Question about Canon Rebel XT / EOS 350D Digital Camera
This camera was working fine, no issues whatsoever, then it just stopped responding (as if the battery were flat). I've tried various batteries and a mains power cord and sadly it remains completely unresponsive. The mirror appears to be up (not in it's default position) which I'm sure is an associated or cause of the problem...?
    President:
  • 1,197 Answers
Camera power 'off'' - remove battery and clean the contacts (shiney metal strips) on the battery. Now remove lens and clean the lens contacts also. put a cap on the camera (no lens) Reinstall the charged battery and turn on the camera. It should start up. If so, turn it back off and reinstall the lens.
Also ensure the battery cover and CF card slot covers are both
closing and latching correctly The camera won't operate if it thinks
either cover is open.
Try taking the card out and switching on the camera.
One of the start up tasks is to check the card and if the card fails those checks, the camera won't start.
Especially if the last thing you had the camera do was a card operation.
The card is protected against the camera being switched off when being written to as the camera will finish before shutting down, but pulling the battery is a definite no-no.
As the manual says...
"Never do the following when the access lamp is lit or blinking. Such actions may destroy the image data. It may also damage the CF card or camera.
*Shaking or banging the camera around.
*Opening the CF slot cover.
*Removing the battery."
There are sensors on the battery and memory card doors. Make sure those doors are closed and the contacts are not corroded. If that's not the case it may be the card, or even the battery. If that's not the case then it will need to get looked at by Canon.
also try connecting the camera to a computer. Sometimes that can help.
Your camera should power on without a card in it, try that as well.
Neither is the lens required to power the camera, take it off too.
If all that fails, CPU board could be broke because of heavy lens on the camera and the mode dial is somewhat poorly placed. See if there's any play or movement in the dial that isn't normal. Wiggle it, turn to a different mode, press it down gently (don't cause more damage if that's what is wrong).
If all the above fails at this point it would be a better option to have it serviced.
Good luck with your Fix
Thank you for using Fixya
Posted on Jul 11, 2010
I cant charge my nikon coolpix s6150
Hi, that happened to mine too but I found out that there was nothing wrong with either the camera or the battery. Simply put it, the charger that came with the camera is not capable of charging the battery up after it has been totally drained. Thus, I bought a charger to charge my battery separately and now it works totally fine.
Dec 12, 2012 | Nikon COOLPIX L18 Digital Camera
Camileo P10 charging problem
I had the same problem with the P10 not charging via USB, I purchased mine second hand so it came with no charger. I assumed it would charge by the USB cable but it did not, the red light flashes but doesn't charge. Luckily I have an external battery charger for a different camera i got some years ago that takes a similar battery , the P10 battery didn't fit properly so I had to place it at a 45 degree angle into the charger making sure the outer contacts were lined up properly and taped it into place. After an hour it was fully charged and the camera is working fine. The charger is a 4.2 volt charger. New external chargers can be picked up on ebay cheaply
Jul 04, 2012 | Toshiba Camileo P10 Flash Media Camcorder
My dvd player is not responding to my remote RMT-D187A the dvd player is fine and will play dvd's but the it's not responding to the remote-I've changed the batteries....there is no way to...
To make sure the remote works or not. See if it blinks if you shoot the pointy end to a mobile phone in camera mode. If it's working fine there, some other issue. At least you know if it's a battery thing.
May 08, 2011 | Sony Televison & Video
Photosmart R727 charging blinks never stop, camera never responds
Remove the battery, connect the camera to the charger and try the camera. If it works, it means you need a new battery.
Jan 04, 2010 | HP Photosmart R707 Digital Camera
I am trying to charge the battery. The charger is flashing a red light and the battery won't seem to charge. Placed it in the camera just in case, and it won't turn on.
Well, with my Nikon, the light flashes to show the battery is charging. It stays on when it's charged. My battery and spare battery are 2 years old and working fine. I'd say wait till it stops flashing...hour or 2 in my case, though I never let them run down all the way.
Jun 28, 2009 | Cameras
Camera does not respond
I suggest you open the battery compartment and check the connections on the battery. It may be that they are a little dirty, preventing proper electrical connection, in which case you can clean them with a little cotton bud and perhaps some methylated spitits.
Mar 15, 2009 | Casio Exilim EX-Z50 Digital Camera
Aoutofocus stopped working
Start off with the simple things, does it work with another lens, is the AF/M switch in the correct postion for autofocus (AF), are the batteries good.
If all of the above are in order it maybe either the DC/DC converter on the bottom of the camera, this supplies power to various parts of the circuit. or it could be the motor drive transistors, these are located under the front cover and are located where you finger tips rest on the right hand side as you hold the camera.
Both these items are not really user changeable and I know the DC/DC units have not been available new for many years now.
I suggest you have a look for a friendly camera repair shop to pin point the exact cause.
You will have to keep in mind the age of the camera 23 years old parts are a big issue
Sep 06, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Canon Ixus 75 not charging
The camera was working fine 5 days ago. Yesterday when I tried to switch it on, I assumed that the battery was flat so I charged it but when fully charged the camera still won't switch on. i Please help!
Mar 24, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Camera no longer turns on.
Try polishing the battery contacts in the cover try ditt in the bottom of compartment with a cotton bud -or time for next camera
May 09, 2007 | Samsung Digimax 370 Digital Camera
Canon Rebel XT / EOS 350D Digital Camera Logo
59 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
