Question about Wurlitzer Jukebox CD Player
Rowe cd 100 no sound please advise!!! - Wurlitzer Jukebox CD Player
  • Alan Hood Sep 02, 2010
    Do you still have a sound problem on your Rowe Ami CD100?
    Regards
    Alan Hood
    ami-man
    UK
3 Suggested Answers
  • 195 Answers
SOURCE: Rowe CD 100 that will not play all Tracks
Are you initalizing the CD's in your jukebox after you install them?
If so it should play all of the tracks.
Regards
Alan Hood
ami-man
UK
Posted on Mar 03, 2009
  • 211 Answers
SOURCE: my rowe cd 100 sometimes doesnt play the cd and it spins it back
Clean the laser eye with a cotton bud. Otherwise it is probably a laser unit problem.
Posted on Oct 29, 2009
I have Rowe AMI 100 CD jukebox. I replaced CDPRO2 Optical Laser-lens and sound still cuts in and out. At times it can't pick up the sound and the cd stops and tries again.
Watch the motor that moves the lens assembly while a CD is playing. It doesn't take much movement to stall the optics so if a gear is slightly binding, that would be enough to cause your problem. Sometimes using a very light machine oil like that is used on a sewing machine on the pivot points will help the gears. A lithium type grease on the rails that the optics moves on may have dried a little, so be sure to check that area too.
May 28, 2016 | Audio Players & Recorders
Can't play album
Set the switch on the computer...Service Switch ON. Press LT button on the computer. On the front keyboard press 4-R, 9-R, zero one. That is press4 hold it down and press R. Press 9 hold it down then press R. Enter 01 on the front keyboard. Set service switch to off. Press LT button. Job done.
Apr 08, 2012 | Wurlitzer Jukebox 1015 One More Time...
The cover over my left oil tube is cracked, can I get a replacement ? How & where ?
I would check out the Victory Glass website at www.victoryglass.com they have a range of trims for the One More Time plastic trims, you will need to find out what manufacturer made your jukebox i.e. Wurlitzer, Rowe Ami, Rock Ola or the earlier Antique Apperatus, Sound Leisure (parts available in the UK from Sound Leisure at Leeds).
Regards
Alan Hood
ami-man
UK
Oct 01, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have a Rowe AMI 100CD jukebox. Its making a loud buzzing noise when I plug it in. Everything else works except the loud noise that I have to unplug it right sway. Do you think it is the red button fuse,...
Hello camillemario,
The problem sounds as if there is a fault on the amplifier.
Pull the 110 volt plug from the power supply that feeds the amplifier.
If the amp is at fault and you are in the USA I would contact Bruce Wentworth for a test/repair to your amplifier.
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
www.abjukeboxrepair.com
Regards
Alan Hood
ami-man
UK
Feb 21, 2010 | Wurlitzer Jukebox 1015 One More Time...
Looking for a spare plastic piece for a Wurtlizer 1015 One More
Hello Belinda,
Check out www.victoryglass.com for spare parts for your one more time jukebox. Make sure that yours is Wurlitzer and not a Rowe Ami, Rock Ola or Antique Apperatus (they were a subsidiary of Rock Ola but used Rowe Ami parts).
Also in the UK Sound Leisure made the one more time.
Regards
Alan Hood
ami-man
UK
Feb 11, 2010 | Wurlitzer Jukebox 1015 One More Time...
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
My rowe cd 100 sometimes doesnt play the cd and it spins it back
Oct 21, 2009 | Wurlitzer Jukebox CD Player
Regards
Alan Hood
ami-man
UK
Feb 01, 2009 | Wurlitzer Jukebox CD Player
Cant solve puzzle 100 in professor layton cant go on im desperate
first square is the only one that is straight, all the others are at an angle..
1st - top four pins on left hand side
2nd - top row 3rd pin, 3rd row 2nd pin, 4th row 3rd pin (position 4) 2nd row 5th pin
3rd - 1st row 4th pin, 3rd row 1st pin, bottom row 2nd pin, 4th row last pin
4th - 1st row last pin, 2nd row 4th pin, 3rd row 4th pin, 2nd row last pin
5th - 2nd row 3rd pin, 3rd row last pin, bottom row last pin, 5th row 2nd pin
6th - 3rd row 3rd pin, 4th row 2nd pin, 5th row 4th pin, 4th row 3rd pin
7th - 4th row 1st pin, 5th row 1st pin, last row first pin, 5th row 2nd pin.
hope this makes sense!!
Dec 06, 2008 | Nintendo Professor Layton & the Curious...
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
91 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
