iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i
This machine and options can be upgraded by downloading system software programs from the personal computer (hereafter called as the PC) in which a service
support tool (hereafter called SST) has been loaded.
System software programs and upgrade tools are listed in the following table:
SST =Main unit System (main controller) The main controller also controls the reader.
Boot = (boot program)
Option PCL = (PCL printer kit-J1)
Fin_U1 (Finisher-U1) Dedicated service tool needed to update (Downloader PCB: FY9-2034)
System software programs to be downloaded need to be registered in the SST.
The system software programs are registered with the names listed below.
<Software Programs Pre-Installed in Main Unit>
Machine name:iR2020
Unit name:
- Main controller: System
- Boot program: Boot
- PCL board: PCL
[System Software Registration Procedure]
Start the PC.
Start SST.
Click the "Register Firmware" button.
Select the drive in which the system was downloaded
Then click the "SEARCH" button.
A list of system software programs contained is displayed.
This machine does not allow two or more system software programs to be downloaded at the same time. If two or more software programs need to be upgraded,
register and download them one by one.
When the system software program registration result appears, click the OK button.
Connection
1) Turn off the main power switch of this machine, and then disconnect the cables connected to this machine.
2) Connect USB connector on the back of this machine to the PC using the USB cable Downloading Procedure
1) Turn on the power switch of the PC and start SST.
2) When the power switch is turned on, the Found New hardware Wizard appears. Click "Cancel".
3) Select "MFP" in "Target Selection", and then select "iR2020" in "Model List".
4) Double-click the "System" folder in "Model List" to check the system software version. Select "USB" in "Interface", and then click the "START" button.
5) Turn on the power switch of the host machine.
6) Press the following keys on the control panel to enter the service mode.
Additional Functions Key > 2 Key > 8 Key > Additional Functions Key
7) Using the plus (+) or minus (-) key, select "#DOWNLOAD".
8) Press the OK key on the control panel to place the host machine in the downloading wait mode ("#DOWNLOAD CONNECTED" is displayed).
9) Press the OK button on the SST screen displayed on the display of the PC.
10) When connection is complete, Click the OK button in SST MENU.
How to reset E000, E001, E003, and E007 Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine. Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one. Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair. Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set". Canon Printer Support Phone Number
1. In standby mode,press the "Settings/Registration" key.
2. Press the"Reset" key.
3. Press the"Back" key.
4. Press the"Settings / Registration" key.
5. The service modescreen is displayed.
6. Scroll to Printerthen choose Clear
Use the"Back" key to exit Service Mode
<quote> How to reset E000, E001, E003 and E007 Canon IR2016, IR2020
Press "OK" than Press "Stop" or "Additional Function key" to end service mode or restart the machine.
</quote>
first, you need to be an administrator with an administration id and pass to change any id and pass
please call canon Technical support, they can help you without damage.
Under service mode *28* find the clear all and OK, after that you shouldnt have any pass required, but you need to set the IPadress, and your preferd sets.
OK, you should have canon driver/software cd.On that CD you will find Scan Gear, after installation, open Scan gear and "discover" the ir2020.( copier must be in scan mode) then press select. Open the word or similar on your pc that is connected with USB to copier.Under tab insert chose the insert from scaner or camera, chose scan gear and custom insert.
you have miss regrestion there are several ways to correct this process 1-go into service mode -function-clear-dc con -ok then take machine off unlug from wall outlet replug turn machine on 2-replace your itb assy. 3-there is another way but you have to be next to the machine and fimilar with second level service mode.
The system has returned to default but it now asks for a system ID which it didn't before.
Is there a default system id and password?
Simon
