Question about Vacuums
Need to change belt on hoover futura - Vacuums
    President:
  • 1,673 Answers
You didn't say model number, but remove the bottom plate to get to the brush roll, if you can see the motor shaft, the belt goes from the brush roll to the motor shaft. If you can't see it, then remove the top cover to get to it.
Posted on Apr 20, 2008
Why does my hoover belt keep snapping?
Hello! Your belt will need to be replaced about twice a year. If your belt is breaking within a couple uses of you changing it, you may not have the correct belt for your vacuum. Double check the owner's manual or Hoover.com to verify the belt number for your vacuum. Always replace the belt with a genuine Hoover belt. Hope this helped!
Aug 25, 2014 | Hoover Vacuums
Hi, I just replaced my belt for my Hoover Upright Futura with replacement belt 38528040. Now it is making a very loud noise with a lot of vibration. What would be the cause? Could it be the new belt? It...
It is not likely to be a belt problem. I would remove the belt and brush assembly, turn the vacuum on, and see if it is still loud. If it is, the motor fan is broken and will need replacement. If it sounds normal, the problem is in the brush assembly. Examine the ends of the brush for damage or play in the bearings. The brush may need replacement ( part # 48414081 )
Jul 26, 2011 | Hoover U5227-930 Elite Upright Vacuum
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
How do I change the belt on my Hoover Elite Dual Purpose Vacuum cleaner? The belt part # is 38528-027. Where is the motor pulley?
The hoover belt number you listed (38528027) has been changed by Hoover to 38528040. Below I have listed a link to the manual that has instructions and a link to the belt you need. Hope this helps!
Hoover Elite Manual
Hoover Elite Replacement Belts
Nov 02, 2009 | Hoover Elite U5061-900 Bagged Upright...
Help...can't replace the belt on a hoover upright ''futura''
You didn't say what the model number is, so, I will give you a link to a website that has instructions with pictures on how to change the belt. Once on this site, you will see two links for belt replacement. Click the one that is closest to your model.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
I hope this helps.
Oct 02, 2009 | Vacuums
Need to check , belt , donot where to check,on
If you click on this link, it will take you to a website that has instructions with illustrations to show you how to change belt.
Hope this helps.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Aug 21, 2009 | Vacuums
Lost instructions,need to change belt
The customer operation manual can be downloaded from the hoover web site hoover.com
the bottom cover comes off with 4 screws. install the belt on the motor, then roller, stretch to install roller into cavity. replace cover.
Feb 24, 2009 | Hoover U5753-900 WindTunnel Bagless...
Need to change a belt on my Hoover Concept One Power drive
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=766023
Generic problem for all Vacuums
Posted by gentilly on Jul 10, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. On the Hoover Concept One Power Drive Upright vacuum there are 2 belts, a drive belt and a power drive belt, always use the Hoover genuine belts and for the best cleaning always change you vacuum belts every 4 to 6 months for the best cleaning. !st, remove the bottom plate and cut off the old belts – then you need to lift up the one side of the brushroll that has the pulley side for the longer of the 2 belts and slide it on. Replace the brushroll, B4 you go to far remember which went on 1st, the power drive belt (smaller belt) or the brushroll belt, in either case hook the belt(s) onto the pulley 1st and then use a belt puller or a screwdriver with a hook or bend on the end and stretch the belt(s) onto the motor pulley and then track the belts in a straight line – do this on both belts. Once you have done this then replace the bottom plate. Check your owner’s manual in the trouble shooting guide to see if they also have suggestions or check with your local vacuum cleaner dealer in your area or contact the Hoover website or the Hoover factory cust serv phone # listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 10, 2008 | Vacuums
How do I change belt for a Hoover Futura upright vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=753487
Posted by smullur on Jul 07, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Hoover Futura has a bottom plate of which can be released by removing screws, clamps or levers and the bottom plate will come off – if not then the top cover will come off and the belt will be exposed. Then, cut the old belt off, then lift the pulley side of the brushroll up and slide on the new belt then replace the brushroll in the brushroll holder. Then use a belt puller or screwdriver with a hook on the end then pull or stretch the belt onto the motor pulley once that has been done then track the belt which means to roll the belt so that it runs straight and then re-install the bottom plate. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
Jul 07, 2008 | Vacuums
Vacuums Logo
185 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
