Ho do you open the top to get to the water connections on a Maytage Performa washer model PAV2200AWW?
    Genius:
  • 1,073 Answers
Use a putty knife about 4-6 inches from the outside edge in the gap between the top and frount push in with the putty knife blade to disengage the top retaining clip repeat this on the other side
lift up the top water valve on the right rear of the unit
Posted on Apr 20, 2008
I have a Maytag Performa Top Loader PAV2200AWW it will not spin. Previously made a loud noise. Should I repair or invest in a new one?
This is a simple fix. All you need is the transmission pulley and bearing.
Here is a link to the kit you need. It is under $50.00 and should only take less then 30 minuets to fix. Also, I included a video to walk you thru the process.
Oct 13, 2012 | Maytag Performa PAV2200
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Nov 03, 2009 | Maytag PAV2300 Top Load Washer
Model number AS 200 serial # 251033 Maytage
either a bad pump or a worn or missing belt, lean machine back and check your belts
Sep 19, 2009 | Maytag Washing Machines
Washer doesn't cut off water
The problem is the water inlet valve . The part which the hoses from the wall , connect to . Without the model number , I cannot tell you how to access the valve .
Sep 16, 2009 | Maytag Washing Machines
Maytag performa mod#pav2200aww leaking between rinse and spin cyc
My Performa started leaking from the Drain Pump rubber gasket. It had dryrotted. However, Maytag doesn't make a replacement O-ring gasket. You have to buy the whole new pump! Thanks Maytag.
Jul 05, 2009 | Maytag PAV2300 Top Load Washer
Agitation issues. Everything else appears/works normally.
I just encountered the same problem. I think the operation of the machine is such that the motor turns one direction for the spin cycle, and the other direction for the agitate cycle. I am replacing my motor, as I think i have a bad winding on the reverse. I will let you know.
Jul 03, 2008 | Maytag Performa PAV2200
Set wrong load setting
you may have overheated the motor,try leaving for an hour or so and try on spin to see if it starts.hope this helps.
Mar 14, 2008 | Maytag Performa PAV2200
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
