Question about Kenmore 71121 Air Conditioner
A/c is icing up alot and the pump has stopped pumping. What could the solution be? thank you, Heidi
  • Kenmore Master
  • 43,501 Answers
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioningA/c is icing up alot and the pump has stopped - 2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Posted on Jul 12, 2010
My whirlpool will not drain only a year and a half old
That's usually a clogged pump, Heidi. Chances are a sock or something got sucked into the pump and stopped it. I'm not familiar with your particular model but normally one has to open up the machine to clear the pump. It's not difficult with normal tools but you'll probably need some room to tip the machine. There are instructions (including videos) online to help. Good luck!
May 12, 2014 | Washing Machines
It keeps saying download error each time I download a game from the store and the playstation plus updata keeps turning its self off I have 37gb free on my playstation 3
Laura: Hi, my name is Laura. How may I help you?
chat_enduser_message.png Heidi Newberry: my ps3 has a down load error, t keeps saying download error each time I download a game from the store and the playstation plus updata keeps turning its self off I have 37gb free on my playstation 3
chat_agent.png Laura: I see, Heidi. I'd be happy to look into this for you today.
chat_agent.png Laura: Do you receive an error code along with the message?
chat_enduser_message.png Heidi Newberry: playing crisis 2 73%download
chat_enduser_message.png Heidi Newberry: an error had occured,
chat_agent.png Laura: Okay, so there is no code or number along with that message?
chat_enduser_message.png Heidi Newberry: What would a code example look like
chat_agent.png Laura: It would be a number.
chat_enduser_message.png Heidi Newberry: one minute
chat_agent.png Laura: Thank you.
chat_enduser_message.png Heidi Newberry: 5534-7577
chat_agent.png Laura: I see.
chat_agent.png Laura: In order to provide you with the correct solution, I would like to exhaust all options by thoroughly troubleshooting your system.
chat_enduser_message.png Heidi Newberry: saved data to online
chat_enduser_message.png Heidi Newberry: Ok
chat_agent.png Laura: Please eject the game disc if there is one inside, and turn the system off.
chat_enduser_message.png Heidi Newberry: ok
chat_agent.png Laura: Can you turn your system on without a disc inside at this time?
chat_enduser_message.png Heidi Newberry: yes, ok
chat_enduser_message.png Heidi Newberry: done
chat_agent.png Laura: Great, once on the main menu, please disable your Media Server Connection. From your main menu, go to Settings > Network Settings > Media Server Connection, and disable.
chat_agent.png Laura: Thank you. Once that is complete, please navigate to Settings > Network Settings > Internet Connection Test, and let me know the results of this test.
chat_enduser_message.png Heidi Newberry: Thank you Laura that reset the game system seems to be working
chat_alert.png You have disconnected
Nov 27, 2012 | Video Game Consoles & Games
Thanks for being there. I bought a Whirpool refrid/ freezer on top from a friend and the water pump behind ans at the back of the unit was broken. I had a repair man replace the water pump. What happens is...
If your ice maker was leaking before and after the valve replacement, it is likely the ice maker that is at fault. The ice maker energizes the water solenoid, its not a pump, which then opens to allow the pressurized water flow up to the ice maker. If the valve solenoid has been replaced, the culprit is likely the ice maker itself. The valve should only be open for about 7-9 seconds, but if the ice maker motor is slow, or if there is some other malfunction with the ice maker, it will energize the valve for too long, causing it to then overflow. It could also be a hairline crack in the ice maker mold that is causing it to leak.
Oct 13, 2010 | Whirlpool Refrigerators
Doesn't drain water and spin
It sounds like your drain pump is either clogged or bad. Bail out as much water as you can with a cup and then check the pump. There will probably be something in the pump stopping the impellor blades. There will also be alot of water so make sure you have towels and/or a bucket when you take the pump off.
Jul 06, 2010 | Kenmore Washing Machines
Hoshizaki ice machine KM500-MAE not sending water to harvest
I would not change the pump. If it runs for 3-5 minutes and stops, it has to be a control. The control board runs the freeze cycle for the first 5 minutes. This prevent "Short Cycling" of the freeze cycle. The board looks at the float after the first 5 minutes for the proper water level but should not effect the pump. If the pump does not run in the wash mode, check out the "Power/ Wash" switch. I would start there before I go spending hundreds on pump motor or control board. You may be able to get by on a $20 fix! Do this and get back to me. We will get it going.
Good Luck
May 06, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Won't stay cold for long
IF your compressor is not pumping correctly that would be your problem. If it where the freon you would not have any cool cause it would leak out and you would get alot of warm air. this sounds like the compressor is pumping but not recirculating
Feb 07, 2009 | Kenmore Refrigerators
Danby icemaker not pumping water
I have the same problem, the ice shovel was catching and not moving forward to shovel the ice, this stopped the ice maker. i have cleaned off the surplus plastic from the molding process (on the underside of the shovel) and this so far has cued the problem.
Jul 16, 2008 | Ice Cream Makers
Kenmore 71121 Air Conditioner Logo
55 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
