At start up power lights and fan are on but nothing else happens. i have tried starting up with supplied recovery disk in tray.
  • 621 Answers
Sounds like faulty memory try using only 1 memory stick at a time to find the bad 1. If youve only got 1 in there replace it.
Posted on Jul 11, 2010
My emachine tower won't turn on . I try un plugging it and plugging back and it doesn't work. Could it be that there something wrong with the motherboard or the hardrive?
> won't turn on
Remove the side-panel, and then press the ON button.
Do any fans start to turn? Feel any air coming out of the back of the power-supply?
Does pressing the button open/close the CD/DVD tray?
If not, then your power-supply has "blown", and must be replaced.
If the fans do turn, and the tray opens, but nothing happens on the screen,
e.g., no "splash" screen, nor any brief white-text "hardware-summary" appears,
then it's either the CPU or the motherboard which is the problem.
If you see the "splash" screen, or that "summary" screen, but Windows does not start to load, then the disk-drive either is not getting any power, or its "data" cable is not connected, or the disk-drive itself has "died".
It's time to take it to a qualified technician, for professional trouble-shooting.
Feb 01, 2011 | Computers & Internet
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
I bought a ET1331G-03w at Wal-Mart. I want to create recovery disks. I follow the instructions given with the product....For Windows 7 click (start)> All programs>emachines> eMachines Recovery...
What type of disks are you using? You cannot use DVD RW. You need to use DVD - R . I have had this very issue. Hope this helps.
PS, once it tries to write to a dvd and fails, try a new one.
Dec 30, 2009 | E-Machines eMachines Desktop PC
Gateway yellow power button, nothing starts, no fan, nothing. opened up computer and see mobo led light is lit. newton ps has a test button. tried to test with various components plugged in and the test...
Power supply has several voltages. Just because the 5v power is active doesn't mean all the voltages are OK. You need to have the power supply tested for 12v and 3.3v. A quick test is to unplug all the wires from the power supply. There is a single green wire on the motherboard main plug. Connect (use a bent paper clip) that green switch wire and any black wire. Plug in the power supply and it should run (fan starts)
Oct 26, 2009 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
I was doing a recovery, when all of sudden the laptop stopped and gave some error message. It will not boot up at all. When power button pressed the laptop starts up fan runs for a while and then nothing...
Hello, You'll need to load the cd recovery disk that came with your computer into your cd drive and restart your computer. All factory recovery cd's are self booting. If you can't boot from the recovery cd you might have a bad disk or a hardware problem.
best of luck, mpawlak908
Oct 19, 2009 | Acer Aspire 5000 Notebook
Cannot get new Motherboard to boot up in Normal Mode
what u may have done is wwhen u were installing the new board, gave a static shock to the system...that will cause only the fans to come on and nothing more...this is a bad problem bc u cannot fix it...if u figure out something else is wrong, and it gets fixed, let me know
Jun 20, 2009 | Gateway Computers & Internet
My HP dv2214us cannot turn on
INSERT UR OS DISK THEN BOOT IT THEN SELECT RECOVERY CONSOLE BY PRESSINGG THE R KEY
THEN TYPE FIXMBR THEN RESTART UR LAP
PLEASE WOTE FOR ME
May 19, 2009 | HP Pavilion dv2214us Notebook
Doesn't start. Green LED off. Red light permanently lighted.
First, try replacing the power supply. If this does not work then the motherboard will need to be replaced.
Aug 02, 2008 | Matsonic MS8137C Motherboard
Power supply
I think your problem is not with the power supply, its the hdd or memory thats causing the problem. try to check the cables, and re insert the memory then start up your pc again.
allen
Jun 12, 2008 | ASUS P4P800-MX Motherboard
Computers & Internet Logo
29 people viewed this question
Alun Cox
David Payne
David Payne
