Question about Kenmore 490 sq. in. Cooking Area Gas Grill 15227
When i turn on the 3rd burner the first two go out.
I have a 4 burner Kenmore grill. The first two burners work fine. When i turn on the other two the first two go out. Help!
    Champion:
  • 274 Answers
Thas is typically a symptom caused by a failing regulator, replace the hose and regulator, easy to do and inexpensive, and see if that helps.
Posted on Jul 12, 2010
On a kenmore 5 burner grill when lighting the fourth burner all of the grill shuts down, regardless of which is the fourth burner?
Sounds like the pressure regulator is malfunctioning. Try disconnecting your gas line. Open/Close all burners then reconnecting gas. If propane, don't turn bottle off before burners. Always turn burners off first, then bottle. then bottle on before burners. This primes the regulator to the proper pressure.
Jan 09, 2012 | Kenmore Grilling
My grill is on, the flame is burning, but the temperature never gets up to 300 degrees with all 4 burners going
Try this, turn on just one burner, once it is lit, turn on a second burner. If the flame on the first burner gets lower when you turn on the second burner, you probably have a bad regulator. Replacing the regulator is cheap and easy and may solve your problem.
Jan 10, 2010 | Kenmore Grilling
My kenmore 4 burner was working fine, but after i changed gas tank, the middle two burners shoots flame under the stainless steel through the tiny holes towards the person standing infront of it...
Turn the propane tank off.
Remove the burners and clean them thoroughly of rust and spider webs, taking particular care of the throat where the orifice shoots gas into the burner. Also make sure the burner holes are free of rust. Wipe any accumulations off of the gas orifices also.
Let me know what you find.
Dec 12, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Weak Flames on Propane Grill
It is possible that your burners are clogged. Clean the burner ports with a paperclip (not a toothpick).
Jun 01, 2009 | Kenmore Elite 644 sq. in. Cooking Area Gas...
Glas flow will almost shut down once i turn on the second burner
hi my name is mark, let me see if i understand your problem. you light the 1st burner and get a good flame. you light the 2nd burner with the 1st burner lite and it starves both burners of gas. if this grill is a lp grill and you have propane in the tank. the regulater is the problem.
Feb 22, 2009 | Kenmore 16228 Grill
Loss of pressure on Kenmore 16322
I can tell you EXACTLY what is wrong. Remove the tank and open all valves to the grill. Reconnect the tank and turn it on just slightly. Relight the grill.
Ther is a safety device in the tank that needs to be reset. The only way to do it is removing the tank.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 17, 2008 | Kenmore 16322
Kenmore 4 burner grill only lights 3 burners
Looks like your regulator is not venting properly to relieve the back pressure. The best thing you can do here is replace the regulator.
May 27, 2008 | Kenmore 490 sq. in. Cooking Area Gas Grill...
Kenmore 490 sq. in. Cooking Area Gas Grill 15227 Logo
175 people viewed this question
Top Kenmore Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
