Question about Dishwashers
The dishwasher has LE as an error message - Dishwashers
  • Anonymous Aug 30, 2008
    dishwasher runs for 2-3 minutes and then shuts off with an LE on the screen
Washed Bar B Q grills in dishwasher and it now turns off after 2-3 minutes. Water remains in tub. turn D/W back on and water drains, but still turns off. Unfortunately, the manual has been misplaced.
Posted on Jul 09, 2008
What does LE error message mean?
LE error code indicates that the motor of your machine is faulty.
Jun 18, 2014 | LG LDF7932ST Builtin Dishwasher
Lg dishwasher displays LE error
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
The rotor of Washing Motor is
The Blade is locked.
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Additional details in this article: dishwasher/how-to-fix-lg-dishwasher-le-error
Hope this helps (remember to rate and comment this answer).
May 26, 2011 | LG Dishwashers
Error message LE
1. drain water
2. unplug for 20 minutes
3. spin the drum manually 3 rotations
4. back in business
look at this link below it has "Other" info
Mar 06, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
LE error message on the panel
Depending on the serial # of the dishwasher it may need a new wire harness and inner door liner.
LE is a motor circuit error.
Contact LG @ 1 800 243-0000 they may help you out.
Jan 15, 2010 | LG Washing Machines
LE error message
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
Good Luck!!
Dec 11, 2009 | LG Dishwashers
Dishwasher showwing LE error message
Hi Tanja
LE is motor error.
Empty water from inside the machine and try tripping the circuit breaker for a couple of minutes.
If that does no clear the error , then one of the following faults may have ocurred:
Wiring connection broken either bad connector on pump side or on timer control side, or faulty wiring harness.
The hose connected to impeller, or the impeller itself is blocked.
Motor or pump locked.
Faulty timer board.
Aug 15, 2009 | LG Dishwashers
Dishwashers Logo
165 people viewed this question
Top Dishwashers Experts
