Question about Sony Audio Players & Recorders
Receiver blown? Red power light, but no didgital diplay
I have a Sony receiver STR-D985that is about 15 years old. My main receiver for my sound system, (6 sets of speakers, with a Niles HPS speaker selector connected to them). Worked great for a few days, then I inadvertantly deselected the ''protection'' button on the speaker selector, meaning I was powering probably 2 ohms... and the receiver got really hot and turned off. I waited an hour, and tried turning it back on. The red ''power'' lightcomes on, but no sound, and the digital display is completely blank. Is it possible there is afuse in the unit that blew, or it is unfixable? Which not incidently, is EXACTLY what the JVC receiver that WAS powering the system did.. got really hot, then no sound. When you turn the unit on, you get the red power light, but no digital display.
  • 2,359 Answers
As a quick test,plug in a 1/4" headphones and tune for tuner radio signal.
I hope you can tune in on a station and check for sound quality.
As long as you are able to tune in on a station and able to listen it will be fine.
The power amp for your Sony STR-D985 is a MOSFET amp.
I would open up the casing and re-grease (White Lithium) the heatsink contact grease first.
Disconnect the Niles speak selector and connect the unit with direct speakers connection.
Please let me know after you do a test with headphone and direct speaker connection..
Posted on Jul 11, 2010
My Sony receiver amplifier model number Str-de315 has just stopped working clicks on 2 lights come on but nothing else k
no front panel display means one of twot hings: either the power transformer is blown, or the main power fuse. If the main power fuse is blown, then there are likely to be shorted output transistors that will need to be replaced.
May 03, 2014 | Audio Players & Recorders
MY RECEIVER JUST CLICKS BUT DONT TURN ON
Either the main power fuse is blown, or the power transformer is bad. If the fuse is blown, then there are probably shorted output transistors in the amp section that need to get replaced.
Sep 22, 2013 | Sony Str-k740p Radio Receiver
Speaker Imedance Matching - Sony STR DE 997 receiver with 120Watts - 8 ohms output with Benz 6 ohms..Tower Speakers
hi pawanh75,
thanks in advance for a very informative setup that you have.
Here are some of possible mods , only if you like and can DIY
( or have someone to help you )
• Using a 6 ohms impedance for an 8 ohm impedance amp clearly
denotes that it heats up the output stages.
(please forgive my very technical words)
• One way to lessen the heat is to install a blower .
Use a 220V blower on top of the receiver.
( air should be in going up direction ).
• Before I proceed further please indicate if having the speaker
connected and having a zero volume , and just letting the receiver
in an "On" state deliverately produce heat on the receiver, or just
when the volume is at medium to high level.
If it s running hot at zero level with speaker , please post.
If it is running hot even without speaker, post also
• It may also helps , if you have a powered subwoofer ( for the low's),
and set settings on your receiver to "small"
Let me know what you find to help you further.
Sep 11, 2012 | Sony STR-DE997 7.1 Channels Receiver
No rear speakers coming out oy my system.reciever sony STR-DG800 and bose acoustimass 10 speakers
The rear left and right channel has a audio output ic problem, first check rear speaker wires for shorts, if okay! the system will need to be assessed for repair costs.
Apr 07, 2012 | Sony STR-DG800 Receiver
I have an Onkyo TXNR609 home theater receiver hooked up to a 6 speaker surround sound setup in the living room. I also have 2 speaker pairs outside - one on the downstairs patio and one upstairs. I was...
If you haven't done already, then verify that zone 2 works without the selector. If the speakers definitely work and the zone output definitely works then the speaker selector must be the culprit! It's pretty difficult to mess up the wiring with speakers, as even if polarity is reversed, you will still hear something.
Sep 23, 2011 | Niles SSVC2 Two Pair Speaker Selector...
Hi I purchased a sony av amplifier model STR-DB930 on e-bay a few months ago and I am using 3 ohm speakers from my old surround sound system. The output selector on the back of the unit is set to 4 ohms....
The lower number in Impedance specs is not a suggestion. It's a limit. 3 is not between 4 and 8.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DB930-Receivers-manual/id/387bh934/t/2/
If you don't want to buy new speakers, settle for safer low volume levels.
You're going to kill that receiver driving a 3-ohm load. HTS-style speakers aren't reliably re-deployable to other electronics. Perhaps, if you have 4 speakers and they're similar you could wire them in SERIES and present a 6-ohm load to each channel.
Re-engineering the speakers themselves is, well, don't do it. It isn't rocket science but it also isn
Feb 28, 2011 | Sony STR-DB930 Receiver
Sony receiver str-dg800 will not power on.
Unplug the unit from the wall and remove the outer case. At the rear of the main circuit board is a fuse. Check the fuse to see if its blown. If not, go to the transfomer at the front of the receiver and check the fuses at the transformer.
Aug 28, 2010 | Sony STR-DG800 Receiver
Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Feb 13, 2010 | Sony STR-DE445 Receiver
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
