Question about Garmin StreetPilot C330 GPS Receiver
C330 will not power up when plugged into power receptacle in car
C330 unti will not power-up when plugged into power receptacle in car
  • 4 Answers
First, check the car's power receptacle by plugging in another device that definitely works (or take your gps to another car). Cars generally have a fuse associated with the receptacle that can blow. The second most likely problem is that the internal battery inside the c330 has died. This is especially likely if the unit is old (more than 1 year) and if you live in a climate with extreme heat or cold (which reduces battery life). This video shows how to replace the battery:
The company that produced the video sells a kit which includes the battery and tools necessary to replace the battery yourself. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+STREETPILOT+C330&Show=ExtInfo I swapped the battery of my brother's dying GPS using the aforementioned kit and all went well. His Garmin is back up and running smoothly.
Hope this helps.
Posted on Jul 13, 2010
  • 63 Answers
In the tip of the unit there is a glass fuse that can be replaced. Please check that first. Next thing to check is the cable. If you have a multimeter put it in the continuity measuring setting. Then measure from one end of the cable to the other to make sure there is no break in the line. If you need a replacement cable I suggest GPSCity ( http://www.gpscity.ca )
Posted on Jul 12, 2010
Black Screen to no power
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 12, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin died and will not turn on
My streetpilot c330 won"t shut off.
IT'S CALLED A FROZEN SCREEN...
2 OPTIONS
ONE, RESET IT !!! (See resetting instructions below)
TWO, let the battery die out!
Frozen screen screen is frozen and wont power off
2 OPTIONS
Feb 28, 2009 | Garmin StreetPilot C330 GPS Receiver
Gps will does not work
Feb 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Street pilot c330
It took a nap...
Feb 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Power dors not transfer thru the connection between the wire and unit on my c330 , it appears that a little gold wire has broken in the rubber mount.
It took a nap...
Feb 18, 2009 | Garmin StreetPilot C330 GPS Receiver
C330 wont turn on or power up
It took a nap...
Jan 22, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin c 340 froze- what do I do
This solution is for c330 but it should work the same...
It took a nap...
Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Garmin freezes
2 OPTIONS
Jun 13, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
398 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
