Question about Viking Professional VCBB363 Bottom Freezer Refrigerator
Ice freezing on bottom of freezer drawer - Viking Professional VCBB363 Bottom Freezer Refrigerator
  • Viking Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigeratorice freezing on bottom of freezer drawer - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 12, 2010
    New Friend:
In our case (viking model VCBB363) we found drain hole frozen and so the defrosted water not draining. Poured small quantities of boiled water into it, blotting away the thawed water till hole was cleared. Problem solved. Ofcourse you have to open the panel, after carefully disconnecting icemaker connections and thermistor connections and open screws. Hope this answers your question.
Posted on Apr 10, 2014
5 Suggested Answers
david04928
  • 102 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 3 Answers
    SOURCE: Kenmore elite bottom freezer. Frost, Ice tray
    The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
    Posted on Apr 02, 2009
    • 256 Answers
    SOURCE: my frost free fridge freezer is too cold and
    You may have an issue with the temperature control assembly. Check the temperature settings (ideally at "one-half way" for both fresh food and freezer compartments).
    Contact an appliance service company.
    Posted on Feb 19, 2010
    I have ice bottom of freezer
    There could be blocked condensate drain and water from the freezer is dripping in the refrigerator and freezing under the crispers.
    Sep 23, 2014 | Refrigerators
    Why is bottom drawer of refrigerator freezing shut
    You have a clogged drain in the freezer from the defrost system. You will need to clear out all the ice, remove the rear wall and clear the drain under the evaporator as well. Failure to remove all the ice from the drain system will cause this issue to return. Good Luck
    Jul 23, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Ice is forming under the freezer drawer what causes this
    Clean your coils. Then defrost ice build up with a hair dryer. Good luck!
    Apr 12, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
    Ice maker overfills tray
    Sounds like a probe fault. It should stop freezing when the set point is reached and defrost for a short while. Have you set it to fast freeze?
    Apr 05, 2012 | Thermador Refrigerators
    My frost free fridge freezer is too cold and freezing the food in the bottom drawer there is some ice around the bottom drawer
    Feb 19, 2010 | Hoover HCA390FFK Bottom Freezer...
    Ice maker filling with water but not freezing into cubes.
    Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
    The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
    Aug 25, 2009 | Amana ABB1927DE Bottom Freezer...
    Bosch Refrigerator ice forming in vegetable drawer
    Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
    Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
    Water drains internally at back of freezer drawer
    Check the drain.
    Take the bottom drawer out of the freezer and look in the very back for a drain hole. It may be covered with ice. A hair dryer will melt the ice so you can unclog the drain.
    Dec 30, 2008 | GE GDS18LBR Bottom Freezer Refrigerator
    Bottom drawer wall is covered s ice/ top shelf not freezing
    Sounds like a defrost system problem. Could be related to defrost timer, heaters or defrost thermostat. Have it serviced.
    Jun 09, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
    Viking Professional VCBB363 Bottom Freezer Refrigerator Logo
    540 people viewed this question
    Top Viking Refrigerators Experts
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Viking Refrigerator Expert? Answer questions, earn points and help others
