Question about Acer Aspire One Netbook 8.9" Notebook
My Acer one a505 needs a 3R8 resistor?
My Acer one a505 with 160 gig hd and 1 gig ram was runover on the front edge. the only datmage is the coiled resister 3R8 on the motherboard. Does anyone know how I can purchase and replace this? I am having a hard time finding the part. thanks,
  • 61 Answers
Wow, the laptop was run over and and the only damage was to one resistor? I would be very surprised that you could damage a resistor and there be no cracks in the circuit board. cracks can be hard to see even with magnification. Even if you replace the broken component your laptop still might not work. If it is on a mb it is probably a small surface mount device or from your description may be an inductor. If you have no experience repairing circuit boards this may be a difficult repair to do yourself.
Posted on Jul 12, 2010
I have a Acer AX1200-U1510A AM2+ Motherboard and i would like to upgrade the processor, ihave 4 gigs of mem and a 1 gig Gigabyte Gt 610 graphics card. I only have a 240 watt power supply what processo
Should work with a processor of the same socket type. I'd seriously upgrade the psu myself. Personally I'd upgrade the motherboard and processor to a quad core, and get the fastest ram, look at ebuyer.com, you can buy a bundle upgrade package for less than you may think. :)
Sep 04, 2012 | Acer Computers & Internet
Can i fit 4 gig ram to acer eg31m motherboard?
Yes the maximum memeory is 4 gig. That would be a 2 gig in each slot. Research is saying the memory should be DDR-2 PC2-5300 667MHz chips.
Apr 11, 2012 | Acer Computers & Internet
Cpu speed for ddr 400 ram
cpu speed has nothing to do with ram. they are completely independant. ram speed is important to the FSB (front serial bus) this is the speed at which your motherboard communicates with the devives attached to it. cpu speed refers to how fast a cpu can process info. or how fast it "thinks". most motherboards have the capability of upgrading cpu's. your mobo (motherboard will support the following cpu's:
any pentium 4 up to 3.0 ghz
it supports the following ram
ddr (nott ddr 2 or 3) up to 2 gigs (1 gig each slot) of 533mhz speed (or less)
it also supports up to 2 gigs of sdram either pc133 or pc100
you are using 400 speed ram as you stated i would upgrade to a 533 speed ram as it will be faster, but this is not necessary. as for the cpu just get any P4 (pentium 4) that is 3.0 ghz or less and it will work.
Jun 27, 2010 | ASUS P4S533-MX Motherboard
Cpu lead lights on but no display in monitor
check the RAM condition, For that remove the RAM from mother board and clean the two side of RAM contact terminals wiping with the eraser and insert it again into the mother board.
if you have using more than one ram just remove both the RAMs reinsert one by one after cleaning the RAMs one by one .
Jul 07, 2009 | EliteGroup ECS 755-A2 Motherboard
4gigs ram
Switch sticks around in various combinations (2 gig in slot one, 1 gig in slot two, switch, try other stick, etc) and see if it is the memory or the motherboard.
Sep 10, 2008 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Acer 2.4 upgraded to 2 gig ram and 360 gig HD. Old 40 gig HD left in place and computer is very slow
Go to start .... then my computer.... right click on my computer and select properties. on the general page does it show that it has recognized all the memory you have installed ?
Robert
Aug 29, 2008 | Acer Computers & Internet
Upgrading acer laptop RAM
You Can Actually Upgrade This To 2 Gig Memory.
Each Slot Will Take 1 A Gig Strip.
I,d suggest Buying another 256 mb Strip, To Put Into Slot 2.
Or Buy a 512mb ( Half Gig ) Which Will Give you 750mb With your Existing Strip Already In There. ** Recommend 1 Gigabyte Max** 2 gig of Ram in This Baby Would Probably Start Glowing.
You Can Buy DDR/266/333 In 256/512/1 Gig Strips. These Are Commonly Known As SD-RAM-Modules.
Mike @ Compurepair.
Feb 28, 2008 | Acer TravelMate 2500 Notebook
Graphics upgrade
As long as you have a open vga, vga e, or pci slot in your computer you should be able to install a new video card. the Acer website says your motherboard supports up two gigs of ram, I am not sure how much ram you are running but if it is under 1 gig I would consider upgrading that also. as far as a graphics card goes get one that has at least 512 mb of its own ram so it dosent pull from your system ram as I am sure your current on-board card is doing. Another couple of hints are: if you are running Windows Vista you they call for 1 gig ram for optimal performance, also it is very important that you un-install any graphics drivers before you install new ones, and when you install the new card read the instructions completely before you do anything.
hope this helps
Carl
Feb 07, 2008 | Acer Aspire L100 PC Desktop
2 gig ram stick
Absolutely, 2 Gigs stick of RAM exist. Unfortunately your motherboard's maximum memory supported is 2GB. This site specifies very clearly 1 gig stick max per slot:
http://www.crucial.com/store/listparts.aspx?model=P5VD2-MX+SE
A.J.
Jan 28, 2008 | ASUS P5VD2-MX SE Motherboard
Compaq_277498_001_motherboard
can you please post the make of the motherboard, as compaq only build pc and do not make motherboards, we can help you then.
Jul 14, 2007 | Compaq ( 277498-001) Motherboard
Acer Aspire One Netbook 8.9" Notebook Logo
182 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
