Question about Lexmark Wheelwriter 1000 Typewriter
Typewriter will not do anything. Two lights are flashing for 1 and 2 margin function. Have powered off several times but nothing happens; still does nothing.
  • Lexmark Master
  • 3,594 Answers
Your keyboard is bad, try my tip under WW1000.
DickyO
Posted on Aug 10, 2010
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
The margin lights are flashing and nothing is responding. It seems locked up. Have turned off and back on several times and nothing changes. This is a Lexmark 6781-025 IBM personal Wheelwriter 2.
Your keyboard is probabily bad. If you h ave mech. abilities try my tip under WW1000. If not Contact Geo. Beyers Co. @ 800-392-8085 for a rebuilt KB. Tell them O'Reilly sent you.
DickyO
Oct 20, 2010 | Lexmark Wheelwriter 15 Series II...
R margin is not in the right place
Not positive about but many electronics you must press and release the mar rel key for it to function.
DickyO
Apr 05, 2010 | Brother EM-530 Typewriter
Can't change the right margin
You must first position the carrier to where you would like the margin to be set, so if you want the margin to the right of where it already exists you must to the the margin and Depless the margin release function (M rel). If the typewriter is in line-by-line mode you may have to select the TYPE mode , before you do this. When the carrier is position to the place you want depress the R margin set function (CODE plus M left)
Nov 25, 2009 | Brother EM-530 Typewriter
Wheelwriter 6 Typewriter won't come on.
When the switch is turned on, the machine sholuld cycle all the motors and home the carrier to the left margin position and one of the linespace lights whould be on. If the machine does not cycle at all:
  • Make certain that there is power to the outlet (try a known working appliance or light into that outlet)
  • Ched that the line cord is securely plugged into the wall outlet
  • Check that the line cord is securely pluggted intor the back of the typewrtier (you can wiggle it while the power switch is on and see if the machine reacts)
  • Flip the switch on and off several times, including a flicking motion
Nov 09, 2009 | Lexmark Wheelwriter 6 Series II Typewriter
Tab Release
You can reset all functions to original settings by doing this simple self test.
1. Turn typewriter off
2. Hold down the margin release key.
3. While holding down margin release key, turn on typewriter.
4. release margin release key
typewriter will now begin to type on it's own.
5. Turn typewriter off and then on again
all settings will now be cleared.
Feb 02, 2009 | Swintec 7040 Typewriter
Margin Release problem
Unlike the manual states, you have to release the Alt + MREL before you backspace past the margin. Then it works.
Feb 21, 2008 | Brother ML-300 Typewriter
Brother Electric typewriter ax-22
sounds like it needs a good clean. Your best bet would be to look out for a Brother service centre or at least an established typewriter repair centre. Most modern technicians will be able to get your Brother working again...Good luck!
Nov 19, 2007 | Office Equipment & Supplies
Margin clearing and resetting
You cannot "clear" the margins. You have a left margin and right margin. They MUST be set somewhere even if they are set at the extreme left and right of the carriage. This part is IMPORTANT!!! Some functions (like right margin or margin release) may be written in a different color or shade. If they are, you must hold down the CODE or FUNCTION key while touching that function. In any case, the CODE key or similar will be the same color as the function you are trying to access. Get the printer where you want the margin to be. If you want the left margin set to the left of the current margin you will have use the MARGIN RELEASE key first. This may be labeled MREL or MAR REL or something similar. Backspace to where you want the margin to be then press the LMAR or LEFT MARGIN key. That will set the left margin at that point. Repeat the process for the right margin. Hope that helps Ed
May 26, 2007 | Nakajima AE-830 Typewriter
Lexmark Wheelwriter 1000 Typewriter Logo
96 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
