Question about Sony KP-51HW40 51" Rear Projection Television
I have a sony kp-51hw40 that I just received
I have a sony kp-51hw40 that I just received from a friend. Seems to work fine, but after a while being on the colors start to fade out of the picture. He also said after a time or to, the tv would just shut off while on. you can turn right back on, but I have not witnessed that yet. can you help??
  • Sony Master
  • 8,457 Answers
This problems also cause by the 2 STK convergence ICS and some or all it resistor are dead.Require changing the 2 STK convergence ICS and some or all it resistors will solved this fading out and shuting down.
Posted on Jul 11, 2010
  • Chi Chu Jul 11, 2010
    This problems can be fix by the shop about $300-350 for parts and labors.
My Sony KP-51HW40 is underscan!
If you have already changed the aspect ratio on your TV, then change it on your cable or Sat box. Your TV appears to be operating normal.
Jun 17, 2012 | Sony KP-51HW40 51" Rear Projection...
I have a sony KP-51HW40 and when i turn it on about 5 minutes later it shuts it off.
If the TV works fine during the 5 minutes its on then your power supply in the tv is heating up and shutting off. If you have some mechanical knowledge you can buy another power supply from Ebay for around 35.00 and replace it. will require some soldering
Jan 23, 2011 | Sony KP-51HW40 51" Rear Projection...
I have a KP-51HW40. Everything works fine but the screen stays blue. What could the problem be?
if blue picture tube is blooming with retrace lines? it's because it developed internal short. you might try to turn down screen on blue picture tube. always mark with fingernail polish so you can return to starting position. J.D.W.
Jun 24, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony kp 51hw40 real projection tv
Below is exploded view of your Sony KP-51HW40 TV rear side which shows board names and location.
You need to check D Board for convergence ICs and these are marked as IC8001 & IC8002 on circuit board.
Nov 23, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40
sounds like the tuner may be going out on the set.
Aug 10, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51in
It sounds like your red tube is going out. Fairly expensive piece but easily replaced. They run anywhere from $250-$350.
Jul 23, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW40 - Picture not Clear
Your problem is a typical convergence problem that happens on almost every tube type projection TV set ever built. There are two Convergence amp IC's that need to be replaced. If you have no TV repair experience, play it safe and call in a pro to assist you in this. Good Luck
Apr 29, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
126 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
