Question about GE JE1460 Microwave Oven
Paint has bubbled and chipped off in microwave cavity. I have sanded down areas to expose metal. What type of paint do I use to touch-up cavity areas?
  • GE Master
  • 9,085 Answers
Apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Aug 19, 2010
The bottom inside part of my Oster microwave is peeling up pretty bad where the plaste circle with wheels turn the glass. Don't use it much for this to happen....is it still safe and is there any recalls...
Using the microwave with exposed metal can cause additional problems. You can remove the loose paint, lightly sand the area and reprint with microwave cavity paint. The paint can be purchased from your local parts distributer, or find it online. Follow the instructions on the can.
Jul 21, 2014 | Microwave Ovens
Rust in microwave
If the wall of the cavity is not rusted too badly, you can sand it down to metal and touch it up with catalytic paint made specifically for microwave oven cavities. You should be able to get this paint at any appliance parts house. After this repair, be sure to wipe down the inside of the cavity to get the condensation cleared out after you cook in it. I usually leave the door open for an hour or so to be sure that it dries out completely.
Oct 21, 2013 | Microwave Ovens
When i use the microwave it makes a very loud coughing and spluttering noise and there is a flashing of lights inside. It also smells of smoke. Any help greatly appreciated. I live Bristol, England if they...
proceed according. God bless youIf you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
If your microwave has a shelf in it, and you do not use it, keep it out. If one of the shelf supports breaks or comes out, the microwave will arc where the support was. You will have to sand the spot down, paint with appliance paint and re-install support. If the shelf shifts on the support and touches the side it will arc.
Your magnetron waveguide will either come out of the top, or side of the oven cavity. Some will have a stirrer in it(mostly top waveguides) with a panel over, or just a cardboard type cover over it. Over time, the stirrer cover can become warped from the heat which will expose the stirrer's metal shaft which will then cause sparking. These covers and stirrers come in a kit and can be replaced from inside the oven cavity.
Your cover over a side waveguide is coated with a substance on it, and overtime this coating can come off from the heat and moisture in the microwave. These waveguide covers are very easy to replace from inside the oven cavity. Touch up any paint that may have chipped or come off because of the arcing.
If your waveguide cover and/or stirrer are all OK, then the spark is coming from your magnetron. The antenna on your magnetrom has overheated and burned, sending the microwaves out at the wrong angle. If you catch this microwave oven repair early enough, you can usually get by with just replacing the magnetron. If the arcing has caused servere damage inside the waveguide, you will need a new microwave. Waveguides are not replaceable and most you can barely see into them, let alone sand and re-paint. In this case of microwave oven repair, when you remove the magnetron, you will see the burned antenna, or your magnetron will fail the test below.
Apr 04, 2013 | Samsung CE1031B Microwave Oven
Kenmore microwave is sparking when you it start and then goes to pause
see this steps and fix it. God bless you
see the guide for test the magenetron and another component.
Oct 03, 2012 | Kenmore Microwave Ovens
Sparks when starting then goes to pause mode
see this next steps. God bless you
My LG/Dometic MICROWAVE sparks inside the cooking area when turned on
see the next steps and follow with common sense: God bless you
Microwave is arcing If you see arcing or sparking inside a microwave, turn unit off immediately. Arcing can be caused by having something metal in the oven cavity touching a side, an oven shelf is touching the side of the cavity, an oven shelf support has broken, microwave waveguide, or bad magnetron.
Jul 26, 2012 | Microwave Ovens
My oven sparks from the metal plate on the side.
Check to see if there is any rust or cracks in the coating that came from the factory. Some microwaves use metal underneath an epoxy type coating and if it is exposed, it can cause an arc from the microwave generator. If there are any defects in the surface, it can be sanded down and you can purchase a can of interior microwave paint and put a coat of paint over the defective area. Also look for any exposed metal in the area of the sparks, there should no metal exsposed anywhere, if it is, cover it with the paint. hope this helps.
Feb 13, 2011 | GE Profile Spacemaker Over-the-Range...
Was cleaning inside of microwave and noticed the paint was bubbled and when I cleaned this area, all paint came off and metal was exposed 9about a 2 inch area). Should I use the microwave or will arching...
Hi Bonnie,
Do not use the microwave with the exposed metal surface.
What you can do is pick up some appliance touch up paint, it comes in a small plastic bottle with a brush. It looks similar to fingernail polish. It should be available at an appliance store such as Sears, Lowes, Home Depot etc.
Clean the area good and use sandpaper or steel wool if needed to make sure the area is smooth and clean. Then use the touch up paint to recoat the surface. Let dry before using the microwave oven, usually a couple hours or so.
May 01, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
PAINT DAMAGE INSIDE MICROWAVE CAVITY.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If it's allowed to stay that way, it can arc, which will greatly accelerate the charring & rusting processes.
May 25, 2009 | Sharp R-820B Convection/Microwave Oven
Inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing, which can be messy.
Nov 21, 2008 | Microwave Ovens
GE JE1460 Microwave Oven Logo
726 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
