How do i bluetooth from my mobile phone to my computer
  • 621 Answers
On the PC right click the bluetooth icon in system tray and select receive file. Windows 7 will want you to set up a security code first time you do it. If icon is not in system tray you will find bluetooth icon in control panel
Posted on Jul 11, 2010
Trouble with bluetooth from a LG 280 mobile phone
Make sure the Bluetooth drivers are properly installed on the computer, dont use the generic basic Bluetooth driver from windows.
Use the manufacturer Bluetooth drivers, cause it will resolve the Bluetooth connection issues between your computer and whatever the devices you are trying to connect to. Usually any small USB Bluetooth device will come with a small disc to install proper drivers or you can get it from the website of the manufacturer for the latest one.
Suggest you use Windows update to resolve this.
Mar 25, 2014 | HP Pavilion Computers & Internet
Tip
How do I automatically start Bluetooth?
<p>Bluetooth is a wireless connection method used for two different devices together, like a computer, cell phone, headset or sync. You are required to enter code synchronization when connecting two devices, but most likely you do not want to enter this information each time you want to sync the hardware. Instead, you can automatically start the Bluetooth devices in sync with each other. <br /> <p><br /> <p>1. Turn on the Bluetooth device (such as a headset) and the hardware you want to synchronize with the equipment (such as your computer or mobile phone). <br /> <p><br /> <p>2. Click the "Start" button when using a computer, select "Control Panel" and finally "Hardware and Sound". Select "Bluetooth Devices" and click "Add" and wait for the computer to search for Bluetooth devices. Press "Setup" when using a mobile phone, select "Bluetooth" and activate the configuration. This allows the phone to search for the Bluetooth device. <br /> <p><br /> <p>3. Select the Bluetooth device, once it is detected (both computers and mobile phones) and enter your pair of four-digit code (listed in the user manual of Bluetooth device). <br /> <p><br /> <p>4. Press "OK" on your computer or mobile phone connects to Bluetooth. Now each time the devices are enabled on the phone and the computer automatically detect and connect to Bluetooth devices. <br />
on Jun 26, 2011 | Computers & Internet
How should i send or receive data from other mobile.
  1. Use a cellphone with Bluetooth (wireless connection), or even a USB connection (which is a computer port). These are all good ways to communicate with other devices.
  2. If your computer does not have the hardware for a Bluetooth connection, then buy the adaptor, sometimes called a 'dongle'. The adapter plugs into a USB port. It will be quite cheap, something like 10 to 20 American dollars. This adapter will have software for the connection process, which lets you transfer files from the computer to your phone, and the other way around.
  3. Make sure your computer is equipped with Bluetooth technology (either integrated into the machine or a USB dongle) and active.
  4. Turn on Bluetooth on your mobile device.
  5. Turn on your phone and go into 'Settings' in the Main Menu
  6. Keep going down until you find 'Bluetooth' (Sometimes it may be under 'Connectivity)
  7. Click on it and find 'Turn Bluetooth on' (or something similar) and press 'On'. You can now send and receive files. Once you receive a file, it will most likely be under 'Received Files'. This option can often be found in the Settings or Connectivity menu of your phone.
  8. Pair your computer with your mobile device by making both devices discoverable (also known as visible or unhidden) in the Bluetooth options. Once both are visible, search for Bluetooth devices on your mobile phone
  9. Locate the name of your computer in the results list and select it.
  10. Enter a 4 to 8 digit passcode of your own choosing and press continue.
  11. Once your devices are paired, you can send and receive files.
  12. There are several methods to send a file to your mobile device. One method is to copy the file from your computer, navigate to your mobile device (often found in My Computer or My Bluetooth Places) and then paste the file to the phone. Another option is to right-click on the desired file and select Send To --> Bluetooth Device --> (mobile phone's name).
  13. While the file is being transferred, you should see a progress bar on your computer and/or phone. Once the file is finished transferring, a message stating such should show up on your device's screen.
