My laptop wont tack power from the mainsor battery to the notebook.
    Brigadier General:
  • 10,406 Answers
This problem is not a "user-repairable" problem.
Take the computer and the power-supply to a qualified computer technician, for proper trouble-shooting and repair.
Posted on Jul 21, 2010
It wont start up again, power problably good, no problems before this
try tacking out the batt and leave the mains plugged in, if it turns on you will need a new batt
hope that helps
Jan 09, 2011 | Acer Aspire 5050-3242 Notebook
Can tacking out the keyboards battery reset the password
No - the password is stored in non volatile memory which means even taking out the battery wont clear it. Some Manufacturers have a super user password to clear the admin password - call the support desk for the manufacturer of the laptop you have.
Sep 08, 2010 | Computers & Internet
Hp compaq 6720 laptop, wont charge battery, bought new battery have same problem. have tried several different chargers and they are all working, but not charging battery
If the notebook does not charge even after replacing it with new battery and checking with several chargers then it is laptop power jack issue.
You may need to replace it. However to confirm the issue is with power jack just remove the battery and try to power on the notebook only with AC adapter. If it does not then it is the power jack which is allowing the ac power to be charged.
If your notebook is in warranty then you can ship it to HP and if it is out of warranty then check the link below, you can purchase the power jack of the laptop from here.
http://www.laptopjacks.com/parts/HP-6720s-laptop-parts-466.html
May 27, 2010 | HP Compaq 6720s Notebook
My Toshiba wont turn on. I tried holding the power
Hi there, Your ac adapter is damaged & that's why power does not transfer in your notebook. The capacitor of adapter is burned & that's why the noise started. Thanks & waiting for your feedback.
Feb 19, 2010 | Toshiba Satellite A60 Notebook
I JUST GOT A GATEWAY M465E NOTEBOOK ON 07' ,IT WONT POWER ON!!! I THOUGHT IT WAS MY CHARGER SO I BOUGHT A NEW 1 FOR MY EXACT MODEL & IT STILL WONT POWER ON! IM TRYING TO SEND IT BACK FOR REPAIR OR A...
There could be a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
If the laptop works directly from the power adapter with the battery removed, then the power adapter is good. In this case we can suspect that the battery is defective & needs to be replaced.
Nov 22, 2009 | Gateway M465-E Notebook
Has power but wont boot up at all inspiron b130 notebook, was working fine 4 days ago ,
There could e a problem with the battery. A fast check to determine whether you have a problem with the power adapter, power cord or the laptop's battery is to turn off the laptop, remove the battery, connect the power adapter, turn on the laptop & see if it works.
Try also to reseat the main components of the notebook: the battery, the AC adapter, the memory modules, & the hard drive.
After that try switching it on & see if the problem was fixed.
Nov 15, 2009 | Dell Inspiron B130 Notebook
I have an Acer Aspire 3610 notebook. It wont charge
How old is your battery? When you use your laptop, do you run it on just the battery or do you use your a/c adapter and battery? If you're going to use your laptop for an extended period of time, it's recommended to remove the battery and run off of a/c power alone. This helps to extend the life of your battery. Over time, using both a/c and battery will cause your battery to charge/discharge, which dramatically shortens the life of the battery.
You may simply have a dead battery.
Another alternative is that you have a bad power unit, which is what the a/c adapter plugs into on your laptop. My guess is that you most likely have a dead battery.
Oct 07, 2009 | Acer Aspire 3610 Notebook
My hp laptop wont start power light flashes on
try powering up the laptop with the battery pulled. In my case, the battery was the culprit. Probably shorted.
Mar 28, 2009 | HP Pavilion dv2000t Notebook
2007 white macbook, battery is full, unit will
try tacking the battery out. Holding down the power button for about 10 seconds and then putting the battery back in and giving it a go...
It resets the power management system
Feb 20, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
