Question about ActivCardGold for CAC v3.0 (acg30kcl)
I get the following error: our card does not comply with any of the known profiles.
How fix computer sayin user profile cannot be loaded
Hi Anon
Please follow the instructions in the link below to fix your user profile problem.
Aug 13, 2014 | Microsoft Windows 7 Ultimate for PC
I have honda civic 1995 can anyine tell me that 15 inch rim would be suitable for the car as my country has not good roads.would 15 inch rims would damage suspension or not?
talk with a tyre dealer on this one as there are road regulations that you will have to comply with. 15 " wheels will fit your car but you will have to select a lower profile tyre to comply with regulations so you would be achieving any thing as to clearance. Discuss the matter with an "off road" shop as to suitable suspension modifications to get what you want
Jan 03, 2014 | Cars & Trucks
Verifone Vx570 given an error Modem Profile Not Set?
error modem profile not set appears when your Verifone VX 570 modem profile is not properly loaded or has been errased due to Tamper error or Bad RTC. Reloading back the modem profile will sometimes fix the error, but there is also a chance that your I/O module (form where you connect the power and telephone wire) is also bad, thats needs to be repaired or replaced. Call (775)358-2922 ask for Randy. Thanks.
Backside of the I/O module of VX 570
Jan 18, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
WHAT GRAPHICS CARD IF ANY WILL FIT IN A HP SLIMLINE S5120Y COMPUTER?
Hi catchabass1...
You will need a low profile PCIe graphics card.
Go to the following website and check out the low profile graphics cards
Please take time to rate me
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Description=low+profile+graphics+card
Sep 14, 2011 | HP Computers & Internet
Ge profile dbl oven keeps reading error message F7. Put cardboard card around ribbon cable on back of controller as advised a year ago on this site. We have moved it & changed it and now it works...
The F7 error code means that a button on the touchpad is stuck. What the proper repair procedure is,is to first replace the touch pad and if F7 returns replace clock (also known as eoc or control board) Do not take this wrong but a no point in my 30 years appliance repair career exchanging info with my coworkers or even factory trainers at training sessions have i ever heard anything about putting cardboard around the touchpad ribbon cable.
Gene
Aug 11, 2011 | GE Profile JKP56 Electric Double Oven
E-geforce resolution compatibility
That is exactly right. Actually that videocard can even go beyond and support 2048 x 1536 resolution so you should be good to.
You can verify this here under product specs:
http://www.dealtime.com/xPO-eVGA-GEFORCE-6200-PCI-512MB-DVI-I-CTLRV-D-S
Sep 16, 2009 | Evga e-GeForce 6200, PCI Video Card
1 Adaptec RAID 3085 cause parity error in server while 2nd don't!
I'm thinking you should be checking the drives. If one of them is failing, you will get parity errors.
Picking apart parity problems TechRepublic
Mar 04, 2017 | Acer Altos G530 Server
NOT FORMATTED
The error means 3 things:
1. Files format of the files saved on the Floppy disk is not readable on the OS or does not comply with the file format of the OS. So you really need to format it.
2. The floppy disk is brand new and you need to format it first.
3. The floppy disk is not working. Try a known working floppy disk.
Oct 12, 2008 | NexxTech USB External Floppy Drive (NEFD2)...
Application error
there are many reasons why your computer may act that way, the error 0xc0000005 is actually a Windows Validation Error.
In many cases this error has been generated by faulty RAM memory. So if you have just upgraded your computer with some new memory and you started getting this error then I would remove them and see if the error goes away. If it does then send the memory back and get a refund.
If in case you just updated your graphics card drivers before this problem occured, you may just roll it back. Also keep an eye on the vendors website to see if they have an update/patch available or coming soon.
if you have other questions just lemme know okay.
Sep 19, 2008 | E-Machines eMachines Desktop PC
Computers & Internet Logo
1,454 people viewed this question
Top ActivCard Computers & Internet Experts
David Payne
David Payne
Are you an ActivCard Computer and Internet Expert? Answer questions, earn points and help others
