I have Printmaster Gold version 3. I have had it installed on windows xp I now have a new computer with windows 7 and would like to install printmaster gold. What do I have to do?
  • 8,404 Answers
Is your PMG 3.0 on the software compatibility listing for W/7? Did you check it? Pleae check it here: http://www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
If your software is Windows 7 compatible, the list will tell you ... it should run with no hitches. If PMG 3.0 is not listed, you can appeal to the Printmaster Company for a upgrade path.
There is a compatibility test you can run from within the above link that will tell you what on your 'old' computer will migrate to your new computer ...
Even thogh this response was probably not within your expectation, it is a viable response and I hope it assist you in solving your delima.
Thank you for your interest in FixYa.com
Posted on Jul 11, 2010
Having compatability problems installing
Hi, PrintMaster is known for having versions that are not compatible with certain Windows Operating Systems, 18 is known to not work with Vista, yet works with 7 and XP quite well. The best solution would be either to upgrade to Windows 7 or get another version. Good luck!
Jan 10, 2016 | Broderbund PrintMaster Gold Version 18
I have PrintMaster Premier 8.0, I would like to install on my computer running windows 7. It will not download. I do not want to purchase another version. Is there any updates that I can download to allow...
1. These instructions from Microsoft will explain how to run a compatibility troubleshooter for your software.
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
2. Contact Broderbund directly at 800-395-0277. I use their Print Master software also and they are very helpful at the customer service area.
Sep 11, 2013 | Mindscape PrintMaster Premier 7.0
How can I run PrintMaster 16 Platnum in Windows 7
Printmaster 16 Platinum is an older program and is compatible with XP and older versions of Windows.
First check which version of Windows 7 that you have. Click Start > Control Panel > System and Security > System. If your version title ends with x64, you will need to use an option that lets you run an older version of Windows. If you do not see x64 in the title, then the compatibility mode might work.
For the 32-bit OS, right click on the installer and choose Properties. In the Compatibility tab, check the box for always run in the compatibility mode and select an older version of Windows. Apply the changes and click OK. Then right click again and choose Run as Administrator. You may need to repeat this to run the software as well. This is not guaranteed to work in Windows 7 32-bit.
The alternative is to run an older version of Windows. This could be on a second computer, a dual boot computer or a virtual computer (if your hardware supports the feature). Most of these methods require licensed version of the older Windows OS. If you have Windows 7 Pro or Ultimate or upgrade to them, you can run a virtual XP OS for free. Download Virtual PC and XP mode from Microsoft. Then install the Printmaster program in XP as if this is the only OS. (Other virtual computer programs are Parallels and VMWare.)
The only other option is to upgrade to a version of Printmaster that is Win7 compatible. One option is Printmaster 2012 Platinum available here: http://www.broderbund.com/p-273-printmaster-2012-platinum.aspx .
I hope this helps.
Dec 10, 2011 | Broderbund PrintMaster Platinum 16
I cannot install PrintMaster Platinum 2011 on my Windows 7 computer. Is there a way to do it? It says it is compatible with windows 7.
Administrator privileges are required to properly install the program on Windows® XP, Windows Vista®, Windows® 7 and Mac OS X for PrintMaster Platinum 2011 .
Using mouse, right click on the "setup" and Run as "Administrator"
Hope it helps.
Apr 28, 2011 | Encore PrintMaster 17 Gold for PC
I have used PrintMaster 10 for a number of years on my old computer-XP. I recently purchased a new computer and wish to put the program on my laptop( Windows 7). I tried choosing the compatibilty method...
The only solution with this older software that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or are willing to upgrade to one of these versions), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them. You can't have a printer installed on both the main computer and the virtual one at the same time. You will be asked to uninstall the printer if you try.
Your other option is to upgrade to PrintMaster Platinum 18.1, see http://www.broderbund.com/ for details, which is compatible with Windows 7. This will import your Printmaster 10 projects.
I hope this helps.
Apr 11, 2011 | Broderbund Print Master Silver 16.0 for PC
I have chnged my computer system form XP to Window, now I cannot install PrintMaster Platinum Version 17? Is there any way that I can istall this program disc?
Thank you for your question.
In this instance it is easier to direct you to a video on the "Microsoft" website regarding installing older programmes. This is much clearer than trying to explain in writing.
All the best with your install.
Kind regards
Jul 20, 2010 | Broderbund PrintMaster Platinum Version 18
I could not install PrintMaster Publishing Suite 7.0 on our new computer running Windows 7. Is this software compatible with Windows 7? Is the a version to upgrade to that is compatible that we can work...
Not compatible or not working well with windows 7?
(making a program work with windows 7)
Maybe, It doesn't work because the driver/application you installed is for other versions of operating system. I am also using windows 7 like you so don't you worry, You can still use your old installer/driver from other versions of operating systems. Just remember that before installing any program in a windows 7 Operating System Computer, Use "troubleshoot compatibility". Right Click the Icon of your program installer/application first, then choose "troubleshoot compatibility". This will allow you to choose on what type operating system your program will run. Just reply back if it still doesn't work.:D rate and vote for me:)) julyallan01_52.jpg
Jun 20, 2010 | The Learning Company PrintMaster...
Have Windows 7 Home Premium (64-bit)on a new HP laptop computer. Am trying to install PrintMaster Gold 2.0. I get error messages when it is nearly installed. Broderbund told me it is compatible with...
(make your program/application run with windows 7)
Feb 11, 2010 | Broderbund PrintMaster Gold 16 for PC
CAN'T INSTALL PRINTMASTER GOLD 10 ON VISTA COMPUTER
Maybe your edition of Vista is more bugged?
Try updating...
And take caps off. That's called flaming.
Jul 11, 2009 | Microsoft Windows? Vista Home Premium...
My printmaster Platinum 10 version will not install on Vista.
downgrade too XP 10 is not compatible with Vista
May 02, 2009 | Computers & Internet
Computers & Internet Logo
190 people viewed this question
David Payne
David Payne
