Question about BenQ T903 19" LCD Monitor
Need to clean (more than dust) the screen of a Benq T903 monitor
I need to clean (more than dust) the screen of a Benq T903 monitor. I'm worried about using liquid solutions (alcohol, etc). Any suggestions, please?
  • 60 Answers
They make alcohol swabs just for that purpose, Try Walmart. I've been using them for years and they have proved to be save.
Good Luck
Posted on Jul 11, 2010
  • faxol Jul 11, 2010
    Iallison1964 - Many thanks for your help.
White dots are displayed on the screen in Benq MP515. keep on incresing
Its dust getting into the light path optics.
You need to check your filters are in place and open up machine an use compressed air can to remove the dust.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | BenQ MP515 DLP PROJECTOR SVGA Projector
I am getting no singal
Please try it on another PC first, if it still does not work, then you will have to open it up if you are going to DIY repair (Please note that BenQ makes monitors for Dell and HP, so look at the Dell and HP albums)
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 29, 2010 | BenQ T903 19" LCD Monitor
Benq t903
Hello
Possible bad Monitor video cable.Or video device is bad.
Try unpluging the pc completly from the wall for 5 min then plug back in and restart.
Also check that connections are solid and tight on monitor video cable.
Hi there my benq dlp projector is showing white spots on the screen when the screen is black can you help me?
This is caused by dust on the lens assembly. If you can remove the lens, clean the surfaces with a lens cloth. That should resolve the problem. It is possible that the there is dust in the optical pathway inside the unit as well. If the cleaning of the lens does not resolve the problem, the unit should be brought in for a professional cleaning. It is not suggested that anyone open up these units as there are fine adjustments that can be changed internally easily that could result in convergence problems.
Dan
Jan 29, 2010 | BenQ PB6100 Multimedia Projector
Just got a hand me down Benq model t903 19
Quite the opposite -- your new monitor can't handle the screen settings that you're running on the old monitor.
Hook up the old monitor and start up the computer so you're looking at a Windows desktop. If you have windows open, close them or minimize them down to the taskbar so you can see the desktop/background image.
Right-click on the background image and select "Properties" to bring up the Display Properties dialog.
There are tabs across the top of this dialog -- select the one named "Settings"
In the bottom half of the Settings tab, there's a control named "Screen Resolution" with a slider to move between "less" and "more"
Move this slider to 1280x1024 or lower. If you're already at a resolution smaller than 1280x1024, then set it to 800x600 and we'll troubleshoot from there.
Hit "OK" to accept the new settings. Windows will ask if the new settings are OK -- click on "yes"
Now unplug your old monitor and plug in the Benq.
If you are happy with this screen resolution, then you're done!
If you're looking at 800x600 and want to see more, then repeat this process -- go to the Display Properties -> Settings dialog and try a bigger resolution. Hit "Apply" instead of "OK" to try a new setting.
If the screen says "OUT OF RANGE" for a setting, just wait for 15 seconds, and windows will revert to the old (working) settings.
Let me know how this works! If it's helpful, click the little thumbs-up. If it's not, ask questions and I'll try to explain in more detail
Aug 09, 2009 | BenQ Computers & Internet
Monitor goes blank after being on for 1 minute
it's not yr monitor problem. it's a basic system problem u need to clean yr ram or ser CPU internal Cables connectors or make sure yr pc is clean if yr pc has dust problem clean with Blower and remove dust then try it's help u..
if u don't know how to clean **** please don't do yrself.. contect yr engineer.
Thanks
Please vote
jo_chinmay
Jan 01, 2009 | BenQ FP71G 17" LCD Monitor
Computer monitor problem
not one fixya people can help with much
if pins break when straightening
need a new part with good pins required as replacement
Mar 22, 2017 | BenQ FP731 - 17" LCD Monitor
BenQ FP591 15" monitor decides to die
Strange that both should show the same symptoms don't you think? Have you changed anything computer wise? Graphics card or resolution? Screeching noise is a puzzle too. How are they powered - internally or via a separate power supply?
May 31, 2007 | BenQ FP591 (Black, Silver) 15" LCD Monitor
BenQ T903 19" LCD Monitor Logo
89 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
