Question about Scosche Industries SCOSCHE GM21SR 2006-UP GM LAN STEREO REPLACEMENT INTERFACE WITH ONSTAR
I have a 2007 Monte Carlo..I installed the Scosche Gm21Sr the exact way it states o the instruction manual. The problem is that the radio stays on and wont play the music through the speakers
  • 1 more comment
  • mr_stanfield Jul 11, 2010
    The 12v constant is yellow
    12v acc is red
    illumination is orange wire
    black is ground
    The ground is ran correctly and as soon as the radio is hooked up it cuts on. Even if the key isnt in the ignition and the door is open.
    Its a onstar monte carlo with no bose system...when i connect the second factory plug into the scoche box the audio leaves from the door speakers and starts playing through the chime speakers very low. The sub input works fine. When i unplug the factory harness it plays through the door speakers but not through the subs. I still can get the radio to turn off
  • 532 Answers
The GM21SR Is designed to be used with any aftermarket radio. To get the most current application guide information, please contact Scosche Tech Support: ...
www.scosche.com/ecom/download/GM21SR.pdf Thanks.
Posted on Jul 11, 2010
  • 2,359 Answers
Do you have On-Star in your 2007 Monte Carlo?
Is it a Bose equipped from factory?
According to my Scosche book
GM21SR is for OnStar equip Monte
GM22SR is for standard non Onstar Monte
non-Bose system only
As quick check disconnect the smaller power connector to the GM21SR,
Wait 2 minutes.
Key out
Reconnect the smaller power connector
key to on only (not staring) for 5 seconds and key out
Re-set the Onstar volume and the chime/dimmer programing again.
    President:
  • 1,561 Answers
Check to ensure the radio volume is at mid or at an higher volume, perhaps, you can also check if the radio is not on mute, see the procedure to wire your radio,
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Light Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 3 1/2′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 4′ x 10′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Take care.
  • 1 more comment
  • Sulaimon Jimoh Olayemi Jul 11, 2010
    Sounds like the amps protect circuit is working, check speaker leads for
    shorts to ground, or the voice coil maybe shorting out in a speaker .
    Check
    with Ohmmeter or a installer.
    Take care.
    So even if the ground is fine...Once i unplug on of the factory inputs from the Scosche device the musice comes back through the speakers but it cuts off the amp input
    and the radio still wont shut off
Location of power mirror fuse 2007 monte carlo
page 396 shows the panel for the circuit breaker [auto] no fuse for power windows the panel is passenger side door side molding the following link is the owners manual for your vehicle
2007 Chevrolet Monte Carlo Owner Manual
Aug 09, 2016 | 2007 Chevrolet Monte Carlo
Locating radio fuse 2006 Monte Carlo
located in under hood fuse box the following link is the owners manual for th 2006 monte carlo page 5-95 starts the information and the location of the fuses
https://www.manualowl.com/a/Chevrolet/2006-Monte%20Carlo/Manual/1345 sorry the first link was for another vevicle second link is for monte
Jul 06, 2016 | Cars & Trucks
How to correct a 2005 chevy monte carlo high beams from staying on
About 17,700 results (0.74 seconds) Search Results
    My high beams won't go off!! - Monte Carlo Forum - Monte Carlo ...
    montecarloforum.com > ... > General Forums > General Monte Carlo Talk
    Jun 8, 2012 - i flipped on the high beams last night and i think that switch in the column broke. ... My high beams won't go off! ... 2003 Chevrolet Monte Carlo. Help!! Need to get headlights working. - Monte Carlo Forum ...
    Jan 1, 2012
    Repair Guide: List of Common Monte Carlo Problems and Solutions ...
    Aug 9, 2011
    Fog lights not working, High beams stay on?
    May 9, 2011
    More results from montecarloforum.com
Jan 30, 2016 | 2005 Chevrolet Chevrolet Impala LS
What are problems installing a radio in a 04monte carlo
It would be helpful if you stated the type of issue(s) you are having.
Apr 24, 2014 | 2001 Chevrolet Monte Carlo
Radio codes for chevrolet monte carlo
you may have a card in owners manual that has radio code, otherwise you need the serial number off the back of the radio to give to dealer
Sep 15, 2012 | 2005 Chevrolet Monte Carlo
Monte carlo radio is theftlocked.
you need the unlock code from the manufacturer. I had a radio lock up but the company had me send it to them for them to unlock. i had to prove that i bought it and it was not stolen.
Jan 30, 2010 | 2001 Chevrolet Monte Carlo
1984 monte carlo left blinkers are fine but
What you need is a new blinker module. They are a relatively cheap part that you can go to an auto parts store and get, and install yourself quite quickly with their instructions.
Jul 17, 2009 | 1984 Chevrolet Monte Carlo
Need mannual
should only fit on way but if not plug it in BOSE
Oct 22, 2008 | Scosche Industries Scosche High...
Pioneer AVH-P5700 instalation
You can find a wiring diagram for your 87 monte at http://www.modifiedlife.com/1987-chevrolet-monte-carlo-car-audio-wiring-schematic/ You can refer to the installation manual for your deck at http://akamaipix.crutchfield.com/Manuals/130/130AVHP570.PDF Since you are removing a shaft style radio and installing a DIN style you will need to perform extensive modifications to your dash. The Pioneer manual provides the dimensions.
Sep 10, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Scosche Industries SCOSCHE GM21SR 2006-UP GM LAN STEREO REPLACEMENT INTERFACE WITH ONSTAR Logo
436 people viewed this question
Top Scosche Industries Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Scosche Industries Car Audio and Video Expert? Answer questions, earn points and help others
