Question about Toys
I want to know what would be the right rating of Electronic Speed Controller should I buy for my 22v 4900 mah 25c lipo. I tried using X-70-SB-Pro but it fried up.
    President:
  • 1,561 Answers
I advice you check the rating on the original Electronic Speed Controller that came with the device to know the exact rating, perhaps, you can also check the user manual for the specification that came with the device, if you can not get it, i suggest you take all the part to electronic workshop to help you get the Electronic Speed Controller that will work with your 22v 4900 mah 25c lipo. this way, you will be rest assured you are in safe hand.
Take care.
Posted on Jul 11, 2010
  • E.J. Kelley Oct 22, 2011
    your AMP rating on your ESC should be at least 10% greater than the Amp rating on what ever you are trying to operate with it.
Does the epson 4900 have wifi capability
No , It Doesn't , only Includes as standard one hi-speed USB 2.0 and one Ethernet port
Jul 27, 2016 | Epson Stylus Pro 4900 17" Standard Edition...
Need a replacement power supply for a Evernote scanner
Sorry Gregory, gave you the wrong number.
You could try something like this. Various voltages and currents with different adapter plugs. This is on Ebay UK but I would think there are others, don't know where you are.
Ebay item number: 201154296095
Specs:
1.Rated Input Voltage: AC 110V or AC240V
2.Vibration Input Voltage Range: AC95V-265V
3.Input Rated Current: 0.4-0.6AMP
4.Input Power: 90W
5.Efficiency: >88%(TYP)
6.Out Power: 90W
7.Output voltage: 15V/16V/18V/19V/20V/22V/24V(0/+0.5V NOLOAD): DC15V-24V
8.Output voltage: 15V/16V/18V/19V/20V/22V/24V(-0.4/0.5V@rating load): DC15V-24V
9.Output current: 15-20V/4.5A@22V-24V/4.0A: 4.5AMP(max)
10.Overload protection: YES
11.Short Circuit Protection: YES
Dec 17, 2014 | Office Equipment & Supplies
Rc helicopter battery
Tip #1: Wait at least 15-20 minutes after you drain a battery to charge it.
This allows the battery to cool down before each charge cycle. I would make sure the battery is cool to the touch before charging it again, but 15 minutes should be alright.
Pointer #1: If the battery is hot after use, then it is a good sign that your battery is getting old.
Anything warmer than about 140 degrees is dangerous; if your battery is this warm after flying, it's time to replace it. I wouldn't use it anymore so it doesn't explode. This is a good indication that in the near future you should look to getting a new one. I would recommend a higher quality / mAh battery (keep the same voltage, though) if the battery running out is a stock battery.
Tip # 2: Wait at least 15 minutes after charging a battery to use it.
Once again, this is to let the battery's chemical processes have a break.
Pointer #2: Battery terms to understand when buying a RC battery.
mAh: Milli Ampere Hour. This is basically the electric charge transferred by a current of one milliampere for one hour. I'm no electrical genius, but the higher the mAh, the longer a battery will last per charge. This is the one part of a battery that you can change without damaging the heli.
Volt: The electrical pressure. Basically this determines how much power can flow to the motor. For lipo batteries the voltage comes in multiples of 3.7 volts, or 3.7 volts per cell.
Cell: An independent 3.7 volt battery.
If you would like a little more in-depth explanation, I found this howstuffworks article helpful.
Litium-Ion (Li-Ion): a type of battery that has a rigid cell structure and shape. It is safer than a lipo battery, but not as efficient.
Lithium-Polymer (Lipo): a type of battery with a flexible cell structure and shape. Lipos can catch fire and explode if mistreated or dropped on a hard surface. BE CAREFUL! Although more dangerous, they are more efficient than li-ion batteries and can come in practically any shape with the same cell count.
Look below to see how the li-ion (on the right) has two defined cylindrical shapes in the package, whereas the lipo to the left is just a rectangle with no visible curvature or cells.
Jul 19, 2013 | Cell Phones
Using lipo s it goes to low voltage shut off
the packs may need to be balanced..most good chargers have an option to balance your packs out..one cell may be stronger so it is running off that cell then acting dead
Apr 08, 2013 | Traxxas Toys
Recently i bought a kyosho inferno ve... what are the best batteries for it? how many mAh , volt and ...C must buy???
for best run time you should run a 14.8v 4s lipo at 5000mah and around 30 to 40c. it will be very fast and give you excellent run time.
Nov 07, 2010 | Kyosho Inferno Ve Rtr 18 Electric 4wd...
Looking for manuel to assemble weider 4900 pro weight machine
http://www.online-owners-manual.com/154031.html
Hi sorry couldn't find a free on-line manual but can buy on cheaply at above link
If this helps please rate me
Jul 03, 2010 | Exercise & Fitness
Traxxas stampede eletric r/c
The first thing to check is whether or not your speed controller is in Lipo mode or NiMH. If you are using NiMH, and the ESC is set for Lipo, it will not work properly. If the ESC is in NiMH mode, then try reprogramming the speed controller, as this has been my problem a couple of times. Good luck, and have fun. Hope this helps.
May 05, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
2nd controller steers hard right in need for speed
I think i know what your talkin about. You must change the controls to your desired option by pausing, clicking options, then controls, and then navigate through the different contols and find your desired option because if your using a certain control while its set on something else, your vehicle will go haywire.
Feb 09, 2009 | EA - Electronic Arts Need for Speed Pro...
I have just recently boughta Nikon D60 and currently own a Tamron 28-300 lens and a 90 macro lens. I think that I want to buy a strob after a workshop I went to this past weekend. I want to be able to...
The SB-600 will probably do everything you want.
One caution: To use flash off your D60 you're going to need either an external sync cord or a wireless controller. The SB-800 (and the current SB-900) can be used as a controller, the SB-600 can't. But the controller goes on the camera, so you'll end up needing two flashes.
Oct 22, 2008 | Nikon Cameras
Toys Logo
126 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
