Question about Konica Minolta magicolor 2300DL Laser Printer
My printer folds up the paper like an accordian. What can I do to repair this?
That usually means there's something stuck inside the rollers of the printer. The only way to fix this, is to open the printer cover and remove the rollers to clear the object (it's usually a little piece of paper or something). If that doesn't work, then the rollers need to be completely taken apart and should be done by a professional or someone that knows what they're doing.
Posted on Aug 05, 2010
Paper jam before printing process
more than likely your fuser is not turning the gear may be bad on the fuser or an internal gear.
Jun 30, 2014 | Sharp Mx-4111n Multifunction Copier
Paper jam in back, accordian fashion, cannot extract lexmark e328
There might be a access door in the back of the printer, remove the door and gently pull the paper out.
May 26, 2010 | Lexmark E322 Laser Printer
The screen reads paper jam error, but there is no visible paper jam and when turned on a grinding noise occurs
Most likely, there is a paper jam in the fuser unit....which is stalling the fuser rollers, thus causing grinding noise (accordian or fan folded jam)
Oct 24, 2009 | Canon imageCLASS D320 Digital Copier
Paper jams and folds into accordians
Most problems with the HP4 series can be fixed by replacing the paper pick roller. Is your paper jamming at the output slot on the top? Can you print ok with the back door open? If so, you need a new output assembly. Try Feedroller.com for cheap parts.
Oct 07, 2009 | HP LaserJet 4 plus Printer
My printer folds the paper in the back accordian
check the drum unit and toner unit, also check on all rolls inside the printer.
if still not working you can send it to me to fix it for you.
Jul 13, 2009 | Brother MFC 7420 All-In-One Laser Printer
Paper is jamming when I print something
Were you able to remove all of the original jammed business cards? where the leading edge of the "Fanfold" prints occurs, you will probably find something blocking the paper path. HP printers usually have a limit on the paper weight that the printer can handle when doing duplex (2 sided) printing. Check this against the weight of the cards you are printing.
Apr 18, 2009 | HP Color LaserJet 2600n Printer
Crinkled paper
It sounds like a fuser problem. You may have something stuck in it, or the lower roller could be defective. You may have to replace the fuser.
Nov 01, 2007 | Lexmark E320 Laser Printer
Konica Minolta magicolor 2300DL Laser Printer Logo
242 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
