Question about Hitachi 32LD380TA 32 in. LCD Television
Sound has gone from our Hitachi lcd television.
The television seems to be working perfectly , except for a complete loss of sound. We have checked all the cabling. Had our sky box checked out.
is it a costly or easy repair.
i.e is it worth fixing?
  • 11,361 Answers
If you get no sound on all source, then try this:
Let verify first to narrow down to where the problem can be. First, check the on screen sound set up menu to make sure the speakers are not set to OFF. If the setting is OK, then attach the powered PC speakers to the Audio Line out RCA jacks to see if you can get the sound there, if you do, then the problem can be in the power amp circuits, if you do not get the sound at RCA jacks, then the problem can be in the sound processor circuit. Please post back what you find.
Parts: www.shopjimmy.com
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Posted on Jul 11, 2010
Hitachi 55FX48B 55 in. loss of power...
Try first unplugging power cord for ten minutes, it looks more like your power unit has gone.
Sep 02, 2008 | Hitachi 55FX48B 55" Rear Projection...
My hitachi big screen has red shadows on picture how do i fix it
What you described sounds like a convergence problem. When convergence has failed the colors will commonly look 3D,warped, etc. This tips page here on Fixya has more details.
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi Rear Projection TV - C4678FS - No Sound
i am having the same problem with my hitachi.. if you find anything out plz let me kno
May 09, 2010 | Hitachi Televison & Video
Color on tv cannot be adjusted. too much red. lamp has already been replaced.
A discolored Blob, loss of one color or blotchy pattern usually in the center of the screen. The problem is becoming all too common with Hitachi projection sets. What happens is that one of the lenses in the optical block (or light engine) starts to burn or discolor due to overheating because of a blocked air filter causing poor air (cooling) circulation. Nothing can be done when the damage is too far-gone except to replace the light engine-at a cost that makes it not worth repair. if the damage is minimal than to reduce further damage, the air filter should be replaced. The Light engine needs to be removed in order to replace the air filter. Be sure to vote/rate me if this helped Thanks!
Also see link:
http://fyshere.blogspot.com/search/label/Hitachi%2050V500%2050%20in.%20HDTV-Ready%20LCD%20Television
Oct 23, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Power but no picture or sound
Actually, it seems the the ballast might have got damaged. This seems more like a ballast issue, it's easy to fix, plus ballasts run around 60 dlls.
Aug 10, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Picture color washed out
have authorized servicer do a memory intialization this is ussually for a pinkish or reddish picture
Mar 26, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Tuner tunes very fuzzy picture and some sound loss
This is a good indication that there is a connection problem somewhere in the cable. Check all of the cables for a bad ground. This includes any cables that reside outside the house. The Coax cable for either satellite or your cable provider may be frayed.
Keep us posted.
Dan
Feb 16, 2009 | Hitachi 32LD8700 32 in. LCD Television
HITACHI 53SBX59B, projection lights don't line up.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Jan 04, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Possible sound card problem?
check the solder connections on the audio output ICs and also around the external sound connections often the ground trace will develope a solder crack and will cause a loss of sound.
Jun 30, 2008 | Hitachi 46BX01B 46" Rear Projection...
Hitachi 32LD380TA 32 in. LCD Television Logo
73 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
