When the lid is moved to the fully open position on the laptop the screen colour changes from whit to yellow by moving the lid more towards the vertical it rectifies itself. I am guessing that it is a connection problem on the hinge. How do I get at it?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 99 Answers
By seeing your problem I would recommended you to go to the authorized repairer as it is not possible to solve it manually as it might cause more problem to your laptop.
Posted on Jul 11, 2010
The yellow light on main unit flashing ,there is power can here the opener click but wont engage ? from main control and remotes
Be sure the level that the release rope is connected to is pointing towards the motor unit, and raise/lower the door to the position of the inner carriage, so that they will engage. If the inner carriage is fully closed and will not move to the open position, or still will not connect with the outer carriage, you will need to have the opener serviced.
Aug 20, 2013 | Chamberlain 1/2-HP Whisper Drive Belt...
Where is the samsung laptop service centre in DC, USA
It would certainly seem so. Has it been damaged? Dropped, Jarred, bumped? If your not comfortable with opening the laptop, take it to a Qualified Computer tech. There are connections in the rear of the monitor, a ribbon cable, and at the bottom of the monitor, behind the bezel.
Dec 28, 2012 | Samsung Computers & Internet
How to change ink cartridge ?
open the printer by lifting the lid, and the ink cartridges will auto move to where you can have access to them, ensure you have the power on, check in detail the present position, and replace the new inks colour by colour in the same position, close lid, power off the printer for 3minutes, power on again and follow the instructions on alignment, and cleaning of the new inks
Mar 31, 2010 | HP Officejet 4315 All-in-One Printer
Hp pavillion dv9000 lcd screen changes colour when moved
The inverter is to change the volts from the laptop to the Backlight. This wont have anything to do with it.
Im more than certian it will be the LCD cable. Proberly loose or torn at where the lid closes.
Hope this helps.
James
Feb 23, 2010 | HP Computers & Internet
How do I life up the screen (open the laptop) on an HP Pavilion vd 4000? when I press the central button on the front, nothing happens.
When you push on the center button, that is supposed to move two hold down teeth to the side allowing the screen to move up. You then grab the lid and lift the screen manually into position. If the lid will not move up with the button depressed, then a piece of linkage is either binding or broken. In that case, keep the button depressed and try taking a credit card and sliding it from one side to the other and then back in the opposite direction, the teeth are tied together so if you move one, you move both. If you feel resistance on the card, try lifting the lid as you move the teeth.
Sep 27, 2009 | Computers & Internet
How do you manually position the ink unit. i.e. when an ink colour has NOTrun out when it asks for a replacemnent and on commencement of this the inks are positioned to allow top to be opened.
You can always open the top..?
The ink tray should move towards a spot where you have access to the cartridges once you open the lid.
Read the owners manual.
Aug 14, 2009 | Office Equipment & Supplies
Changing Cartridges does not move into view so I change it
try the on/off button with the lid open. it should move the cartridges.
Jun 21, 2009 | Epson Stylus C86 InkJet Printer
Remove ink cartridge
I found that the proper way to do it only worked when the ink light was flashing red. Then when I pressed the stop button it moved across and stopped beneath the marker to show which cartridge needed changing. The I pressed the stop button again and it moved to a place where I could change it.
This happened despite the fact that the pictures I was printing blatently showed that I needed to replace my ink, it wasn't until I had printed the liney pictures a few times that the printer decided the ink level was low enough to turn the flashing light on and let me change it.
Jan 23, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Iwant to change the coloured ink
just open the front door while the printer is on. the carriage will move and stand to the cartridge install position.hold the colour cartridge pust it little bit towards down till it leaves the lock and then get it ouside towards ur side.fit the new cartridge in the reverse procedure.
thanks.
Sep 15, 2008 | HP Office Equipment & Supplies
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
