Question about Kenmore 62602 Electric Dryer
Very high heat and timer won't advance
I don't think I have the right model but mine says 110.c65492400. Its a kenmore front loading and its about 3 and a half years old. I first noticed it was started before we went to bed and in the morning still running, I ran it, no heat so I checked and the heater element was open so i changed it. As soon as I ran it with the new element the thermal cut off which is on the duct into the drum blew right apart. I got a new one and the high limit stat in the kit which goes right on the heater element, changed them and the hose going outside and cleaned the ducts in the dryer. I then ran it and it worked for about half an hour and then just quit. I checked the thermal fuse on the blower duct, it was open so I changed it and now it works but on the high heat setting it got so hot the clothes smelled burnt and the timer didn't seem to advance, on the low heat setting it works fine but the timer stll doesn't advance. I already have about $125 into it and would really like to find the root of the problem, any help would be greatly appreciated, Thank you.
  • 868 Answers
Stop !!! You are creating a much larger problem by trying to fix this at this point.To correct the problems it has now is not going to be practical to cost.My advise is to push this aside before you have a disaster.Buy a new /used dryer that is working and when it does need a repair you let me know,do not try to repair anything your not sure of because it makes it impossible to correct the added problems at a low cost.
Posted on May 22, 2008
When Kenmore washer model # 25864400 is turned on it fills with water but won't start washing why ?
It looks like the model no. you give in incomplete. If it has a small "110." in front of the number you posted, You probably only need a lid switch. The timer thinks the lid is still open and as a safety will not advance to agitate or spin. Here's the part you need:
http://www.searspartsdirect.com/partsdirect/part-number/3949238/0026/110
Good luck, John
Sep 21, 2014 | Kenmore Washing Machines
Kenmore dryer model 110 does not stop during automatic cycle
Make sure the small orange wire is connected to the 250 limit at the base of the heater assy. That is what powers the motor on auto cycle.
Nov 27, 2013 | Kenmore Dryers
Kenmore washer Model 110, Serial No. 27602690 won't spin
If wash cycle operates and water drains as should before spin indicates motor spinning. Chances are bad timer If your a real fixer you can remove timer control from panel check and clean all contacts internally making sure none are stuck closed . (Have had 3 110s in my time).not easy but can be done or buy new about 150$ reassemble and check operation.
Mar 28, 2013 | GE WBSR3140DW Top Load Washer
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
I have a Kenmore washer model 110-20712991. the timer doesn't advance. Wherever I put it, it stays there and only does that functions, never advancing to the next position. Is there any test i can perform...
It does sound like a bad timer:
See the following: This is a Whirlpool / Kenmore Service Manual for top load, direct drive washers. It has testing instructions as well as directions for removing each of the two types of timers.
If your timer is the one with a knob that un-screws, use a thin needle nosed pliers to hold the shaft going thru the timer while you un-screw the knob.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Oct 12, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore Dryer - No Heat
110 comes from the motor 110 comes from the timer remove the wire that comes from the motor see if you have 110 if you do the timer is bad if not the motor is. even if the motor is turning its bad
Jun 07, 2010 | Dryers
Kenmore Elite HE3 front loader F-11 and FDL codes
yes!! the F/11 is triggered under high voltage conditions like high speed spinning. The part is called the MCU motor control unit. if it goes into failure while using your machine and locks the door, just wait 3 minutes and the door will unlock after the MCU resets. Try using you machine with a low speed spin for awhile.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
High Heat but does not dry
Check the exhaust tube that goes out the back of the dryer. It may be clogged with lint. Ours did this about a month ago and and a thurough cleaning did wonders. I bought a kit from Lowe's with all kinds of attachments. It was really easy.
May 26, 2008 | Kenmore 62602 Electric Dryer
Kenmore 62602 Electric Dryer Logo
107 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
