Question about KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator
Not cooling, water collecting in bottom of refrigerator
My refrig is not cooling and water is collecting on the bottom of the refrigerator.
  • KitchenAid Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezernot cooling,  water collecting in bottom of refrig - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
Model ET22DK or ET22DM water collecting inside refrig
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 15, 2011 | Whirlpool Refrigerators
I have a fridgidaire refrige and water keeps pooling in the bottom of the refrige and then leaking out the bottom when it fills.....what is the problem?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
My Refrig is collecting water in the bottom. My freezer is on top and the refrig is on the bottom. Water collects in or under the produce trays. What could be wrong
Without a model number or even a brand, this advise can only be general. You have a blocked defrost drain. Each time the refrigerator does an automatic defrost, the resulting melted frost needs to go down to a drain pain near the compressor, where it will evaporate. If the path to the drain pan is blocked, the water has to go somewhere, in your case, down the inside of the liner of the refrig and to the lowest level, under the produce trays. There may be a tube down the outside of the refrig on back which can be removed for cleaning, or the blockage may only be accessable from the area right by the cooling coils inside the freezer section. (usually located behind the back wall, but sometimes under the freezer section floor) You may find that flushing the drain tube using a turkey baster with warm water will be all that it takes to solve your problem.
Jul 14, 2010 | Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
GE Refridge #tbx21jablraa Water collecting in
The defrost drain tube is plugged. Move the refrig out from the wall and remove the tube which goes from the center middle of the back to the bottom part of the refrig. Clean out the tube and check the part that goes into the refrig. That part usually comes off with a quarter turn or so, then pull.
Sep 24, 2009 | Refrigerators
Water on floor of refrigator. Our refrigator is a Frigidaire Crown series model no. F44Q18CC. We have never had the ice maker hooked up sence we owned our refrigator.We bought it about 5 years ago. Lately...
Water collects INSIDE the refrigerator ? It is coming from the freezer. You have a plugged up defrost drain - look for a drain cup inside your refrigerator section agains the wall, this leads to a plastic tube that connects through the back wall of your refrigerator down a drain tube - see if you can remove this and with an object pass it through the drain tube to dislodge anything obstructing the water passage - if you do not have a drain cup in refrigerator then look in your freezer behind the panel you should see a drain hole below the evap fan, where the ice melts and drains through the tube - if this area is iced up or blocked water will overflow to your refrigerator through the cooling vents :)
Sep 18, 2009 | Frigidaire Refrigerators
Water collecting in bottom of refrig Hotpoint
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
May 14, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
-water is collecting in bottom of refrig
YOUR FREEZER DRAIN IS CLOGGED AND NEEDS TO BE CLEANED OUT-MIKE
Mar 01, 2009 | Refrigerators
KitchenAid Architect KBRA20ERSS Bottom Freezer Refrigerator Logo
91 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
