Question about Maytag 24 in. MDB8951AWS Stainless Steel Built-in Dishwasher
Maytag 24 in. MDB8951AWS intermittent button problems and incomplete wash cycle. The buttons work sometimes ... sometimes not. We also have experienced incomplete wash cycles when the buttons do let us start a cycle. Sometimes it completes correctly. Suspect control board, as I expect a membrane failure to cause incomplete cycle unless it is making a Stop/Cancel contact by itself. Can anyone chime in on thoughts?
SOURCE: Most of buttons on touch pad are not working.
Gee thanks McGyver, I'll get right on that and after I'll use any remaining parts, a comb and of course a paperclip to build a rocket. Have anything a bit more practical for the rest of us on planet earth?
Posted on Apr 07, 2010
  • 577 Answers
SOURCE: Dishwasher will not start. All option buttons
Hello, I am sorry that your dish washer isn't working. One of the biggest problems with these new dishwasher is they install the control on top of the door and the operational circuit board below the control panel. Inside the door is acceptable to moisture which creates all kinds of problems. It not the spray arm or the float, or the pump. it is where they put the circuitry to control the dish washing machine.
I hoping that all you will need is a push button control strip for this dish washer. moisture get in the micro switches and make them inoperable. These button in the control strip are hermetically sealed against moisture....for a while.
Remember, it depends on how long has the dishwasher been working and what will be the cost to repair your dishwasher. Dishwasher are really good for 10 to 12 years of service. I worked on a Kenmore that was 25 years old. I told the lady of the house it is time for a new dishwasher. I could have repaired it, but really it not worth it when it is this old. GB...stewbison
Posted on Sep 06, 2011
  • 878 Answers
SOURCE: Control buttons don't work, Help.
donnson, sounds more like the touch panel shorted or stuck keypads. You can remove the touch panel ribbon from the control board and try to clean it with an eraser. You will need to remove the torx screws and remove the inside panel. See if it comes back to life. Behind the toe-panel on the bottom, there should be a tech sheet showing how to check the key pad. The key pad and control board are warranteed for 5 years on this model, parts only. back.
Posted on Jan 08, 2007
  • 338 Answers
SOURCE: Maytag Dishwasher Doesn't Start
on a dishwasher an ohmmeter is almost useless. the best way to check is to look for voltage. at the door switch check for voltage to ground on both sides. if you have 120 on both sides of the switch then follow the wire over to the control board. if you have 120 going into the control board and nothing coming out of the control then you nood to start looking for a broken neutral. however the likelyhood that its the control panel may be a better idea especially if you are hitting buttons and nothing happens. try reseating any ribbon cables
Posted on Nov 25, 2008
SOURCE: My Maytag steam dishwasher # MDBH980AWS won't do
My Maytag dishwasher # MDBH950AWW wont turn on no light but it has power in the outlet no power to the control board
Posted on Jan 21, 2010
Dishwasher shuts off during cycle
Since the troubleshooting and repair process is too lengthy to include here, please go to the following link:
to open [or download] the service / repair manual. It is free.
Scroll about half way down the page, in the left column, under Maytag products, select the Maytag / Jenn Air / Jet Clean II "Tall Tub" Dishwasher repair manual... it covers your model dishwasher..
It includes a troubleshooting guide as well repairing instructions
Best wishes on your project.
Dec 01, 2013 | Maytag MDB9600A Jetclean II Built-in...
My Maytag dishwasher will not start. I have a concealed touch pad on top. This is the third time it has done this. Every light works but the start button. If I wait a day or two it will start working...
There is a way to reset it when this happens. Do a Duck Duck Go web search and you can get the sequence for your particular model/Maytag. There is a sequence of keys to reset. Do the lights blink when you try to press start?
Let us know if this helps.
Jan 03, 2018 | Maytag 24 in. MDB8951AWS Stainless Steel...
Maytag model no mdb8951aws. My dishwasher doesnt clean properly. There is a residuesomehing like food stuck inside cups & bowls specially in upper rack .i dont stack dishes.tried everything but no...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
Jul 05, 2010 | Maytag 24 in. MDB8951AWS Stainless Steel...
Maytag mjd 2005 when started on normal gives a once-every-two-seconds "wash". Seems to pump out some water each time. When turned off and on again 'normal' button lights and the same thing happens. Will...
I have the same problem but now on all cycles - to get it off normal and try the other ones, open the door, hold down the 'normal' button for three seconds, and then at least try the other settings temporarily.
Mar 30, 2010 | Maytag 24 in. MDB9750AW Dishwasher
My maytag dishwasher lower and upper spray arms are working intermittently. Sometimes there is plenty of water spraying around, other times, I can hear what sounds like the motor running but the arms are...
Pour 1 Cup of Muriatic Acid (Can be purchased at your local Pool Supply Store) into the bottom of the washer and a little in the soap dish. Run the Dishwasher through 5 cycles. Check to see If this helps. If not Try the same process with CLR house cleaner.
Oct 22, 2009 | Maytag 24 in. MDB4000 Built-in Dishwasher
Control panel on my whirlpool dishwaher not functioning properly
The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
Feb 20, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Maytag Nuptune Washer
These units seem to all use the same control board and have the same issues. the intermittent and door lock issues are random and frustrating. it will take a person that wants to fix it. see this link for what to do. I have other links that explain the same.
Oct 03, 2007 | Maytag MAH8700A Front Load Washer
Not draining
check that the pump/filter is not blocked or that the drain hose is not "back filling from the sink waste piping -if it is plumbed in there.
Jun 06, 2007 | Maytag 24 in. MDB8951AWS Stainless Steel...
Maytag 24 in. MDB8951AWS Stainless Steel Built-in Dishwasher Logo
81 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
