Question about Rolex Day-Date President 118238 Wristwatch
What do the numbers 8385 mean on my rolex watch band
    Genius:
  • 1,970 Answers
Mcdevito75 here, Most likely the manufacturers ID for that particular band.
Posted on Jul 11, 2010
Where are serial nimbers located in rolex watches
Rolex case serial numbers are always stamped into the case beneath the bezel and you need to remove the watch band to read them...
May 21, 2014 | Rolex Daytona 116520 Wrist Watch
I buy a Rolex and the seller told me the serial # was deleted but this store give me a letter of disclaimer. Do I can have any problem in future for this.
Does the watch itself have a serial number on it? If the watch was manufactured after 2005, there is a chance that it will have the serial number engraved on the rehaut (inside metal circle under the crystal). If not, it will be engraved on the watch case under the band at the 6:00 position.
Maybe they mean it was polished off? If it is, that is a problem if you were to ever want to get it serviced by Rolex or if you ever wanted to resell it.
If you provide the serial number they gave you, I am happy to run a check to see if it is a reported counterfeit.
Sep 29, 2013 | Rolex Daytona 116520 Wrist Watch
Hello please help, I wish to know what year Rolex Oyster Perpetual Lady Date model 6519 was Manufactured. Thank you in advance.
This model Rolex has been manufactured over multiple years, and it is not possible to date your watch based purely on is model number. However, it is possible to date most Rolexes based on their serial numbers, which can be found stamped between the lower lugs (i.e., the lugs below 6:00 on the watch dial). You will need to remove the band from these lugs to read the serial number.
Dating the watch case of a Rolex does not necessarily date the entire watch. It is possible that a movement from another watch was placed into a watch case that is younger or older than the the movement. Like Rolex watch cases, Rolex movements can also be dated by their serial numbers, if this is a concern you have about this particular watch.
This jeweler has put together a nice summary of when Rolex watch models were introduced and which serial numbers are associated with specific years of manufacture. Once you have found your serial number, this should help you date your watch. I have no connection (financial or otherwise) with this web site, but I found the information useful and presented in an easy to understand way.
http://www.bgrayjewelers.com/rolex_information.htm
Jun 03, 2011 | Watches
Where are the model number and serial number on a rolex
Thank you for contacting FixYa.
  • Look at the side of your watchcase. On the watchcase lugs, located where the watch bracelet is attached, you may see one small hole on each lug where the spring bar is located. This means your Rolex has the traditional pierced lug style. If your Rolex does not have the pierced lug style, turn the watch over, and look for the long spring bar in the space where the bracelet meets the watchcase. The spring bar attaches the bracelet to the watchcase. The directions for removing the spring bar on both watch styles is slightly different.
  • 2
    Use your thumb to press down on the link where the band meets the watchcase if your Rolex has the pierced lug style.. If your Rolex does not have pierced lugs, turn the Rolex over, and press down on the link where the band meets the case. Either way, you are applying gentle pressure to the same link, just different sides of it. Remember, you are only removing the side of the band at the bottom of the watch, so press on the link below the 6. Maintain gentle pressure on the link while performing the next step.
  • 3
    Insert the tip of your spring bar tool into the lug holes, and push the spring bar inward. When done correctly, you will feel the spring bar fall into the case, rather than pop back out. Repeat this step on the other side of the spring bar.
    For a nonpierced lug watch, place the tip of your spring bar tool on one edge of the spring bar, and push inward, until the spring bar falls into the case. Repeat this step on the other side of the spring bar.
  • 4
    Pull the band gently away from the watchcase. It should remove easily. You can now see the serial number on the watchcase.
  • The reference or model number of a Rolex is located between the lugs at the 12' position. It is also listed on the certificates Rolex issues.
    Hope this helps. Jewel
    Oct 07, 2010 | Rolex Oyster Perpetual Submariner Date...
    I currently purchased a rolex super president watch which is second hand wen impurchased the watch it had no papers but was bought from a registered rolex dealership i do not no the year of manufacture but...
    If you don't have this ORIGINAL VALID STAMPED INTERNATIONAL ROLEX WARRANTY then your watch does not have any warranty. Just approach the dealer and ask him for ORIGINAL VALID STAMPED INTERNATIONAL ROLEX WARRANTY otherwise your watch does not have any warranty
    Jul 11, 2010 | Rolex Day-Date President 118238 Wristwatch
    Need to know if my rolex watch is real not a fake
    There are many great web pages to do this with.
    One example:
    http://www.qualitytyme.net/pages/rolex_or_replica.html
    There are also various type of fakes on is to use a real Rolex dial and all and replace it with fake movement.
    All i can suggest is do your home work and find a actual Rolex Dealer in your area to talk to.
    r/
    David
    Feb 04, 2010 | Rolex Daytona 116520 Wrist Watch
    How do you adjust the band on a rolex watch
    Unscrew bracelet screws from the side and take out/add link. Then screw bracelet screws back.
    Jan 29, 2010 | Rolex Day-Date President 118239 Wristwatch
    Unable to Open Rolex Band [knockoff]
    Hello
    I bought one while on a buisness trip to China. I like the watch alot but the band was too big. I have a friend who's a jeweler. He fixed the band for free. It does take a special tool (which he had).
    Aug 05, 2009 | Rolex Day-Date President 118238 Wristwatch
    How to remove links if there are no pins
    All Rolex watch bracelets has screws, not pins. Get small screwdriver and unscrew them.
    If there is no screws at all, that means bracelet links had been removed and you have shortest version allready ,or, this is not the real (genuine) Rolex bracelet.
    Find your nearest watchmaker to clarify all this.
    Jun 27, 2008 | Rolex Explorer II 16570 Wrist Watch
    How to open a ladies rolex watch band
    how to open rolex wrist band brand new watch
    Oct 03, 2007 | Watches
    Rolex Day-Date President 118238 Wristwatch Logo
    1,075 people viewed this question
    Top Rolex Watches Experts
    Arturs Kalnins
    Arturs Kalnins
    Are you a Rolex Watch Expert? Answer questions, earn points and help others
