Question about Philips GoGear SA5285/37 Digital Media Player
Flash error on GOGEAR - Philips GoGear SA5285/37 Digital Media Player
  • 68 Answers
Update it firm ware
Posted on Jul 21, 2010
My phillip gogear SA 6025/97 mp4 player 2 GB can't start to open and it becomes flash ( appear phillip gogear and then stop and return it) when I join it to PC.
1st tanx 2 ur orgnal phlipis gogear company very very smart i love it ! my gogear vidio m3 is AC6025/97 so i missd orignal erphon zn i dont use 4 along but naw after 2years when i open my batry is not good and not long time use dot save poure pleas helpe me ytbarekdebebe@gmail.com or trughabesha@yahoo.com
Sep 24, 2012 | Philips GoGear SA6015 SA6025 SA6025/97...
It will not turn on or charge
Hi, the Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
1. Your GoGear may not respond to button presses from time to time. This is often caused by an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
If the GoGear freezes after uploading a file to the device or if one song or sound file freezes the device each time you play it, the file is likely corrupt and needs to be removed from the GoGear. Connect the GoGear to a computer and delete the file from the device.
GoGear Does Not Power On
2. Problems with powering up the GoGear are often the result of an exhausted battery. If you cannot power on the GoGear, charge the battery with the supplied charger.
In some instances there is an error with the device that is keeping it from powering on. Unlike the errors that freeze the device, errors that keep it from powering on cannot be cleared by pressing the "Reset" button. The errors need to be fixed by using the "Firmware Manager." The Firmware Manager is a computer program that restores your device to their factory conditions. You will be able to use your device again after restoring it to factory conditions, but you will lose all of the data on your GoGear.
To use the Firmware Manager, open the installation CD supplied with your GoGear and follow the onscreen instructions to install the Firmware Manager on your computer. Plug the GoGear into the computer and check that your computer is connected to the Internet. Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware or "Update" the firmware. Since you need to restore your device to working order, select the "Restore Firmware" option. Updating the firmware will not delete the files or errors that are causing the GoGear to malfunction.
Once the process is complete and your GoGear can power on again, consider updating the firmware. Updates give your device extra functionality and repair errors in the device.
Hope it helps...
Have a nice day.
Feb 22, 2011 | Philips GOGEAR SA6045 MP3 Player
Go gear vibe has been frozen for about 25 min. wont shut off or anything
Hi, i stuck a pin in the reset hole, (to the right of the lock switch) and it shut it off, than all you have to do is turn it back on..
The Philips GoGear is a portable MP3 player with additional functionality such as the ability to record your voice or the radio. Some minor problems may develop in the device that keep if from working normally. The most common issues are the GoGear freezing, not powering on and memory-error messages. Troubleshoot your device to return your GoGear to normal operation.
Unresponsive
Memory Full
The GoGear allows you to make voice or FM radio recordings and saves the recordings to the internal memory. The internal memory is limited and the GoGear may show the message "Memory Full" when trying to save recordings. When you receive this message, plug the device into the computer and delete any extraneous files or files you no longer want to keep on your device. This will free up memory so you can save more recordings or place additional music files on the GoGear.
Hope it helped..
Have a nice day.
Feb 22, 2011 | Philips GoGear ViBE Digital Media Player
Cant turn on
Hi there
Check to see that your battery is not flat,if it is you should fully charge it before you power it ion
If that is not the case,then an error is preventing your player from powering on and you will have to restore your player to its original factory settings using the firmware manager
Open "Firmware Manager" on your computer. You will be prompted to "Restore" the firmware select the "Restore Firmware" option.
Once the process is complete and your GoGear can power on again.you should also update your firmware from time to time as this gives your device extra functionality and repair errors in the device.
Sep 02, 2010 | Philips GoGear Flash MP3 Player
I have a phillips go gear MP3 player and when i turn it on it freezes only the words www.phillips/welcome.com screens shows. how to i fix this?
Hello
Your GoGear is freezing because there is an error in the operating system and can be fixed by resetting the device. Resetting the GoGear is similar to rebooting your computer. You will not lose any of the data uploaded to the device. To reset the GoGear, press the "Reset" button located on the left of the device. The screen will go blank for a few seconds and then turn back on.
Sep 02, 2010 | Philips SA3025/37 Flash MP3 Player
My gogear if frozen. Will not power off.
Hello :
PLEASE DON'T FORGET TO RATE !
Apr 18, 2010 | Philips GoGear Flash MP3 Player
GoGear Media engine error! DRM License using Vista
my phillips gogear mp3 os saying i have no media engine and a drm liecince
Sep 17, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips 4GB GoGear Flash Audio Video Player - Video Error
just download youtube converter it is freeware.add the file ,choose the format i.e avi ,get the output file .now load it on philips media converter it will read and work.
Oct 09, 2008 | Philips GoGear Flash MP3 Player
Format
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Aug 01, 2007 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear SA5285/37  Digital Media Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
