and Plugs wire the same. With a Phono MONO Phono Jack, the "Bulb End" is always Positive, the Case or Outer is - Negative. IF it is a Stereo Plug/Jack there is simply, Two Plus wires, and two - Negative, Eth Wires, these Two, Negatives, Earths or Contact together, and go to the Outer Connection or Negative. The Two + Plus Wires go, One to each tip connection, of the Two Positive connections, that go to the end, Bulb Tip A & Tip B, of the Stereo Jack./Plug
For Power Connections the same is generally true, the Centre Conductor is usually Positive, while the other one is - negative, case, eth gnd.
Feb 18, 2010 | Polk Audio IBM PC 300PL Mini Tower...
Wiring diagram for sony xplod amp and how to bridge one
if you have the model number handy i can tell you
but most sonys are marked like this ..
+12v goes directly to the + termanl on the battry
GND goes to a solid metal object on the car (ground)
REM remote turnon goes to the remote turn on from your headunit
unbridged speaker outputs
+L positve left speaker
-L negative left speaker
+R positive right speaker
-R negative right speaker
ok to bridge a amp (must be capabul of doing so) look for a mono switch and set to mono ..
then take the +L channel put it to your subs + and take the -R channel and put it to the - of your sub
also set the cross over switch to LPF if your running bridged for a sub
if that is a bit hard to understand msg back with the model number of the amp and i can get u the orignal manual for the wireing diagram
hope that helps
Jan 26, 2010 | Sony Z2X-1200 SPL Car Amplifier (1200...
I need installation instructions for a MTX thunder 280
BATT = 12v positve constant
GND = 12v negative or ground
REM. = 12v positive switched or remote wire.
The remote wire is most commonly found on aftermarket CD players. It's typically in the main wire harness. The most common color of this wire is blue with a white stripe.
Jan 20, 2009 | MTX Thunder 2-Channel Amplifier 282 Car...
Wire diagram
guynoir..with alpine your other set of speakers would most likely run through an amp ,which may connect up by the rca leads or a din plug , this is where your fader comes in to play.i was an agent for alpine
Feb 07, 2008 | Car Audio & Video
GPS Logo
100 people viewed this question
Top Alpine GPS Experts
Shehu Pro
Shehu Pro
richie46
Are you an Alpine GPS Expert? Answer questions, earn points and help others
