Question about Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor
What size fuse do i use for a power drive minn kota trolling motor
SOURCE: Minn Kota power drive trolling motor will not
It is the circuit board in the foot pedal. You will have to replace the whole foot pedal. This is a very poor design. The thin plastic which protects the contacts gets a little hole which allows water to enter and consequently the contacts corrode. Has happened to me two times in past four years. It might be OK for operation in a dirt-free water-free environment; but not under actual fishing conditions.
Posted on May 26, 2009
CorvetteKing
  • 108 Answers
SOURCE: Minn Kota 54lb hooked up backwards (Pos. to Neg) wont work
Unfortunately, those units have a circut board at the power source and if there is no fuse you more than likely destroyed that board. Take the casing apart (the part attached to the boat) it should be two halves. That inital board you see is probably what is destroyed. Of course before i did that I would look for an inline fuse near where the cables attach to the battery or under the unit in the nose of the boat. There is nearly always a fuse if it came from the factory or dealership with the unit so i'd play a little extra hide and go seek for that before doing anything else.
Best of Luck
Posted on Jun 05, 2009
SOURCE: m y minn kota trolling motor cover busted
HOPE THIS HELPS
Posted on Jul 14, 2009
bigcass
  • 35 Answers
SOURCE: is a minn kota mag 36 just 12V or 12V -24V run
I believe the Mag 36 is a 12v and the Mag 40 is a 24v......Ive been doin a little research and cant find anything that points to a 12 and 24v system.....
Posted on Jan 19, 2010
  • 122 Answers
SOURCE: How many amps does a minn kota 80lb thrust motor draw ?
max is 56amps on 24v system
Posted on Jan 31, 2010
Only have a model number and need to order a Minn Kota electric motor propellor
Minn Kota go by the thrust which is mentioned on the top plate. I got mine off Craigs List as well.
  • Minn Kota Prop Compatibility Chart - TrollingMotors.net https://www.trollingmotors.net/blogs/selection/86967623-minn-kota... Minn Kota Prop Compatibility Chart Minn Kota Prop Charts. ... Minn Kota with a serial number and they can recommend a compatible prop for your older Minn Kota motor. ...
  • Minn Kota Motors www.minnkotamotors.com Prop Selection & Part ... Electric Anchor Winches; Shop All; APPAREL. ... A combination of a Minn Kota motor and foot controlled rudder steering allow you truly ...
  • Trolling Motor Replacement Props - Minn Kota www.minnkotamotors.com/Accessories/Trolling-Motor-Accessories/... Minn Kota builds the world's toughest ... Electric Anchor Winches; Shop All; APPAREL. Mens; Ladies; Youth; Shop All; WHAT MOTOR DO I NEED? LET US HELP YOU ...
  • Minn Kota Replacement Propellers - www.fishntech https://www.fishntech.com/minn_kota_propellers.html ... Minn Kota Electric Trolling Motor Replacement Propellers & Nut Kits, ... Minn Kota Replacement Propellers . ... Minn Kota Electric Trolling Motor Replacement ...
  • Minn Kota props replacement props for Minn Kota www.minn-kota.com/minn-kota/minn-kota-propellor/page/2 Minn Kota Replacement Props for propellor Weedless Wedge 2 Props ... Minn Kota MKP 3 Prop 2061151 ... MinnKota Trolling Motor Power Center $57.58; DeckHand Electric ...
  • MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ' ... www.ebay.ca/sch/...nkw=MINNKOTA+MKP+37+2091170+TROLLING+MOTOR+P... Find best value and selection for your MINNKOTA MKP 37 2091170 TROLLING MOTOR PROPELLER ... MINNKOTA MKP 37 2091170 TROLLING ... MINN KOTA ...
  • Jun 08, 2016 | Minn Kota Endura 30 Freshwater Transom...
    WHO STOCKS A 2991251 CABLE FOR A MINN KOTA
    Sherry, I think there may be a new Minn Kota part # . Check the attached links. Good luck
    "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
    Minn Kota Power Drive Non Auto Pilot Coil Cord Assembly 2991283
    Minn Kota Trolling Motor Part COIL CORD STRN RLF PD48 54 2991283
    http://minnkota.com.au/wp-content/uploads/2014/07/55-PowerDrive.pdf
    Can get replacement parts for my Minn Kota trolling motor FAQs
    Apr 13, 2016 | Minn Kota Boating
    Minn-kota wiring battery charger 4 bank trolling motor e-drive
    call the 800 number for minn kota on the head of your unit for questions or technical data. they will send you a copy of your manual also if you dont have it. i am not sure what your question is so ask them to save yourself time.
    Jun 01, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Burning out fuses on trolling motor at battery
    not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
    Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
    I need Minn Kota Power Drive operators Manual
    I'm installing a Minn Kota Power Drive 70# on my Crestliner Fishhawk. I understand the 24 volt system. however the boat has 2 black, an orange and a red wire running to the batteries. I know black to neg. but where do the orange and red wires go.
    Jun 09, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    I lost istallation manual for minn kota power drive v2 50# thrust bow mount tolling motor, where can I find instruction manual?
    Contact the people at this Email address. Minn Kota <Motors@johnsonoutdoors.com> The address is between the brackets. They emailed me a manual for a different trolling motor. They are nice folks. It will take up to a week for you to get a reply.
    Apr 22, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
    Minn Kota Maxxum 55 Freshwater Bow Mount Trolling Motor Logo
    267 people viewed this question
    Top Minn Kota Boating Experts
    Colin Stickland
    Colin Stickland
    Andrew Taylor
    Andrew Taylor
    Mike
    Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
