Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Replacing belt on a craftsman 917259521 - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Aug 11, 2015 | Craftsman Garden
I have an old Sears Craftsman Tiller Stock Number 32-29943 and I need to replace the belt on it. Does anyone know where I might be able to find a belt?
i believe the model# is 917.291481, on eBay they sell belts, hope this helps Tim:
http://shop.ebay.com/i.html?_nkw=craftsman+tiller+belts&_sacat=0&_odkw=craftsman+tiller&_osacat=0&_trksid=p3286.c0.m270.l1313
Apr 25, 2011 | Craftsman Garden
Craftsman 917259521 mower stops when blades engaged. Engine starts and runs strong
There is a safety switch under the seat that, if not activated, will cause the engine to die when you engage the blades. Lift up the seat and check that it hasn't come out of its mounting, and that the wire connectors are still on. If that all looks OK, unmount it and use a piece of tape to keep the button pushed in. Test the mower again. If that fixed it, it may just be the switch mounting needs to be adjusted. If pushing the button doesn't fix it, replace the switch. They are not expensive. Good luck!
Jun 11, 2010 | Garden
Replacing a the belt on a portable air compressor - craftsman
hi mate if the pump is connected then it doesnt have a belt its direct drive and if the motor is seperate from the pump unit then it belt driven i dont understand as the picture is a direct drive (no belt)
Aug 23, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
May 17, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Replace drive belt Craftsman 917-255572
First you have to remove the deck,then you may have to remove belt guards to install new one,then reinstall the deck
May 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
89 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