  14. Find the transferred file on your mobile phone by using the phone's built-in file explorer.
Oct 20, 2010 | Computers & Internet
Unable perform blue tooth operation
you should be having bluetooth in the computer. open the bluetooth of the mobile and put the option '' visible to everyone'' ON. then open the bluetooth in your computer and search for the devices. when it read your mobile, connect it (Double click it). it may ask for a passkey, write any number and then when you press ok, it will ask for passkey on your mobile. write the same number there and it will pair the two devices. then select any item from your mobile and select '' send via bluetooth'' it will search for the bluetooth items arround and definitely will find your computer. select it and it will send the item from mobile to the computer. While sending something from the computer to mobile, ensure that mobile bluetooth is on and ''visible to everyone'' option is on. Then select the file from computer, right click on it and select ''send to'' option. in that there should be an option ''bluetooth'' click it and it will search for the devices having bluetooth and will find your mobile. select your mobile and it will start sending the file
Sep 07, 2010 | Nokia N72 Cellular Phone
How to connect computer through blue tooth
Sep 07, 2010 | Motorola Mobility L6 Cellular Phone
I am looking to have a s/w, which enable me to make a call from my PC to a cellphone using my GSM services. (My cell PH is connected to computer using cable and I want to make a call to any mobile number...
connect your mobile phone to your computer using bluetooth in a pc running windows 7 operating system. click on the bluetooth icon in the system tray and click show bluetooth devices. search for your mobile phone ( turn on bluetooth in your mobile) and select Add. once your mobile phone is detected and added to your computer in windows 7, then double click on the mobile phone icon ( displayed after your mobile is successfully added to your computer). in the next menu, you can find options to dial a mobile number from your computer. the call will be made through your computer and you can use your computer's speaker and mic to answer the call.
Enjoy
I hope this is useful to you
Please rate the solution provided.
Thanks
Aug 15, 2010 | Samsung Cell Phones
How can I download and install bluetooth software free from web in my pc to share my mobile content?
hi! bluetooth is not a software. it is a hardware, so you can't download it. you can transfer files through the usb cable, but if you want to do it through bluetooth, you have to buy bluetooth usb for computer. when you do it, then search for devices using your phone. computer bluetooth has a different icon than mobile bluetooth, so you will recognize it easly.
Jul 04, 2010 | Nokia X3 Cell Phone
How to connect bluetooth of of computer to cellphone bluetooth?
If you've installed the bluetooth device on the computer, Open the bluetooth settings and make it available, and also power on your mobile's bluetooth. You can search from your mobile or from your computer. Please note that visibility is set to "always" on both the devices. Good luck.
May 28, 2010 | Nokia 6233 Cellular Phone
Lost instructions how to pair with my phone
Bluetooth technology is a way to boost your mobility when talking on the go. It similarly provides a wireless network for transferring files and pictures that you have acquired on a mobile device. Enabling and using this function can be beneficial whether for business or for pleasure.
  1. tep 1 Select from the menu "Settings" --> "Connectivity" --> "Bluetooth." This will bring you into the Bluetooth menu function, allowing you to configure your Bluetooth technology. In this menu, you'll find an option to turn Bluetooth on or off. Select "on."
  2. Step 2 Look for devices on the mobile phonemag-glass_10x10.gif that will be compatible with a Bluetooth device. There is a menu option to seek these devices. If a device is listed on the menu, you have the option to pair this device with your mobile phone. To do this you'll need to enter your security password. This is generally created when initially setting up your mobile device.
  3. Step 3 Check for the visibility option. The phone does have an option to either make your bluetooth device visible or invisible to other Bluetooth and mobile devices. It's your decision to remain private or broadcast your signal.
  4. Step 4 Use Bluetooth for data transfer. Once connected, you'll be able to transfer calls to your headset, transfer photos from your cell phone to your computer, transfer photos from your computer to your phone, and transfer files back and forth. Ensure your invisibility when transferring sensitive information to avoid hackers and losing information to other Bluetooth users.
Nov 15, 2009 | Nokia 2760 Cellular Phone
SAMSUNG SCH-u740
hi! Goto setting switch ON the bluetooth! install the bluetooth devices to the computer! insert the device in the computer! pair the mobile and computer!select the pictures and send through via bluetooth! and finaly u transfer mobile picture to the computer!
Thanking you.........
Jun 15, 2008 | Samsung SCH-u740 Cellular Phone
Computers & Internet Logo
48 people viewed this question
Alun Cox
David Payne
David Payne
