Question about Amana ACEX186E Wall/Window Air Conditioner
Mold behind vents
What is the best way to possibly remove vent so I can get to mold that has settled behind vents? Also do I keep vent open or closed to maybe prevent this problem again?
model # acex186xe
  • 478 Answers
Fill a spray bottle with a 25% bleach to 75% water and spray the front coil which will allow it to circulate with the air, you may want to spray some in the vent before hand with the a/c off. You can take it out and wash it with a water hose if its really bad.
Posted on Jul 11, 2010
When my vents are open and my windows are closed, I sense
Did you change the cabin filter?
There are professional sprays for that, if it
is due to water & mold in the blower housing
Check that the drain is open
Oct 03, 2012 | 2005 Buick Century
My rear vents wont close 2003 montana
Remove rear seat belt bolt, remove upper rear panel, splice vent motor wires. Use 12 volt power supply to close. I used battery charger kepp closed so you can wash and keep rain and snow out.
Sep 25, 2012 | 2003 Pontiac Montana
Why does the air conditioner leak water from behind the unit. My air conditioner is placed in a wall and the back end of the conditioning unit sticks out inside the garage. I have ventilation by...
It is normal for an air conditioner to leak water out the back. This water is actually the humidity being taken out of your house. Being vented out in to the garage is always an issue with condensate water. I have seen some people take a funnel and run a hose outside the garage somewhere. Keep the vent closed. It will be harder to cool the house with the vent open because it lets outside air in to the house.
Jul 04, 2011 | Friedrich Heating & Cooling
Heater smells like burning mold. help?
Your air vent drains are plugged. The drain tubes empty into the engine compartment or into the wheel wells behind the plastic slop covers. The best way to clean them is from the top.If you can locate where the tubes come out you open the drains from the bottom with a piece of wire. By taking off the windshield wipers and the vent cover in front of the wind shield you can scoop out the leaves,mud, debris,etc. and clean out the tubes with a piece of wire washing the left over stuff slowly out the bottom with a pitcher of water. This should help stop the growth of the mold. With out disassembly of the dash it will be hard to clean everything out. Perhaps febreeze in the vent help help remove most of the smell.
Dec 04, 2010 | 1999 Plymouth Grand Voyager
Our vaulted living room ceiling has black smudges coming through the paint...we have used Kilz paint and repainted several times...also had vents put in the roof
Did you happen to spray the mold with Bleach before covering up ? If mold is still in growth mode even Kilz cannot keep it from penetrating.. Usually half water and half bleach would be ok. Just vent the house well.
Aug 19, 2010 | Heating & Cooling
Is it good to close the vent or have it open
The vent will bring in outside air while running. If you are use the cooling keep the vent closed for the best performance.
If you are just using the fan only for air circulation and it is mild outside you can open the vent for fresh air to be pulled into your home.
May 30, 2010 | Goldstar R1203 Air Conditioner
Just wanted to find out if the vent should be open or closed when air conditioner is on..
If you are talking about a whole house ducted system, it is best to keep all vents open.
If you are talking about a window air conditioner, the vent is mainly intended to bring in fresh air, usually people keep them closed, unless you are just running the fan only and want to bring in cooler fresh air, like in the early mornings.
If this has helped, please rate me, or contact me back with any further questions that I can help you with.
Sincerely,
Paul Gibson
May 03, 2010 | Heating & Cooling
Active vent keeps opening and closing though fan is off.
When the unit begins the never ending opening and closing cycle, turn the vent fan on for a few seconds and then turn the fan off. This seems to stop the active vent from opening and closing. If this is GE quality, this is the last thing that I am going to purchase. GE refrigerators are garbage and now I am having problems with a new microwave oven.
Apr 27, 2009 | General Electric PVM1870SMSS Microwave...
Fuel oil level extremely low: possible problems?
After your fuel tank is refilled let it set if possible for solids to settle. In the line near the tank is a fuel filter. This fuel filter should be changed regularly, normally annually. The air must be vented from the fuel filter though vent screws located on top of fuel filter. Do not remove the screws completely as air will vent as they are loosened. At the burner oil pump is a vent to which you can slip on a 1/4 inch hose and direct into a container. On burner start up loosen the vent at the oil pump and observe oil going into container. When solid stream of oil is seen close the vent. The vent looks like a grease fitting on an auto.
follow these instructions: One problem that can occur is the nozzle for the burner sometimes becomes plugged if solid particles make their way to it under low oil conditions. If this becomes the case you should have a heating service tech change the nozzle and fuel filter. However try the venting procedure first. You just may be O.K.
Dec 15, 2008 | Heating & Cooling
I am trying to light my bbq, and it only has low flames. wvwn when on high.
Make sure the vents are open both on the side and chimney. If you are using as bbq light fire in the large section.The small section is for cold smoking as the heat sorce is further away.
I have a brinkman myself and use it regular for smoking mackerel but have only have the large section and not the add on small box. Start as a normal bbq with bricket coals and bbq lighter fluid with both vents open. Leave for twenty mins to become ash covered this eliminates oil taste in food as it is burnt off before food is put in.Then put in oak chippings or beech, hickory,or as I find a mixture of apple and oak to be the best I use strips of wet toweling to put around main lid when closed keeping more smoke in the main box.Keep main vent half open on the left of drum and regulate air flow from vent on chimny stack only open half inch or so.If you want to get a heat bust open lid and put over coals shavings rather than woodchips this will egnite an as soon as it does shut lid down again and watch temp rise. Mine goes upto 3oo deg and settles at about 250 deg. Repeat shavings every ten mins or so to keep temps up.Fish is done perfect in about 45 mins
Apr 20, 2008 | Barbeques Galore Bar-B-Chef Charcoal...
Amana ACEX186E Wall/Window Air Conditioner Logo
187 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
