Question about Dell Dimension 2400 PC Desktop
Just reinstalled XP - cannot increase text size by using VIEW
Enlarge text size
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
This will add to your screen toolbar File Edit View Favorites Tools and Help select the View from the drop down list will be a Zoom with percentages % and text sizes largest to smallest and Full screen option
Increase the Font Size in Email
Email font size is easily controlled while composing messages, but the messages you receive have been sized by the sender.
Some contacts may be perfectly comfortable writing in size 8, but such text can be a strain on the eyes, even with good reading glasses.
The printed hard copies of email messages with small text are even more difficult to read.
There are a few ways to quickly change font size for ease of reading and better quality print-outs.
Open an email message with particularly small text. Increase the email font size of the text using step 2, 3 or 4.
Click on the "View" selection from the menu bar.
Roll the mouse pointer over the "Zoom" choice.
Click on one of the choices that is greater than 100 percent.
Click "View" and cover "Zoom" to make a larger choice if the first choice does not increase the text size sufficiently.
Click the "View" option on the menu bar. Roll the cursor over the "Text Size" selection.
Choose one of the options that will increase the text size.
For instance, if the current size marked with the dot is "Medium," then click "Larger" or "Largest" to make the print appear bigger.
Use a mouse with a wheel to increase the email font size.
Press and hold the "Ctrl" key while rolling the wheel on the mouse.
The text will shrink as you roll in one direction, and grow bigger as you roll in the other.
Change font size before printing.
Click the "File" option on the menu bar.
Click "Print Preview."
Click the "Size" drop down which may display "100%," or "Shrink to fit."
Select a choice greater than 100 percent to increase text size.
Click the "Print" button to view the results on a hard copy.
Nov 13, 2013 | Computers & Internet
Reinstalled windows xp, now all text is small, screen is not full size, mant others hace complained about this problem...what gives!!!!!
Click start control panel administration tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
You might need to upgrade your graphics card drivers
http://download.cnet.com/nVidia-Graphics-Driver-Windows-XP-Media-Center-Edition/3000-2108_4-10044975.html
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
on the top of the internet page you should see some tabs file edit view favourites tools and help click on the view tab on the drop down list you should see a zoom size %
click a different percentage also a text size you might try a different text size although this will not increase the size of the page only the text fonts inside it
if you do not see these tabs in the top toolbar
right click in the top toolbar you will see a number of toolbars and options select the menu tab this will add at it to the toolbar
there should be some adjustment tabs located on or on the underside of your monitor you will need to find the menu tab first you might see some arrows with pointers to extend or retract your screen and one to locate it centre
hope this helps
Jun 19, 2012 | Sony VAIO PCV-RS310 PC Desktop
Increase text size
There are a number of ways to increase text size.
1. You can change the resolution of the screen using the START>Control Panel>Display
2. You can adjust the sizes by using the View tab on the Menu bar. View>Text size.
3. Your can adjust the display sizes by using the View tab on the Menu bar. View>Zoom.
Let me know if you have any more questions or problems.
Please rate this solution. Thanks.
Sep 14, 2011 | Computers & Internet
How do i increase the text size on aol 8.0
If you are using Firefox( any version) just press Ctrl and plus to increase text size/ Image size.
It should go back to normal size when you navigate away from the page.
Hope that solves it.
Cheers from NZ
May 17, 2011 | Microsoft Windows XP Home Edition
I need to increase text size on the Internet and I am having problems. Isn't there a way you can increase text size by brushing two fingers across the track pad and pressing control or another key? ...
If you're using Internet Explorer 7 (or 8) on Windows XP, or Internet Explorer 7 or 8 or 9 on Vista:
* hold CTRL and press "plus" to increase the font-size by 25%
* hold CTRL and press "minus" to decrease the font-size by 25%
You can do this more than once! Use CTRL-and-"zero" to reset to 100%.
Look in the bottom-right corner of IE's "status bar" (use "Tools" and "Tool Bars" to enable the "status bar") for the current magnification, i.e., 100%
May 15, 2011 | Toshiba Satellite A135-S2276 Notebook
INCREASE PRINT SIZE
text size is set from the software you are using to view text. in internet explorer (windows 7) you go to view and use either "zoom" or "test size" to chang it, up or down. othere programs, like microsoft word, have the same ability. so bottom line here is that the text size is not controlled on the monitor but rather in the computer
Mar 19, 2011 | LG 22" FLATRON LCD Monitor
Windows XP text size is too small. How do I make it largerr?
Click on your Desktop with the right mouse button and select Properties from the Shortcut menu that appears. In the Properties window, click on the Appearance tab. At the bottom of the Appearance tab you will see "Font size:" click on that drop-down menu and you can select Normal, Large Fonts, or Extra-Large Fonts. This is how you change the size of the text that is specific to Windows.
To change the size of the text in Internet Explorer, open up Internet Explorer and find the View menu (it should be near the top left of the screen) click on View and in the menu that pops down, hover your mouse over Text Size so the menu will pop out to the right, here you can select Smallest, Smaller, Normal, Large, Larger, and Largest.
If you would like to increase the size of everything in Internet Explorer, you can hover over Zoom in the View pop down menu and change how much you are zoomed in, this will increase everything for you!
I hope this helps! If not, please comment back and let us know!
Jan 04, 2011 | Computers & Internet
Printing yahoo email
According to Yahoo's Answers page, another Yahoo email customer had the same problem, and resolved it by clicking on "View" on the browser toolbar, then "Text Size" and selected a larger size ("Increase" on the Firefox browser).
May 19, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Increase text size
hello, you need to open up your web browser. you should see a toolbar that has file, edit, view, favorites, tools, and help. Go to view and you will see text size click whatever size you want. if you dont see that toolbar, go to display setting and change it to classic settings you will find it there.
Mar 08, 2008 | HP Pavilion dv4000 Notebook
Text to small when printed out
may be your screen resolution is too low (things on the screen appear as big). Try increasing your screen resolution.
To do this. Right-click an empty area of desktop > click properties > Click setting > move the slider of the resolution tab towards the higher number.
Sometimes the application that is used to create or print the document may be set to a view level of low zoom size. increasing the resolution view size of the application should solve your problem.
It is recommended to use true type fonts they print in actual size.
Oct 27, 2007 | HP PSC 1350 All-In-One Thermal Printer
Dell Dimension 2400 PC Desktop Logo
18 people viewed this question
Alun Cox
