Question about ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard
No signal to monitor when booting.
I have not gotten my new computer up and running yet. Keeps saying no signal on the monitor. Everything is installed correctly into the motherboard, power source, etc.
Here are my specs: (Keep in mind I have not got it running to BIOs yet)
Asus M2N-SLI
AMD Athlon 64 X2 6400+ at 3.2GHz (these two were in a bundle)
XFX GeForce 8800 GT
Ultra X-Pro 600 watt Power Supply (SLI-Ready)
OCZ Reaper 2x 2048 Memory
Now personally I think the memory is the problem now. I don't know, but it doesn't say it's SLI-Ready. I don't know if it has to be to work on the motherboard, and if that is why there is no signal to the monitor. I hope I don't have to return another part and get something else. But the memory seems the likely villain here. Hopefully someone can help.
    President:
  • 2,351 Answers
JNic84, did you connect power to your XFX 8800 GT?
That is the trouble little things....
Luck!
Mike
Posted on Apr 22, 2008
  • 105 Answers
(1) Remove memory from mother board and start the system if you happen to listen long beep then RAM is not working properly.
(2) Clean RAM conducting area on mother board with clean cotton cloth, put one peice of RAM and test and check the othe peice also, if working you could any sign display . Before doing all these check mother board any LED is glowing if so your SMPS is working after you turn on UPS.
(3) Check for all proper connection for all cables. Have you connected video cable of monitor to mother board VGA (it will not work because it is disabled as soon as you installed XFX GeForce 8800 GT), your viedo output only will come through XFX GeForce 8800 GT VGA port.
(4) If propelm persits Deassmble complete the system and reassmble & do n't connect HDD, DVD, floppy. Cehck with bare mother baord, processor, RAM (put one picese at a time) by connecting viedo cable of monitor
Posted on Apr 19, 2008
My monitor keeps saying no input signal an now won't power up
Sounds like its the video output from your computer. Try installing a new video card.
Jul 20, 2014 | HP Pavilion Computers & Internet
I get the Monitor is in power save mode and won’t boot normally. It will boot in VGA mode but then goes haywire when you try to change the screen resolution. I’ve also gotten a blue screen saying a problem...
Usually this problem happens when the video card is sending a signal to the monitor that the monitor does not recognize. (Kind of like me telling you how to fix this problem in a language I dreamed up myself.) The monitor will work on a different computer, because that computer has a video card "talking" to the monitor in a language it understands. So the solution is a different monitor that has a resolution setting your computer can talk to. Possibly you can borrow one, change the resolution of the card, and put your own back in. You can plug in and unplug monitors while the computer is on with no problem, to test.
Nov 01, 2017 | Dell M992 Monitor
LCD Monitor (Model Number M17FBA) Signal Out of Range
Hi
Start the computer in SAFE mode. F8 before Windows starts. Once in SAFE mode change the screen resolution to 600 X 480. Do this by right clicking anywhere on the desktop. Once done then reboot into normal mode.
Jun 03, 2010 | Scanport 17" LCD Monitor
Boot up computer. Nothing comes up on screen. Get a message:"information. No input signal." Everything is plugged in correctly.
  • check the cable on the monitor screen
  • if after removing the data cable from the computer and it has no vertical color screen then
  • try other data cable
  • try other monitor screen
May 02, 2009 | Computers & Internet
My W2207 monitor keeps going to sleep
Hi,First there is no signal from the PC . check if the display card has come out while moving the monitor, or just reinsert the display card in the PC , then boot the pc .
Jan 14, 2009 | HP w2207 Monitor
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Monitor saying no signal
check the Pins in the monitors serial port and make sure all are straight 15 of em
Jun 03, 2008 | Computers & Internet
Going to Sleep
Due to the power surge, it is highly possible that the monitor was given a boot by your computer on it's way out.
This will short out a very small transistor inside the monitor on the video board and in turn, then monitor cannot see that there is a signal so goes to sleep.
If you get brave enough to venture inside the screen, then check near the cable input. The transistors are only around 3mm and have 3 legs (two one side and one in the middle on the other).
If you find anything like that burnt (get a magnifying glass) then replacing the board is the easiest option. Just don't be tempted to wipe the board before you look at everything very closely, you may wipe away the tiny bit of evidence you are looking for.
Hope it helps =)
Feb 12, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Input Signal Out of Range
I have been having the same problem with my hpvs17 monitor when i start to use my web browser on linux distros. Now, for the next few days i am going to try my system on a regular crt monitor. if the monitor does not crash, than i will have to say that the hpvs17 monitor has a defect.It seems that when i go online, while i am in the middle of searching something, the monitor just shuts off and i get "input signal out of range".
Jan 31, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Monitor has no picture
Yes! :)
Your monitor is not the problem. Check all the connections from the back of the monitor, to the computer.
"No Signal Analog" means your monitor is working perfectly, however is not receiving signal from the computer.
Didnt find any loose cables?
Try unplugging everything. Leave it unplugged for at least 5 minutes. You need to give the system time to drain all the excess power.
Again your monitor is fine, blue light > No signal > orange light is totally normal for your montior.
Oct 12, 2007 | ViewSonic VX922 19" Monitor Flat Panel
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
369 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
