No power to my Phonic Powerpod 1860 MK11. Plug fuse ok. I suspect that the unit was operated in 'Bridge mode' by accident.
3 Suggested Answers
  • 4234 Answers
SOURCE: I have a phonic powerpod 7. the speaker
In bridge mode, the left and right amplifiers are in essence connected together. Typically, the speaker connections are to the positive connectors for each channel for this mode. WIth the speakers still connected, you essentially shorted the outputs to ground and smoked the output section. The unit will detect this now and not turn on the output section. Your unit is in what is usually called "protect" mode. This unit will require repair. Expect to have the output transistors replaced at the very least. I would estimate around $16-$40 for parts.
Dan
Posted on Jul 03, 2009
  • 5603 Answers
SOURCE: Phonic Powerpod 1860 - One channel xlr input
Several things could cause this... connecting it to a piecee of equipment powered from a different wall receptacle cound result in ground bounce on the building power that could destroy the input circuits. Another thing is if a static discharge hit it... There are bypass capcitors at the inout that could have shorted. Of course the fader could have failed...
Posted on Aug 13, 2011
How do i get reverb to vocals? phonic powerpod 1860 delux
Use use an echo or reverb chamber for live recording through a desk.
A recorded vocal can be processed using a digital recording program like Audacity which is free. In it you will find a re-verb plug in which will allow you to add this effect.
Audacity Free Audio Editor and Recorder
Apr 17, 2015 | Music
Occassional noise when adjusting high med bass values
Typically anytime you can move a pot,fader,switch etc. And It makes any kind of noise such as static it's likely that it is justa dirty component. Deoxit is the most used cleaner. Most pots have some kind of opening on base that you can spray into if not then just directly down at the collar is where to spray. Spray all dirty controls and excursive by twisting pot.
Aug 25, 2011 | Phonic Powerpod 1860 Plus Powered Mixer
Phonic Powerpod 1860 - One channel xlr input stopped working. What could cause that?
Aug 12, 2011 | Phonic Powerpod 1860 Plus Powered Mixer
Need a manual
http://www.bgaudio.eu/products/prod00000051/um_Powerpod1860Plus_PowerpodK12Plus_PowerpodK16Plus_en_es_cn.pdf
Jul 28, 2011 | Phonic Powerpod 1860 Plus Powered Mixer
I have the Phonic powerpod 820. I ordered a Kuston powered floor monitor to add too the system. I know not to hook it up too the speaker outputs on the back of the mixer. So where do I hook up the powered...
You will plug an UNBALANCED 1/4 inplug cable into the MONI jack on the front of the unit. The other end will probably need to be an XLR plug to connect to the Kustom POWERED monitor. Please note that the UNBALANCED output of the Phonic is NOT good engineering practice. The Phonic stuff is normally low-end and they don't do everything correctely, although for a small system it should work. IF you get excessive hum from using a long cable to the Kustom with a "Kludged" unbalanced to balanced cable, you MAY need to use a DI box at the Phonic end to convert the unbalanced Phonic MONI output to a balanced line (XLR to XLR) for a longer run to the Kustom monitor. You might get a 1/4 inch TS to XLR balanced plug that has a transformer in it and use an XLR to XLR cable to the Kustom. Please note that having this plug in the Phonic hangs out and is easily bent over so I would recommend using a right angle connector at the Phonic and plug the 1/4 inch TS to XLR adaoter into that so the yanking of the XLR cable won't break the 1/4 inch adapter off in the Phonic.
Feb 23, 2011 | Phonic Powerpod 820 / S712 PA Package
I have a phonic powerpod 7. the speaker connections are A & B main 1 & the same main 2 in the middle there is 1 1/4 jack socket that says bridge. it says dont connect any speakers to a or b when...
Dan
Jul 01, 2009 | Audio Players & Recorders
110 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
